FSP EP1000, too low output voltage.
  • warsztat
    • Feb 2017
    • 190
    • Polska
    Hi, I have ups fsp ep1000, his output voltage got too low.
    In power socket 235V his otput is 203V, in program "View Power Monitor System" output voltage is ok but input voltage shows 245V. I think voltage measurement circuit is bad but I do not have a schematic to identify elements.
    I need schematic or indication elements.
    All the best all.
    • 31304
    Re: FSP EP1000, too low output voltage.
    i have never seen a system that reads the input voltage.
    • warsztat
      • Feb 2017
      • 190
      • Polska
      Maybe I'm misunderstood, sorry my bad english.
      One picture instead of a thousand words.
        • 31304
        ah, i see.
        probably a bad op-amp or voltage reference chip (tl431?)
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          Originally posted by stj
          ah, i see.
          Or a drifted-high resistor on the topside of a voltage divider.
          "pokemon go... to hell!"
          EOL it...
          All style and no substance.
          guilty,guilty,guilty,guilty!
          guilty of being cheap-made!
          • PeteS in CA
            • Aug 2005
            • 3586
            • USA, Unsure of Planet
            ah, i see.
            Or noise.
            Many server PSUs have microcontrollers on both sides of the pri-sec barrier, with communication between. These report to the server the input and output voltages and currents to the server.
            Back in 1981 or so an engineer at Boschert predicted that a time would come when power supplies would be controlled by Z80 microprocessors. I laughed at the idea. Well, it took 2 or 3 decades, and the actual parts are not literally Z80 microprocessors, but that time has come, for servers at least.
            PeteS in CA
            • warsztat
              • Feb 2017
              • 190
              • Polska
              Good discussion, I still need a schematic. I use a lot of time for repair without a schema. UPS is measuring badly so it gives bad outage voltage, it works on a transformer that heats up.
              • Stefan Payne
                • 1267
                First one I've seen is from 2003 or so with a PIC16 Micro and was made by NMB, dual PCB WTX. The one Fujitsu-Siemens used in the Celsius 670.
                • warsztat
                  • Feb 2017
                  • 190
                  • Polska
                  Hello, I found some time and solved my problem.
                  I replace capacitor C6 and add resistor 100kohm in measure input voltage circuit.
                  Now is ok
                  Regards for all.
                    • 31304
                    it may get worse, you didnt find the fault - you adapted the circuit.
                    • warsztat
                      • Feb 2017
                      • 190
                      • Polska
                      After replace capacitor voltage measurements stabilized (differences before in time between indicating UPS and measuring with a multimeter).
                      Resistor add because of my power supply network that floats near to the stabilization value of UPS. The relay knocked too often. I have reduced the measurement to about 5V and there is finally silence . Otherwise, it would be enough to replace the C6.
                      Sorry my bad english.
                      • electron_jj
                        Panasonic TH-L42D25A checking the PSU output voltage
                        by electron_jj
                        Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                        I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                        08-29-2021, 08:13 AM
                      • David Miteff
                        NM-D521 rev. 2.0 output voltage on CPU coils seemingly low
                        by David Miteff
                        Hello, guys!
                        As the title says - the board is NM-D521, on the input of the CPU coils I read 1.2-1.3V, which should be normal, but on the output I read around 0.6-0.8V. The laptop bootloops with no picture.
                        As of right now I don't have a thermal camera, so I can't confirm a shorted or partially shorted CPU chip. Do you have any other suggestions as of why the output voltage might drop like that?...
                        12-30-2024, 07:02 AM
                        MT3608 Step-Up Converter IC Datasheet
                        The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
                        Internal soft-start results in small inrush current and extends battery life.
                        The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...
                        10-07-2024, 05:02 AM
                      • Ri5ux
                        Playstation 5 2 Second BLOD, F3501 Voltage Output Question
                        by Ri5ux
                        Hi there, just wondering if anyone out there who has a semi-working or working PS5 board could check the output voltage on F3501's buck converter for me, with and without power. I have 12V on the input, fuse not blown, no output voltage on that IC, with or without power, and no shorts present.
                        Symptom: 2 Second BLOD
                        Testing: All other rails seem present. APU, SSD, South Bridge, and RAM confirmed to be powering up using a thermal camera. Monitoring the current draw of the 12v rail shows a somewhat normal boot cycle of the south bridge. Jumps up to 300ma, and down to 0....
                        09-09-2023, 06:57 PM
                      • labello
                        Power supply Termaltake Smart Se 630w any voltage in output
                        by labello
                        Hello everybody I try to fix thi power supply, I have voltage in bridge rectifier, and also in the large capacitor , so I thought the problem was in the pfc but then I found all mosfet ok(tested out of the circuit so I just moved on in the low voltage and here I found a short of one of the diode rectifier. I'll replaced it already but it's completely dead, I mean any stanby voltage and the other voltage is not present. I don't have oscilloscope to understand if the chip work how can I test it? Thank you for the help 🙏
                        09-09-2023, 12:06 PM
