ATX PSU fan ?
  • bianchi77
    • Jun 2016
    • 1121
    ATX PSU fan ?
    Guys,
    I got one ATX PSU, suddenly its fan is off...
    It's it normal if temperature is cold ...or it must be on always ?
    Current temperature surrounding now is about 10 degree
    • 31058
    Re: ATX PSU fan ?
    make & model would help.
    there are only a few that completely stop the fan.
    • bianchi77
      • Jun 2016
      • 1121
      Re: ATX PSU fan ?
      Macron Power
      Model MPT-301
      Low Noise Temperature Controller
        • 31058
        Re: ATX PSU fan ?
        no experience of those.
        others will know.
        probably a dead fan though.
        • bianchi77
          • Jun 2016
          • 1121
          Re: ATX PSU fan ?
          Ok, I'll check the fan and will replace it if broken...thanks
          • bianchi77
            • Jun 2016
            • 1121
            Re: ATX PSU fan ?
            I've tested the fan, it's working perfectly outside the circuit....
            could it be something else ?
            The PCB code :
            LT-20Z 0340..
            • bianchi77
              • Jun 2016
              • 1121
              Re: ATX PSU fan ?
              following the example circuit....could be the failure of Q8 transistor causing the fan fail ??
              • diif
                • Feb 2014
                • 6978
                • England
                Re: ATX PSU fan ?
                Originally posted by bianchi77
                Macron Power
                Model MPT-301
                To me the title says it all. Low noise, perhaps it achieves this by not using the fan when it's not required ?
                Warm up the PSU with a hair dryer and see if the fan spins up.
                • bianchi77
                  • Jun 2016
                  • 1121
                  Re: ATX PSU fan ?
                  I got no idea, but I put diode with 12V and fan..and it always on now...only abit noisy...fan at full speed...but that's allright...it's on and making the system cooler...that's it..
                    master hoarder
                    • May 2008
                    • 12175
                    Re: ATX PSU fan ?
                    Macron Power
                    Model MPT-301
                    Does it look somewhat similar to this:
                    https://www.badcaps.net/forum/showpo...postcount=2230
                    If yes, I don't think the low temperature should cause the fan to stop. This is a really old PSU - way before the days of silent computing, so the fan should run.
                    That said, my MPT-301 came with a completely seized fan, so maybe check yours as well, especially if the PSU is very dusty or if you have the same Superred fan as me.
                    I do NOT advise you continue to run the PSU like that. IIRC, the MPT-301 and MPT-401 have their fans' negative wire connected to the -5V rail, so you may be running that fan on close to 17V! At that voltage, the fan will pickup dust pretty quickly and its bearings will fail sooner rather than later.
                    This PSU has a fan controller that works very well, so FIX IT! Just check the fan output transistor. Better yet, warm up the PSU with a hair dryer as diif suggested, and see if the fan spins. Maybe the cold temperature really is causing the fan controller to turn OFF the fan. I never tested mine at such low temperature, so I don't know for sure.
                    Other than that, this is a great solid PSU. Just make sure to recap it, especially if you have "GL" or "CS" brand caps. Fuhjyyu isn't any good either, but they are still better than the aforementioned brands. Also, beware of conductive tan/brown glue - if you see any near or on the primary side, remove as much of it as possible. The conductive glue could also be the reason why the fan is not running on your PSU. If you see any globs that have turned brown, remove them.
                    • bianchi77
                      • Jun 2016
                      • 1121
                      Re: ATX PSU fan ?
                      nope I put the fan on ground and +12V with diode ....so less than 12V ...
                      I have closed the lid already....it's the same with the photo on the link...
                      I'm not using a port from fan...soldered myself to ground and 12V...so far it's running perfect....soak test for 6 hours non stop already...
                      I know it has fan controller...may be later I'll find out what's wrong with it...
                        master hoarder
                        • May 2008
                        • 12175
                        Re: ATX PSU fan ?
                        Okay, but definitely recap it if you haven't done so already!
                        • bianchi77
                          • Jun 2016
                          • 1121
                          Re: ATX PSU fan ?
                          Yes I have recapped it...thanks
                          • Hondaman
                            Cold temperature battery damage?
                            by Hondaman
                            A couple of evenings ago, my cell phone spent 6-8 hours on the floor of my car, which was parked on the driveway. Probably at or below 0 Celsius. When I took the phone inside, it was turned off, and the battery was at 0 percent (Galaxy S10 Plus). I charged it (wirelessly) without letting it warm up (yes, I know that was probably a mistake -- I probably should have put the phone onto an electric blanket I have).
                            Now, when the battery reaches something like 72 percent or 75 percent, it charges normally. Below that point, it takes 90 minutes to add 10 percent to the phone's battery charge....
                            01-05-2025, 05:22 AM
                            Surface Mount Fuses Fundamentals Datasheet
                            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                            10-07-2024, 06:07 AM
                          • Mirenia
                            Acer Helios 500 (PH517-51) - unexpected reboots when laptop is warm (cold solder joint issue?)
                            by Mirenia
                            got an Acer Helios 500 Laptop (PH517-51) for diagnosing with a strange issue:
                            The laptop runs for a while (1-2 hours, sometimes less) and then suddenly shuts completely off, like someone pulled the power cord and restarts immediately after on its own.
                            If this happened once, then the laptop only runs for a few minutes until restart.
                            This happens regardless while staying in windows or uefi or in a linux environment.
                            At first I thought of a normal overheating issue, but as I monitored temps with HWInfo64, nothing seems very hot.
                            01-05-2025, 05:15 PM
                          • Rudolfl
                            Lenov Yoga C740-14IML laptop freezes
                            by Rudolfl
                            I am really lost on this one. Lenovo Yoga C740-14IML. Running W11. Machine freezes intermittently. It may work for hours, then suddenly freeze. Or it may freeze as soon as it starts and gets to lock screen.
                            Now, what was checked:
                            1. BIOS and all drivers are up to date. W11 was re-installed. No additional software is running. Naturally, no viruses, as it is a fresh install
                            2. RAM test passed with memtest86
                            3. SSD is tested and reports healthy status. It is a Samsung M2 SSD MZVLB5512HBJQ. Unfortunately, Samsung "magician" software is not supporting...
                            02-23-2024, 06:52 AM
                          • asdas09
                            Temperature to remove chips from motherboard
                            by asdas09
                            What temperature with the heat gun should be use to remove large and small chips from the laptop and mobilephones motherboard? My problem is that the chips not easily remove from the motherboard, example 380°C degrees. I don't know if there is a difference with the devices that the temperature is not stable with them even it shows the right temperature, what should it be? I don't know if I should use higher temperature but the risk of destroying other components?
                            I have device Sugon 202. I'm used also normal flux and rosin flux.
                            09-12-2023, 12:44 AM
