X-Power 600-TD again
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    Albeit a separate thread is open in respect of an X-Power 700-TD
    see further https://www.badcaps.net/forum/showthread.php?t=5575
    This is a 600W model
    Rec'd this PSU dead
    Fuse gone
    Replaced fuse and blew again
    Found 1 of a pair of Toshiba 2SK2611 in primary s/c
    Replaced and replaced again, the T5.0A 250V fuse
    PSU now starts up and the go/no-go tester tells
    me all the rails are within regulation.
    PSU exhibits non-start behaviour when I try to apply a minimal load
    such as HDDs. The fans will spin and then stop.
    Suspect as with the observations in the 700-TD post this
    may be down to the WellTrend IC, its a WT751002 as
    this may be a protection issue.
    Any comments?
  • capamatic
    • Apr 2006
    • 33
    Re: X-Power 600-TD again
    Don`t know if the 600TD has the same riser-board as my 700TW, but the protection chip is similar.
    Anyway, have just ESR`d the two Teapo ESK caps on it - 100uf 25V.
    One of them is 0.5 Ohm, the other 1.1 Ohm.
    I suppose these are supply decoupling caps for the chips but are general purpose and may be causing some supply instability, enough to cause no-start ?
    I`ve not yet changed them so can`t comment on a fix, but am hopeful.
    Seems strange to use a GP Cap on a major chip, albeit 105C.
    Worth testing just to discount,
    BTW, thanks for your help thus far with my prob.
    • i4004
      • Oct 2006
      • 2029
      http://pdf1.alldatasheet.com/datashe...TC/WT7510.html
      "The Over Voltage Detector (OVD) monitors 3.3V, 5V, 12V input voltage level. The Under Voltage
      Detector (UVD) monitors 3.3V, 5V input voltage level. When OVD or UVD detect the fault voltage level,
      the FPL_N is latched HIGH and PGO go low.
      The latch can be reset by PDON_N goo HIGH. There is 2.4
      ms delay time for PDON_N turn off FPL_N.
      When OVD and UVD detect the right voltage level, the power good output (PGO) will be issue."
      so check fpl_n and pgo to see if it's latched to protection.
      if it is, it could be output caps, or the chip itself is malfunctioning.
      namely perhaps it thinks something is wrong, but it's not.
      checking the voltages it monitors should establish that.
      these would be vcc(supply and 12v monitor), v33 and v5.
      (according to the sheet i linked...you have 02 on the end, so perhaps it's different layout....)
      it'll be interesting to see if these are external components flaws, or chips themselves.
      my guess is there's something fishy with these chips, but for your sake let's hope it's not.
      here's another datasheet that can probably be helpfull...
      http://www.eserviceinfo.com/download...d_WT7514L.html
      • JEWilson
        • Sep 2007
        • 369
        The 700-TD has a daughter pcb with the WellTrend on it.
        The 600-TD does not. The IC is on the main PSU.
        From the datasheet for the WT7510, it does not have
        current protection unlike the model in the 700-TD.
        Prior to replacing the MOSFETs, I tested the ESR of the
        O/P lytics, these are all Teapo and appear good with my
        ESR meter.
        As a matter of course, I replaced most of the small caps
        with better series such as Nichicon YXF, Pana FC and NHG.
        This is something I do with all of these 600-TDs as a
        pre-emptive measure.
        see prior post and suscon decouples Tiny Switch
        https://www.badcaps.net/forum/showth...hlight=X-power
        I will require to test the WellTrend voltage comparator WT7510
        with multimeter to determine voltage conditions.
        Separately, if the PSU can only handle minimal load, does
        this point to a failure in the secondary with the
        rectifier diode(s) or is it more likely to be a control issue?
        • JEWilson
          • Sep 2007
          • 369
          Removed secondary and tested the schottky power
          rectifier diodes. All appear in good condition.
          As I had the HS removed, found one end of a diode
          leg discoloured. This was under the arc of the largest
          inductor on what appears to be, in the first instance,
          the -12V rail. Checked solder side (again) and
          found at this device, the beginnings of a cold joint.
          Took in cct readings and the diode read both ways.
          Removed the device with some difficulty and
          found it in two pieces once removed.
          I suspect the device had obviously failed.
          As a resullt getting the part number will be tricky.
          From what I can discern, the part ends with R206
          So this may be a 2.0A fast recovery diode (likely).
          Any help appreciated. Thx
          • i4004
            • Oct 2006
            • 2029
            i think that's non-critical.
            see what other psus are using there.
            • capamatic
              • Apr 2006
              • 33
              Any update on the 600 TD ?
              Was it the diode ? Did you manage to test the voltages `round the Welltrend ?
              I`ve pulled the 700 TW apart, everything tests OK. I`m convinced these Welltrend devices are faulty. Only course of action is to hard-power it on. Provided the output voltages are within regulation, then this would seal it.
              • JEWilson
                • Sep 2007
                • 369
                Well,
                I replaced the diode but the problem persists with this
                PSU as soon as you attach a load across it.
                I tried one HDD as a load and the supply immediately
                shuts down
                It does come back up after a while but if you apply a
                load again it will shut itself down.
                Will have to start getting some readings as intended
                in respect of the protection cct.
                • i4004
                  • Oct 2006
                  • 2029
                  adapting it to work with some other ic would be too problematic, i think, so all you can do is try with known good ic of same type.
                  • JEWilson
                    • Sep 2007
                    • 369
                    Just got round to looking at the WelTrend WT7510
                    Vcc, pin 7 reads 11.48V with no load on the PSU,
                    just the go/no-go tester across the 24 pin ATX
                    connector and both of the +12V rails.
                    Checked +12V and +5V at the PSU O/P, reads ok
                    The voltages are within ATX regualtion.
                    When I place one HDD across the PSU and have
                    the no-go tester as above, pin 8 of the WT7510
                    gets pulled low consistent with a fault condition.
                    I have no information on the possible supply
                    variations for Vcc on the WT7510, it is a bit low.
                    I have checked the caps of the O/P rails and these
                    all have good ESR. If a cap had s/c, it would
                    have been obvious from the ESR tester.
                    This may be a faulty WT7510, I will require to
                    obtain one of these or an equivalent and try again
                    • i4004
                      • Oct 2006
                      • 2029
                      it would?
                      how do you differentiate low ohms of esr vs. low ohms of short circuit?
                      you're presuming it has to be precisely 0ohm s.c.?
                      why?
                      • capamatic
                        • Apr 2006
                        • 33
                        If the WT7510 is anything like most others in the series, then VCC can be as low as 4V.
                        The 7510 is a hard datasheet to find, beyond the 1-pager that is.
                        The WT7514 has a max VCC of 5.5V
                        Keep us posted.
                        • capamatic
                          • Apr 2006
                          • 33
                          Perhaps you could monitor pin 5 and 6 (V33 and V5 respectively) before a load is applied , then after.
                          I was thinking of removing the IC from the 700-TW, and breadboarding it. If I fed it with the right voltages, it should indicate wether it`s faulty or not.
                          • JEWilson
                            • Sep 2007
                            • 369
                            I measure the ESR and the resistance at the same time.
                            I use an ESR meter and MMeter to double up when I
                            take the readings.
                            Each meter will read what it finds.
                            This may be an incorrect approach but appears to work
                            for me.
                            • i4004
                              • Oct 2006
                              • 2029
                              actually that seems like ok approach. i though you just relied on esr meter.
                              with your method low ohms of same value on both meters should mean s.c.
                              which means even in-circuit testing should be ok most of the time.
                              if cap is in parallel to coil or primary of trafo then readings on both will be wrong, offcourse.
                              you can have such case on psus where feedback is via trafo.
                              • ifrythings
                                • Apr 2006
                                • 19
                                If the switching MOSFETS were blown did you chaeck the current sensing network to see if anything is damaged? if so it mite be low enough current not to trip OverCurrent unit a small load is applied.
                                If this is a half bridge design check components on the driver transformer area, if it's a signle transistor forward converter, check for a open source resistor on the switching transistors or sensing resistor compator parts.
                                • corrize
                                  A funny fuse story – Lumix LX100 II
                                  by corrize
                                  Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                  I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                  The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                  There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                  And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                  10-19-2023, 09:58 AM
                                • jesterace
                                  Samsung UE46ES8000 Blown fuse but no other signs of short
                                  by jesterace
                                  Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                  09-11-2024, 03:14 PM
                                • jshhh
                                  Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                  by jshhh
                                  Hi guys,
                                  I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                  How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                  Anybody know how to remove this type of fuse?
                                  (The fuse is toward the bottom of the image labeled F2)...
                                  06-17-2025, 01:35 AM
                                • Babbar
                                  by Babbar
                                  04-12-2024, 01:12 AM
                                • drykid
                                  Matsui 175S microwave fuse replacement
                                  by drykid
                                  I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
                                  Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
                                  12-21-2020, 01:15 PM
