Re: Identifying Part from Schematic
8 or 4 Ohms with 100mV? barely any concern, most speaker protection circuits are not trip until 2V.
Check the offset when first power applied and then test it again after an hour to see how much it drifted off.
0V is perfect.
The circuit being used has no Idling Bias Adj, no Offset ADJ, so it is a cheap way of building thing if they expect all the parts to be perfectly matched, they are using 5% resistors, not hand matched transistors, no real protection for speaker in case of DC dump to the speaker so do not expect too much, it is also sub woofer after all.
You can add offset trimpot circuit or if you wan to get real fancy you can then use Active Servo Offset circuits.
BTW if that C1 DC BLOCKING/COUPLING cap has any leakage resistance that will allow the DC to pass through from the other stage, that will also cause the DC to show at the Output. How equal are the power supplies +/- Voltage?
I though sub 50mv was good, 50-100mv was a concern and anything above 100mv was dangerous?
Yes there is no trim pot, I'll check dm later but is pretty low from memory. Definitely a leaky transistor so still best to sort out.Leave a comment:
0.135V is really nothing to worry about, I guess there is no BALANCE/centering pot the set the 0V at the output, even with the trimpot, it can still drift off the center point.
What does your meter show when you touch the two probes together.Last edited by budm; 02-06-2016, 09:46 PM.Leave a comment:
Found the problem with high DC offset
Changed over quite a few transistors as were fairly cheap including 5 x C1815, 1 x A1015, 2 x A92, which didn't fix it.
There were also 4 x C2240 which hadn't arrived yet so for the time being swapped them around and DC-Offset has dropped to 38mv. So just got to wait for them to arrive and will change the lot. The one that was causing issues was the one near the blown resistor so maybe got damaged or perhaps that's what caused the resistor to blow?Last edited by mikay786; 02-06-2016, 05:51 PM.Leave a comment:
Got the amp all back together and powered up and yay seems to be working. Not connected it to the subwoofers yet.
I measured DC offset and its very high at 135mv, what can be causing this?
It had a full recap including main filter caps.Leave a comment:
Guys is it ok to solder wires from transformer primary to snipped off cables from AC socket?
I've already done it but worrying that may not have been the best way and should have removed old wires and soldering the primary wires direct to the AC socket terminals. I did heat shrink the soldered cables and have wrapped it all up with insulation tape.Leave a comment:
Other one had wires, 15mm should be fine.
On one it's connected from fuse to one of the ac socket pins and the other between ground and Earth on the chassis. Why would you need a cap between ground pin and chassis?Leave a comment:
They are not bad but when I removed old transformer I cut the leads a bit too short so not enough room to solder back in.
So the one I linked to is fine then?Leave a comment:
Quick question, is this a regular film cap or a suppression film cap?
Looking to buy this to replace - http://uk.farnell.com/epcos/b32912a3...rad/dp/2469104 which is a suppression one.Last edited by mikay786; 01-29-2016, 08:29 AM.Leave a comment:
I told them what you said so they had me send in the old transformer and they reverse engineered it to original spec. I've got the replacement in a couple of days ago so will get it fitted as soon as I get time. Will need some help when reinstalling as the colours don't match on new transformer!Leave a comment:
@55V there is not much room for error, especially if the line Voltage goes up, caps are only rated at 80VDC (55V *1.414 = about 78Vdc) so the circuit probably not designed for Voltage that high.
I would use 40V-0-40V.Leave a comment:
360w RMS
Uses 2 x 12" Drivers, class A-B Amplifer
Will it being overpowered be harmful, or can we just class it as having room to spare?Leave a comment:
https://www.badcaps.net/forum/showpo...56&postcount=9
I still have doubt that it should be 55V, and 55V*8A*2 will be much higher than 600VA.
BTW, what is the output rating of this sub woofer?Last edited by budm; 12-21-2015, 11:48 AM.Leave a comment:
So just spoke to a few transformer places and one saying roughly around £150 for a rewind on a laminated unit.
The 2nd place I called (http://www.jmstransformers.co.uk/pages/rewinds.php) are saying they can build a new 600va one for around £90 and a rewind wouldn't be much cheaper than a new one. I'm ok to spend upto a £100 so that sounds ok to me?
He wants me to send over specs and photos
600VA Shielded Transformer
Dual Primary (4 cables (1 split with thermal fuse) (115-230v)
6 Output Cables
2 x 55ac (8A)
2 x 12vc (2A)
2 x GND
Is that ok for specs, or anything I'm missing that they would require?Leave a comment:
Yes. But you should try to locate the original one first, I will not use two transformers in customer set or sell it using two transformers.Leave a comment:
So will that be for two seperate transformers?Leave a comment:
The smaller transformer 12-0-12 (24V center tap) 2 A will be fine.
The larger one 40-0-40, 7~8A will be OK. 40V will give DCV on the filter cap about 56VDC (40V * 1.414), in case if the line Voltage goes up by 20%, the Voltage on the cap will be about 67V (48V *1.414) , the filter cap is rated at 80V so you will still have some head room left.Leave a comment:
I'll check for you tommorrow Paul.
What options do I have for this transformer, I'm willing to put £100 towards a transformer.
Is a repair feasible, professional rewind?Leave a comment:
by Steph.henHi all, a newby question about a bridge rectifier I'm trying to identify.
I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?... -
by mpn78Hello
My Fujitsu Esprimo Q556 motherboards blew up. At least fuse, bridge rectifier and capacitor got damaged. I have changed fuse and bridge rectifier (DF1508S), but I don't know what capacitor it is (picture). I know that capacitors size is 47nF, but I don't know other specs for it. Can you help me to choose right capacitor for my motherboard?
There is 240V AC on input side of bridge rectifier and 340V DC as output on capasitors side.
Thanks.... -
by EasyGoing1I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier... -
I’m working on a Dewalt DCR020 jobsite radio that won’t power on.
So far, I’ve checked the following:- The mains is reaching the transformer
- Transformer outputs ~15-20 V AC
- Bridge rectifier outputs ~15-20 V DC
- All fuses test OK
- The on/off button signal reaches the PCB connector
Despite this, the unit does not power up at all.
Inside, I’ve identified some of the ICs:- ST7317 (appears to be an LCD driver, not the main MCU)
- LM2937L (voltage regulator)Not putting out power, 0.5V on the input
- Markings like FS1235, unknown IC
- Board number:
30 Photos-
by mikkele86hello.
I have two power amplifiers, both having their IGBT blown on the PSU.
The original mounted IGBT where marked with IRGB20B60PD1PbF and the gate driver is a IR2156STRPBF.
I looked at mouser and digikey and could not find any available IRGB20B60PD1PbF and somehow ended up using a Bourns BIDW20N60T.
I replaced the gate driver, the gate resistor and both IGBT. But as soon power is turned on, both IGBT shorts out completely (gate, emitter, collector) and the fuse on the AC line gets killed.
So I though i missed a capacitor or diode. I removed... - Loading...
