FSP Epsilon 1010w Worth recapping?
  • mikay786
    • Aug 2014
    • 765
    Got this PSU with obvious bulging caps from a semi dead first gen i7 rig.
    Rest of the rig appears fine, was just going to swap PSU's but now contemplating just recapping the FSP unit as only looks like a handful of caps and the PSU isn't blowing fuses or owt, its just pulsating at the minute.
    Motherboard lights up and goes off constantly, so reckon with a recap should be good.
    I know they are not top tier PSUs but pretty decent. So worth the effort and cost of a few bucks for caps?
    • 31161
    Re: FSP Epsilon 1010w Worth recapping?
    FSP are worthy of a recap.
    • mikay786
      • Aug 2014
      • 765
      Panasonic FR series do the job?
        • 31161
        all i bother using.
        unless they are too big to fit - then FK series are reduced diameter.
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3264
          • Singapore
          yupp, fsp is one of the few companies that dont bullshit on their power ratings. imagine that! a company that is actually honest!! if they say it'll give u 1010w, u will get 1010w out of the unit!
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Best might be to check the specs on the original caps and buy ones with very similar ESR and ripple.
            Otherwise you risk having oscillations in the PSU.
            (Not saying the FR's wont work, just that you should check how close they are to the current caps).
            • mikay786
              • Aug 2014
              • 765
              Horrible layout, caps are literally crammed in there, some badly squashed and at weird angles. Not impressed
              4 x 470uf 16v - 6mm / 6.3mm (CapXon GF)
              2200uf 16v - 10mm (CapXon LZ)
              2 x 2200uf 6.3v - 8mm (CapXon KF)
              4 x 1000uf 16v - 8mm (CapXon KF)
              100uf 25v - 5mm (CapXon KM)
              22uf 50v - 5mm (Teapo SEK)
              47uf 25v - 5mm (Teapo SEK)
              2.2uf 50v - 4mm (Teapo S5)
              • Khron
                • Sep 2006
                • 1350
                • Finland
                You forgot to add, some really non-standard can sizes / values, especially that group of 6.3x20mm(?) caps right on the edge of the board
                I've got two of these that i got almost for free a few years ago. If memory serves, one kept blowing PFC fets, and the other i hadn't / haven't even gotten around to opening up
                Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
                  • 31161
                  4 x 470uf 16v - 6mm / 6.3mm (CapXon)
                  2200uf 16v - 10mm (CapXon)
                  2 x 2200uf 6.3v - 8mm (CapXon)
                  4 x 1000uf 16v - 8mm (CapXon)
                  100uf 25v - 5mm (CapXon)
                  22uf 50v - 5mm (Teapo)
                  47uf 25v - 5mm (Teapo)
                  2.2uf 50v - 4mm (CapXon)
                  you need the series as well as brand!
                  • mikay786
                    • Aug 2014
                    • 765
                    • mikay786
                      • Aug 2014
                      • 765
                      cant seem to fiund the correct size for some of these caps, for example the data sheet for GF series above. 16v table only seem to have 8x16 and 10x12.5 for the 470uf caps?
                      Whilst the caps are 6.3mm x 20mm
                      • mikay786
                        • Aug 2014
                        • 765
                        Could it mean some of these caps are fake capxon if the data sheet doesn't have the same size?
                        For example]
                        2200uf 6.3v KF Series - 8mm x 25mm
                        On data sheet the above caps only come in 10mm?
                          • 31161
                          custom ordered parts.
                          • Khron
                            • Sep 2006
                            • 1350
                            • Finland
                            As i was saying...
                            I believe i juuuust managed to shoehorn some 8mm dia ones into that first one i had started working on, but i'd have to dig it out to confirm. Either way, even those stock custom 6.3mm ones were a real tight fit, crammed in-between all those wires.
                            http://www.xbitlabs.com/misc/picture...up/3p3.jpg&1=1
                            http://www.hardocp.com/images/articl...38i_3_15_l.jpg
                            • mikay786
                              • Aug 2014
                              • 765
                              So im going to have to go by the nearest size.
                              so for the
                              2 x 2200uf 6.3v - 8mm (CapXon KF) = 1470 ripple and 0.095 impedance
                              with
                              2 x 2200uf 6.3v - 10mm (Pansonic FC) = 1440 ripple and 0.045 impedance
                              https://cdn.badcaps-static.com/pdfs/...bd3de58c23.pdf
                              Is that close enough if it fits size wise? First time bothering with ripple / impedence so just want to make sure im on the right track.
                              • mikay786
                                • Aug 2014
                                • 765
                                Originally posted by Khron
                                As i was saying...
                                Yea its a pain. Is it alright reuse the old caps that are measuring ok?
                                only 3 caps are dead which are the 2200uf 6.3v and 16v ones so could just replace them?
                                • Khron
                                  • Sep 2006
                                  • 1350
                                  • Finland
                                  You could, but then you'd also be damn near certain that (some of) the other C(r)apXons *will* die on you sooner or later. My vote's on "sooner"
                                  • PeteS in CA
                                    • Aug 2005
                                    • 3581
                                    • USA, Unsure of Planet
                                    so for the
                                    with
                                    Nichicom PM or PJ series are closer matches on impedance, PM being the closer. Having less than half the impedance of the original could cause stability problems.
                                    PeteS in CA
                                    • mikay786
                                      • Aug 2014
                                      • 765
                                      Replaced what caps I could within reason, and reused the 470uf ones as physically nothing else will fit. Not worth trying to get something similar as the value of the psu is not worth the expense and effort of trying to obtain them.
                                      Anyhow put back together and seems to be working on my psu tester. Aside from measuring dc outputs on the 12v, 7v and 5v rails and thing else I can measure before putting back in PC to make sure it's safe?
                                      • Khron
                                        • Sep 2006
                                        • 1350
                                        • Finland
                                        By "7v rail" i assume you mean "3.3v" rail, right?
                                        • mrmazda
                                          TR2 Thermaltake W0070RU XP550 NP - worth recapping?
                                          by mrmazda
                                          Only two search hits here, one casually mentioning lower/middle calibre many many moons ago, not terribly helpful, and the other, simply exposure to it, and neither included the RU suffix. Is this a design worth recapping to keep a 10-15 year old PC operational?
                                          I replaced the obviously bad Ltec LZP 2200uF 16V and the obviously bad pair of CapXon GS 18x40 620uF 200V with Nichicon 22x50 UPT. It lights up my digital PS tester with suitable voltages, but it emits a screechy squeal that just drowns out the two 80mm fans. It probably would only very slightly annoy installed in a PC in...
                                          04-11-2020, 08:13 PM
                                        • AJ847.63e
                                          Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                                          by AJ847.63e
                                          Hi Folks,
                                          Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                                          I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                                          The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                                          05-06-2025, 10:37 PM
                                        • proxneo
                                          Recapping Sony ICF-SW55 - verifying cap values
                                          by proxneo
                                          Dear reader
                                          I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                                          At the moment, I have selected replacements based on the following list of values:
                                          3 x 470uF 10VDC
                                          3 x 4.7uF 35VDC
                                          4 x 47uF 50VDC
                                          8 x 22uF 6.3 VDC
                                          1 x 220uF 6.3VDC
                                          5 x 100uF 6.3VDC
                                          Which...
                                          06-21-2023, 12:38 AM
                                        • madyoyo
                                          Samsung QE55Q65B with shorted D001 diodes on panel board: Worth saving or not
                                          by madyoyo
                                          Hi
                                          I have a Samsung QE55Q65B with a seemingly common problem: it turn off and back on after a few seconds, (sometimes more, and in rare instances works for hours). D001 on the left side of the panel is very hot. I may be able to remove it with a very fine iron, but i don't have the equipment to re-solder such small parts.
                                          Is there a risk to run the tv without this diodes diodes? And is it worth to pay someone else to replace it. I read many people who ended up with bad lines after trying to remove/replace them, , or the panel failing in another way, so i want to weight...
                                          12-01-2023, 09:28 AM
                                        • JoelJ
                                          Ampeg PF-350 bass amplifier head repair
                                          by JoelJ
                                          Hello everyone!
                                          I recently bought a broken Ampeg Portaflex PF-350 bass amplifier head in unknown condition. As it turns out, it's completely dead. Tried powering it on with the dim bulb tester, dead short.
                                          I have attached the schematic below.
                                          What I found:
                                          TH1 is cracked visibly but measures 6 ohms. Will replace it but should be okay for testing for now.
                                          Either Q1 or Q2 was dead shorted. Don't remember which one but one of them. Both are FQPF12N60C. I replaced both with SiHP18N50C to test as I had these on hand. They are the same package, pinout, mosfet type....
                                          09-09-2025, 08:37 AM
