Bestec SMPS repairing
  • Sunil N
    • Jun 2018
    • India
    Hi I have received Bestec TFX02505W SMPS with burning of Dip Ic. Hence I require circuit diagram.
    Regards.
    Sunil N.
    master hoarder
    • May 2008
    • 12175
    Re: Bestec SMPS repairing
    It's rare to find full schematics for OEM PSUs like Bestec. So your best option is to post good quality images here so that we can see the circuit and try to help you troubleshoot it.
    • Astonished
      Fixing the Charge Circuit of the Batteries of the DC Motor
      by Astonished
      Hi friends of electronics
      What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
      The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
      Please help me fix this circuit.
      (the datasheet of the IC: https://pdf.datasheet.live/28...
      01-28-2025, 06:24 AM
    • Tarot Superstars
      Short Circuit tester
      by Tarot Superstars
      Hello.
      I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
      The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
      Link
      The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
      https://www.youtube.com/watch?v=0eixDdCpiO4
      My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
      09-25-2023, 09:11 AM
    • dkneyle
      Onkyo DX-V500 Laser Disc Player - weird SMPS fault
      by dkneyle
      This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
      Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
      02-01-2022, 02:08 AM
    • Alimash
      op amp circuit function?
      by Alimash
      I am repairing a ups which doesn't turn on ,it has the following ICs:
      SG3525 used to drive inverter mosfets.
      couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
      A LM358 and TL074 for control mechanism and of course the uController.
      The SG3525 is shutting down every time the ups is turned on.
      I want your help to know the function of LM358 and TL074 in the system.
      I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
      07-31-2025, 07:45 AM
    • M1NEBLANK SHOW
      MSI B250 Gaming M3 Short circuit in CPU power supply circuit
      by M1NEBLANK SHOW
      Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
      (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
      Schematic and Boardview here
      04-04-2025, 03:57 PM
