Intex Inflatable Spa - Pump Problems
  • mmartell
    • Oct 2013
    • 3189
    Re: Intex Inflatable Spa - Pump Problems
    Thanks for that bud! Only two wires so no speed control.
    Took some measurements at the unit. The voltage at the pump (with or without the pump) is 13.5v ac. The current draw on the motor is 5.25 amps.
    If I rectify 13.5v doesn't that come out to a fair bit less than the 12v necessary ?
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      ^Personally i would just build the bridge and install the pump. You gotta figure, what "12v" are they referencing? the 13v8/14v2 charge power of a vehicle's 12v system? That's what i assume....
      Follow the white rabbit.
      • mmartell
        • Oct 2013
        • 3189
        Ok so I should have thought more about this - when we rectify the incoming ac in a power supply the result is roughly 170vdc. So if I rectify 13.25vac I should have about 18.75vdc minus any drops through diodes (1 or 2v?) Does that sound right ?
        Isn't that a little too much to feed the pump ? What's the best way to reduce it ?
          • 31199
          at 5A+, better to put a £10 switching psu in from china.
          8-10A at 12v
            • 31199
            or an old pc psu - dont forget to put the results in the ghetto mod thread.
            • mmartell
              • Oct 2013
              • 3189
              Lmao
                Is that the current draw of the new pump or the old pump? What DCV applied to the new motor? 5.25A, that is more than the twice current rating of the motor with 12VDC applied.
                • mmartell
                  • Oct 2013
                  • 3189
                  The current draw was measured on the old pump with 13.5vac applied. The new pump has only been tested with a 12v battery, no current draw test has been done on it yet.
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    #29
                    Just whack it in. Chances are if the pump has died the vinyl sheeting isn't far off...
                    • mmartell
                      • Oct 2013
                      • 3189
                      Do I have to use 3A diodes to make a bridge ??
                        • 31199
                        use a rectifier with a metal base for those currents.
                        it will make it simpler anyway, because they have spade terminals.
                        • mmartell
                          • Oct 2013
                          • 3189
                          Sounds good but what is the significance of the spade terminals ?
                            • 31199
                            makes it easy to attach the wires
                            • mmartell
                              • Oct 2013
                              • 3189
                              I considered that but I thought there might be something deeper lmao
                              • mmartell
                                • Oct 2013
                                • 3189
                                So can I get away with a rectifier and an LM7812 ?
                                  • 31199
                                  no.
                                  read the datasheet - a 7812 is rated for 1A and then only with a heatsink the size of a brick!
                                    Can you get 12V 5A switching power supply brick from recycle place, if there is one close by?
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      Bud I probably could and would be the easiest way to do it I would just learn less What device would use that type of supply ?
                                      Stj I should have said the LM7812A I think it's rated for 5A.
                                        • 31199
                                        old tv's & monitors with ccfl backlights used big psu's
                                          It will dissipate about 12 Watts (Vdrops on the IC: 18V -12V = 6Vdrops; 6V x 2A load = 12 Watts) of power at 2A load so good heatsink will be required.
                                            ZD-915 vacuum pump motor mount service alert
                                            If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
                                            One note this unit has been repaired already once because of switching power supply regulator ic chip failure
                                            Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
                                            The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
                                            09-19-2021, 02:15 AM
                                          • jean luc ferre
                                            laptop hp g72 b52sf screen problems
                                            by jean luc ferre
                                            on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                            the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                            i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                            i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                            06-07-2025, 03:27 PM
                                          • Hondaman
                                            USB problems?
                                            by Hondaman
                                            Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                            (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                            I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                            08-12-2024, 03:26 PM
                                          • clabr
                                            Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                                            by clabr
                                            Need help to solve some problems with this laptop.
                                            After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                                            After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                                            Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                                            Before this had happened I observed some other problems:
                                            When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                                            12-02-2021, 08:09 AM
                                          • jean luc ferre
                                            display screen problems after changing motherboard
                                            by jean luc ferre
                                            First on my laptop i had a motherboard with a pentium 6100 processor. Installing w11 i was blocked on the 23h2 version...impossibility to upgrade toward 24h2 because the SSE4.2 functionnality of the cpu was missing. About displaying and screen looking all was perfect.
                                            I changed of motherboard with an intel I3 processor...and now i don't find the previous aspects of the displaying.
                                            Now i have a veiled screen and pixels are missing though the graphics parameters have not changed.
                                            Desinstalling and reloading the drivers in the same time on the graphic card (intel hd...
                                            09-11-2025, 10:28 AM
