400W PSU... is it worth trying to repair?
    master hoarder
    • May 2008
    • 12175
    Re: 400W PSU... is it worth trying to repair?
    Originally posted by stj
    rubycon YXJ are what i use for small caps under 4.7uf, for everything else i use panasonic FR
    I wouldn't... use Panasonic FR for everything, that is.
    Some PSUs, especially older ones, can be sensitive to very low ESR caps like Panasonic FR and may oscillate badly. And even if the PSU doesn't oscillate badly, it can still output more ripple than it did with the stock barely-low ESR caps. So for older PSUs, the most "far away" I go is Chemicon KY and Nichicon HE. Chemicon KZE and Rubycon ZL/ZLH - only on the 5VSB rail and/or very very rarely if nothing else is available.
    On the other hand, Rubycon YXJ is a very good choice for older PSUs due to not being that low in ESR. Same goes for Nichicon PS, PM, PJ, and PW - I use those all the time.
    As for the 400 Watt rating: I concur with everything that Wester547 said - it looks to me more like a 200-250 Watt PSU. Maybe 300 Watts peak for a few moments. But definitely not 400W. The older FSP units that are rated for 400 Watts are massively more overbuilt that this.
    • RukyCon
      A Fake Rubycon
      • Jan 2017
      • 816
      Most of the capacitors i was thinking of using were Rubycon YXJ.
      I'm not a expert, I'm just doing my best.
        master hoarder
        • May 2008
        • 12175
        ^ They are cheaper than pretty much anything else on Digikey right now too, so I don't see why not.
        • madyoyo
          Samsung QE55Q65B with shorted D001 diodes on panel board: Worth saving or not
          by madyoyo
          Hi
          I have a Samsung QE55Q65B with a seemingly common problem: it turn off and back on after a few seconds, (sometimes more, and in rare instances works for hours). D001 on the left side of the panel is very hot. I may be able to remove it with a very fine iron, but i don't have the equipment to re-solder such small parts.
          Is there a risk to run the tv without this diodes diodes? And is it worth to pay someone else to replace it. I read many people who ended up with bad lines after trying to remove/replace them, , or the panel failing in another way, so i want to weight...
          12-01-2023, 09:28 AM
        • khalillll
          maxipower 400W Dead power supply repair
          by khalillll
          The power supply was completely dead. Voltage reached the main capacitors, but nothing after that.
          After checking, I replaced the UTC7606D IC to restore the 5VSB.
          I using SDC606U as a replacement, but it didn’t work — possibly the IC itself was faulty.
          Replaced it again with another UTC7606D.
          Result: 5VSB came back, but still nothing — no 12V, 5V, or 3.3V.
          After checking again, I think the issue was with the UTC7520D IC.
          Replaced it with a WT7520.
          Result: PSU fully working again
          09-27-2025, 05:06 AM
        • coasterghost
          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
          by coasterghost
          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
          System Hardware:
          Processor: AMD Ryzen 7 PRO 5850U
          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
          09-08-2025, 10:46 PM
        • Cartel
          FORD 1996 ECU RECAP: Aluminum - Polymer worth bothering?
          by Cartel
          I will be pulling my crown vic ECU and recapping it. 3 in total, 47uf 16v x2 and a 10uf 63v
          I hope they havent puked yet. I was thinking of replacing them with Aluminum - Polymer thru hole caps. probably 47uf 25v and 10uf 80v
          They arent cheap. Anyone have any experience with them? Am I wasing my money on premium caps?
          Nichicon PLV series
          thanks
          06-01-2025, 04:58 AM
        • Francesc V.
          Coil replacement - is it worth it?
          by Francesc V.
          Hi:
          I am trying to repair this ATX SMPS and I realised once I've replaced the 5V IC that also the coil is gone.
          Where (and how) do you look for these parts? same piece or similar that I could try to use it? is it worth it? :-)
          Regards,
          Francesc....
          04-07-2023, 12:52 AM
