Lacie SCSI Separates
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    I have recently acquired a number of these.
    They are AC powered by IEC lead.
    They appear to use two types of open frame PSU
    These are;
    AstecAE-24-1200 and
    Alimeko/Rev UK - believe to be made in house by Lacie (bears a D2 logo).
    The first of the two is found in a SBC SCSI Controller housing.
    It has a rated O/P of +12V @ 1.0A, +5V @ 4.75A
    It is populated with Chemicon LXF in the O/P filter
    The ESR of these read ok but the date code of the PSU is 9648.
    I assume this is 1996 week 48
    As LXF have a purported endurance of over 8k hours and more, I
    believe replaceing these LXS (replacements for LXY)
    or another alternative such as Pana FC is the correct course of
    action.
    Sorry no pics. Any comments?
    The second PSU is a little less well featured as it is used to
    power optical and tape drives and possibly single HDDs.
    The PSU inside of a CD-R unit appears physically, to be ok.
    However, the same PSU in a Sony DDS-2 tape unit has
    the primary cap starting to physically dome.
    The primary has a Siemens 400V 47uF and a REC 47uF 16V.
    The bad Siemens cap has an ESR of 1.2, the REC in the same PSU, 2.3.
    I guess this appears to be a failure area in these, the second PSU.
    Both of these PSU have a date code of 1998.
    The O/P filter for these second type of PSU have Sanyo SE
    (1 of 1000uF 16V, 1 of 470uF 10V) and what appears to be
    Pana CE 85 deg C 100uF 16V (2 of)
    The Sanyo ES have ok ESR (cannot find the datasheet) and
    the Panas are about half an ohm or so.
    Q - Replace with better series such as Pana FC?
    Your insight apprecaited
    Thx
  • JEWilson
    • Sep 2007
    • 369
    Re: Lacie SCSI Separates
    Edit
    Note : LXF have been superseded by LXY not LXS
    • linuxguru
      • Apr 2005
      • 1564
      If you have to replace the LXFs, replace them with LXFs. They rarely fail, if ever. 0.5 ohm is about par for the course for a general-purpose 85c Panasonic M in the 100 uF range - there's nothing wrong with them, but you can safely substitute them with FCs.
      • jpdoe
        • May 2007
        • 237
        I've tracked down the manufacturer of those REC capacitors, since one of their series are on sale locally, and I wanted to see their specs.
        The logo can be read as TEC or REC, but is actually an stylized TREC, since the manufacturer is TRANSCEND ELECTROLYTIC CO.,LTD ( http://www.trec-con.com/ )
        Too bad the ones I find locally are general purpose (GR series)
        • JEWilson
          • Sep 2007
          • 369
          Thanks for the input
          Does anyone have datasheets for Sanyo SE and Chemicon LXF pls?
          Thx
          • JEWilson
            • Sep 2007
            • 369
            Just opened another of these enclosures with a Sony SDT-9000 in it.
            This does not have an Alimeko like two others, it has a Hitron HVI25-21.
            This is a 25W PSU with 2A on the +5/+12V rails (as is stated).
            It is populated with FuhYin FHR caps eveywhere.
            Caps appear ok but straight to garbage anyway!
            From the PSU date code 9945, this is a more modern PSU for these
            enclosures than the Alimeko.
            I do not know how Hitron PSU rate quality wise.
            However, I have a relatively more recent enclosure on the way
            with a SONY AIT tape drive in it.
            Should prove to be interesting how the R & D budget has been
            spent with this item as compared to the others.
            Appreciate any insight here.
            Thx
