Digimess HV30001 repair - 300V 1A bench DC power supply
  • Behemot
    replied
    Re: Digimess HV30001 repair - 300V 1A bench DC power supply
    Originally posted by tom66
    I pulled the bulk mains caps which are rated at 1000uF 200V a piece while replacing the transistors on the heatsink. To little surprise they test considerably below rating at 850uF each, so they are probably 820uF caps.
    That's still within +-20 %. Most even new large-can caps I've ever measured with ESR Micro or UNI-T UT210E always showed lower capacity. No reason to call them fake right away. Usually only Rubycon caps measure close to full.
    replied
    those are shrouded and rated for 250v
    replied
    Originally posted by stj
    You'll find those are typically not rated to 300VDC, more likely something around 60VDC. They'll handle it fine for most cases, but you don't want the exposed conductors anyway when you're dealing with anything around that kind of range. This comes down to insulation ratings in the plastic and the design with the exposed conductors which electronic loads don't generally have.
    The other issue - is handling both extremes of high voltage and high current. You can get 400V rated MOSFETs cheap, but on resistance is pretty bad - like 0.1 ohms is the minimum for anything cheaper than "silly price". And if you want say 30A full load current, you're going to get a load of voltage drop across just one FET. So you need many in parallel. And this increases gate capacitance and control loop design complexity considerably.
    replied
    insulated binding posts?
    http://www.rapidonline.com/rvfm-4mm-30a-terminals-63907
    replied
    It's pretty difficult to find ones that will allow wires to be mated to easily. Anyway, this is a project that will be done after 50 others on the list.
    What I really want is something like this unit with these kinds of jacks on it:
    http://www.ebay.co.uk/itm/Electronic...AAAOSwF1dURMd2
    replied
    4mm shrouded jacks - like on meters?
    some of those are rated 1000v and upto 32A
    http://www.rapidonline.com/4mm-single-pole-connectors
    replied
    JST-VL series connectors.
    20A 600v
    I'm talking about connectors you can easily screw in or use test leads with.
    replied
    20A 600v
    replied
    Originally posted by momaka
    Why would the connectors be a problem? At 1 Amp (actually, not even that with this bench PSU ), I imagine the drop should be small enough not to matter.
    The problem is a high voltage high current design. If I were to design an electronic load I'd want it to have a high input voltage and high input current capability (obviously, not simultaneously, but connectors need be rated for both options.) And then connector choices are more tricky.
    This is something I may end up developing soon, will depend on what turns up in the clearance section of my favourite store.
    replied
    I might end up building one, but 300V is quite a high voltage rating for such a design. Connectors and MOSFET choices get tricky.
    Originally posted by lti
    It's kind of strange to see one Lelon cap. That might be the best cap in the whole power supply.
    That is sad. And would be even more sad if it's a fake Lelon.
    atleast we know which bathroom to use!!
    Good one!
    replied
    I haven't had the guts to check ripple under load yet. I'm waiting for a faulty load unit to show up (rather than building a resistor array.) I might end up building one, but 300V is quite a high voltage rating for such a design. Connectors and MOSFET choices get tricky.
  • japlytic
    replied
    My Tenma 72-10495 (Korad 3005D-2S rebadge) had six fake Rubycon USP series units (rated at 105ºC, whereas genuine units of this series are actually rated at 85ºC), so I yanked them out and replaced them with better quality units.
  • lti
    replied
    The capacitors appear to be a mix of Chemicon, Rubycon and some odd Chinese brand with a Rubycon vent, though the Rubycon caps all look a little off, so they could be fakes.
    From what I can see in the pictures, the "Rubycon" caps are branded Rukycon. I've seen them before. The Chemi-Con caps are almost certainly fake, although they're at least the right color. The fake ones I've seen were always black, no matter what series they claimed to be. It's kind of strange to see one Lelon cap. That might be the best cap in the whole power supply.
    It looks about average for a cheap bench power supply. It definitely isn't worth £500.
    replied
    replied
    Re: Digimess HY30001 repair - 300V 1A bench DC power supply
    we have many ways
    That's what I mean! - Never conforming to a single common standard
    replied
    Lol, you Brits always gotta have everything your own way
    we have many ways
    bayonet cap, 27mm ES, mini-bayonet, 14mm ES.
    my lamp tester is one of these.
    replied
    Later determined it to be a second set of diodes bodged on top - MUR460 devices. They feed the large inductor, which is also connected to the transformer. The diodes are covered in thermal gloop in a vain attempt to thermally couple them to the heatsink.
    Oh wait, I forgot it's a digiMESS... never mind what I was going to say.
    It's different in Europe, in the UK we use Bayonet fittings.
    Lol, you Brits always gotta have everything your own way .
    Success!
    Seems like the full 1 amp isn't available at 300V
    Repair cost was about £15 all in...not bad really.
    Nice, glad to hear you got it working!
    Indeed not bad for the price you paid in parts.
  • Per Hansson
    replied
    Digimess Concept
    What a mess that it ever left the concept stage!
    replied
    Originally posted by budm
    Hi Tom, what kind of lamp socket used in UK and EURO, Edison type like the US?
    It's different in Europe, in the UK we use Bayonet fittings. But for the lamp test I just soldered wires to the bulb because the bulb holder I had was broken.
    replied
  • shamsudeen
    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
    by shamsudeen
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply....
    07-19-2025, 07:14 AM
  • rabsonnjala
    LENOVO IDEAPAD 100 works only on bench power supply
    by rabsonnjala
    Hie I have a Lenovo laptop
    Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
    it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
    below are my readings
    with the original charger only
    JBATT1
    PIN1 0.22V
    PIN2 0.22V
    PIN3 0.45V
    PIN4 0.45V
    PIN5 O.43V
    PIN6 0V
    PIN7 GND
    PIN8...
    11-20-2021, 08:32 AM
  • FrancescoV
    Onkyo HT-R390 no sound output, video output ok
    by FrancescoV
    Good morning everyone,
    I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
    The firmware reported is the following:
    M:1.00/11107BLP
    D:?.??/????????
    O:1.00/11107AL
    The DSP firmware given the question marks seems corrupt.
    On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
    05-11-2025, 02:59 AM
  • CoinCoin88
    Garage door RX unit (Cardin S38C) does not short relay to send opening signal
    by CoinCoin88
    I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
    Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
    09-15-2025, 03:36 AM
