All replacement capacitors in iMac G5 PSU burned up
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: All replacement capacitors in iMac G5 PSU burned up
    I wonder how many little Chinese girls it takes wrapping wire around doughnuts to keep the world supplied with those things.
    You need same size doughnut (core), same wire gauge, and same # turns.
    If you find a scrap one that's right except too many turns you can un-turn a few until it's right.
    Mann-Made Global Warming.
    - Dr Seuss
    • i4004
      • Oct 2006
      • 2029
      nwd, what was the cause for you to get new caps?
      smell?
      same smell as you got now?
      if coil was burning before and now, change it.
      if otoh coil started to smoke only now, it's not the coil.
      • relkin67
        • Sep 2007
        • 36
        iMac G5 PS
        I performed this same repair about 3 months ago on an iMac G5 I picked up cheap on Craigslist. The original PS caps are ALL Ltec low ESR (the manufacturer's spec sheet, if believed, shows specs superior to Nichicon PW). Now this is a REALLY hot and stressful application - one that seems to separate the boys from the men. Taiwanese/Chinese capacitors seem to really fail in an poorly ventilated PS (which this most certainly is!)
        My research indicated that the secondary caps are the first to go followed by the coil here mentioned. I seem to have been lucky because the coil didn't burn yet in mine. I replaced everything electrolytic - secondary AND primary with Nichicon PW, Panny FM (Digi-Key was out of stock on some PW sizes) and a couple oddball sized Rubys I got from Topcat.
        Been running 3 months 24/7 without a problem. The iMac was stuffed with dust when I got it so this could have been a contributory factor (you have to open these up every 6 months and dust 'em).
        • Toasty
          • Jul 2007
          • 4171
          Nit picker here. I expect nothing less in return...
          The 'doughnut' with the wire looped around it is called a torrid.
          Actually it's a:
          toroid - a doughnut-like solid whose surface is a torus .
          not
          torrid - parched with heat; hot <torrid sands>; giving off intense heat; scorching
          Actually, since it's cooked, it's a....
          TORRID TOROID !!!
          LMAO
          Sorry,
          Toast
          You may now return to your regularly scheduled drinking.
          veritas odium parit
          • Wizard
            • Mar 2008
            • 2296
            LOL Indeed!
            Cheers, Wizard
            • i4004
              • Oct 2006
              • 2029
              #26
              i find nothing weird there...i noticed it too, but i know bonez is horny, so it's an easy typo to make...hehe...
              • Toasty
                • Jul 2007
                • 4171
                #27
                I would check to see if the core is indeed shorted to the windings.
                Since it looks to be bare metal where the insulation has flaked off on top, first check the core itself with an ohmmeter to see if is conductive. Set the ohmmeter range to read in the x5k or less range and put both leads tips on that bare spot on top. If it gives a reading, it's a powdered iron core. If you get no reading the core material is ferrite.
                If it's powdered iron: Place one ohmmeter probe on the core, check to the underside of the board where the cores leads come through. If you get a reading from the core to either lead, it's shorted and will need to be rewound or replaced. Also, I'd wiggle the core about to see if it has an intermittent short.
                If it's ferrite: Since the core has overheated (obviously), its mµ (magnetic permeability) is destroyed, and may be causing the problem. Rewinding the toroid is not an option. Replacement only.
                On the other hand, if it is an iron core and the coil is not shorted, then the core is okay and the cause of the overheating likely lies elsewhere.
                Replace the cap that you didn't unless you can prove it's not faulty with an ESR meter. It could be that now that everything else is running correctly, it can't handle the stress of the frequency and/or ripple current. That may be causing the coil to go hot.
                Can you run the supply free of any load? Does the toroid get hot then?
                Has an overload condition on the motherboard been eliminated as the cause of the overheating? ie. more bad caps? MOSFET's?
                Toast
                veritas odium parit
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Actually it's not: Nit picker,,, it's: Nitpicker
                  - Dr Seuss
                  • i4004
                    • Oct 2006
                    • 2029
                    #29
                    lol!
                    • nwd
                      • Feb 2009
                      • 22
                      #30
                      What specs do I need to know to get a proper replacement coil inductor? Is the gauge and number of coils sufficient or do I need more info - H value? Does the core have specs I need to know? What does the +3.3 refer to in kc8adu's post? Voltage?
                      Thanks again.
                      -Nate
                      • nwd
                        • Feb 2009
                        • 22
                        #31
                        Sorry for the inductor spec question - didn't see there was a page 2 of replies.
                        In reponse to i4004, replaced caps only because computer would not power up. 7 secondary caps looked swollen and a couple had a little brown stuff at the top. No smell prior to repair. The coating on the coil was cracked and split before repair but not black at all.
                        I definitely had to get in and around the coil with an exacto knife to clear all the putty that was in there so the caps could be freed. Could it be possible I damaged or altered the coil during that process?
                        In response to Toasty, motherboard caps look fine - not sure about MOFSET. I believe a different model iMac had much worse motherboard cap issues.
                        After moving the windings on the coil around a bit, I plugged in the power supply without load. It's been running without heating up for about half an hour now. The computer had been working fine for a day or so before the smell started originally.
                        I am so thankful for all the comments and advice from so many members.
                        I'll pop it back in the machine under load and see what happens. I'll also look into finding a new coil.
                        • nwd
                          • Feb 2009
                          • 22
                          #32
                          Yep, under load, that coil heated up right away. The computer worked fine but I shut her down.
                          • nwd
                            • Feb 2009
                            • 22
                            #33
                            The one unreplaced cap is a real bear to free, which, since it looked okay was not replaced. I believe the tech tested it in place but I need to verify that.
                            -Nate
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              I think the Toriod is shorted like KC said.
                              If a shorted Toriod worked they wouldn't use them, they'd use a piece of wire instead.
                              - Dr Seuss
                              • i4004
                                • Oct 2006
                                • 2029
                                #35
                                to me this suggests it's not a coil's fault, but given you don't have real choice try to replace it.
                                this
                                https://www.badcaps.net/forum/showpo...58&postcount=3
                                does and doesn't make sense.
                                it doesn't make sense because after the repair coil shouldn't be getting hot at all, so what's there to deteriorate it further?
                                ie if he had come cracks, ok fine, it was because of badcaps, but what is it now to make it COMPLETELY BLACK in one day?
                                i don't think one can call coil with few turns shorted at all, what's there to short? resistance goes from 0.050ohm to 0.049?
                                bleh...and like i said i don't think core material condusts more than wire, so why should current go there at all?
                                here
                                http://www.jimwarholic.com/docs/Appl...wer-Supply.pdf
                                i don't see coil mentioned at all...
                                good question...but why did starter of that other thread ask this
                                "Is there another cause for the coil frying itself?"
                                anyhow, change it and we'll know....heh...
                                how will you find out the h value?
                                if you can, sure, if you can't wire gauge, dimensions, and number of coils will suffice...
                                bonez, you're now talking of "toriod".
                                just say "coil".
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Yes i4004, we know you don't understand.
                                  ... But believe it or not they use coils because they are needed.
                                  ... And if it's shorted -> it don't work.
                                  - Dr Seuss
                                  • i4004
                                    • Oct 2006
                                    • 2029
                                    #37
                                    indeed, but if it "don't work" why is it getting hot...
                                    hehe..
                                    and to say "shorted" for few turns coil still sounds lame...
                                    its (miniscule anyway) inductance may be shot(if turns touch etc.), but like i said, that would make it heat LESS than if more turns are used and it had higher inductance...
                                    because it's effectively becoming a jumper, and why would jumper heat up?
                                    two possibilities:
                                    -eddy currents produced in the core because naked wire touches the core...
                                    -not coil problem at all, but changing caps changed the circuit characterictics, so coil is for some reason(particular frequency/amplitude of ripple) loaded more that normal...
                                    also, much higher current will flow if mobo is drawing too much current...those badcaps were there for some time, did they hurt the mobo?
                                    to that extent toasty said it all
                                    https://www.badcaps.net/forum/showpo...6&postcount=27
                                    yeah, i am curios why is it getting hot...you obviously are not....you're just..torrid..again...hehe...
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      What does an inductor do i4004 ?
                                      - Dr Seuss
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        #39
                                        think of your coil with shorted turns like a transformer with its secondary shorted.
                                        • PCBONEZ
                                          Grumpy Old Fart
                                          • Aug 2005
                                          • 10661
                                          Here's a hint i4004.
                                          - An inductor to a circuit is as a flywheel to a machine.
                                          [Come on... I KNOW you know.]
                                          - Dr Seuss
                                          • the Benninger
                                            Burning capacitors near Mosfet
                                            by the Benninger
                                            Hi Folk's, Thhe machibe its Dell OptiPlex 3070 mini, don't power up, two capacitors near mosfet (PQ0) burning
                                            These that you see on camera are new replaced, I had doubts if it was the capacitor (pc64) but I changed both at once, it still results in the same thing, it does not activate the safety of the power supply, and anyway the machine does not turn on, I am limited I only got this boardview, All ideas are welcome, the positive side capacitors have 19V without oscillations
                                            Mobo: IPCFL-CG Rev.A00
                                            S/T: JX8CM63...
                                            06-27-2024, 02:53 PM
                                          • Katz993
                                            iMac Display Replacement Adhesive
                                            by Katz993
                                            TL;DR: Looking for as-close-to-genuine as possible iMac Thin Panel (2012-2019) Adhesive.
                                            Long Rant: I run a tech shop that has a specialty in Macs. We've been doing upgrades and repairs on the thin panel iMacs as long as they've been out, and I've always had the issue of being unable to get something close to the OEM Adhesive for the Display Assembly, i.e. a 'two-part' adhesive, extremely thin but durable and can be cut easily with a thin wheel cutter. My replacement adhesive has always been essentially standard thin adhesive. For a long time, the biggest annoyance with this was having...
                                            03-15-2022, 10:31 AM
                                          • dragon3x
                                            by dragon3x
                                            power on.
                                            Here are some examples :
                                            switching supply area).
                                            than 6.3 V.)
                                            03-21-2025, 02:46 PM
                                          • nicktasios
                                            Macintosh Quadra 840AV PSU
                                            by nicktasios
                                            I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
                                            12-22-2024, 05:07 AM
                                          • Stephen
                                            iMac M1 DFU restore issue
                                            by Stephen
                                            iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
                                            this is the message it gives me with the error
                                            Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
                                            Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
                                            03-07-2025, 12:19 PM
