I recently won (on trademe) some network equipment (and other things, but that's another story) from an office cleanout
Included was a nice 24-port switch - a Micronet SP624E v3.....
...Of course I wouldn't be posting this if it worked, plug it in and it just cycles power repeatedly and PSU goes 'tick-tick-tick' in time with the lights all flashing.
It's a Seasonic SSF-0252-1 which has two outputs, 3.3v and 5v @ 5A and 1A respectively
I tried disconnecting the PSU, and it still ticks and the voltages go up and down between about 1.2v and 2.2v
I read this can happen because there is no load, the output is going too high and the controller is shutting it down because of the overvolt protection. But then it still does it when plugged into the main board (which seems like it wants to work as all the lights come on) so I suspect the PSU may be faulty.
I think the insides are probably a generic design which is rebranded for different companies because the PSU looks identical to the one mentioned here: https://www.badcaps.net/forum/showthread.php?t=5816 and it's the same thing (24 port switch)
Except in my case the PSU has Rubycons which aren't leaking
Anyone seen one of these PSU before? know anything about them (do they need at least some kind of load to work properly?)
Also, the main board is full of Canicon and Suncap low ESR, one of which was leaking. I replaced it with another piece of junk (starts with T) from a scrap motherboard, but the problem still remained (yeah I know, not a great idea)
And that comes to the other question, if I get this working, I'd like it to keep working. I want to replace all the caps because they're obviously junk - what would be good? (remember I'm in NZ)
