Identifying Part from Schematic
  • paulstef
    • Dec 2013
    • 724
    Re: Identifying Part from Schematic
    Originally posted by mikay786
    tested the filter caps and they seem fine, kinda of torn the transformer apart now !! well just the outer layers to see if there was a short up top.
    Well another lesson for the future, ill see if I can put it back together later and tried without connecting to switch. Erm would I just wire directly to the socket bypassing the voltage selector?
    I would probably disconnect the transformer completely and measure resistance of primary first before continuing to blow up fuses...
    But from what you describe it really seems to be your transformer. I think I never had a faulty low frequency transformer
      • 31304
      you could just put a 200v 25a rectifier in knowing it's over-rated.
      got a foto of the one you have for size comparison?
      btw, shit design - it needs a couple of fuses on the outputs from the rectifier or caps.
      as it is, if you have a shorted output transistor it will overload everything until the mains fuse blows - or something else does!
      • paulstef
        • Dec 2013
        • 724
        I thought he had the secondary disconnected from the board...
        • mikay786
          • Aug 2014
          • 765
          Yep disconnected output side so just transformer on its own
          • mikay786
            • Aug 2014
            • 765
            I put in a 400v 25a rectifier, then found out I have a dead transformer. Lesson is always test transformer before worrying about and spending money on things further down the line.
            • mikay786
              • Aug 2014
              • 765
              This is my 2nd in a month!
                • 31304
                good, based on statistics the rest of us wont see one for a year!
                  If you disconnect the primary winding from the circuit and then check the resistance between the terminals where the primary winding wires of the transformer were connected to, the resistance should show infinite resistance, but more likely you have bad transformer with shorted turn.
                  • mikay786
                    • Aug 2014
                    • 765
                    Have done, on the AC socket it's 0.L on all points. On voltage selector is 0.L on points, aside from 2 which depending on position of switch, so that seems fine.
                    The primary windings on transformer all have resistance with one another.
                    Any idea on a replacement transformer? I'm guessing it's difficult due to dual different output voltages, 55ac and 12vc?
                    Would it be possible to use two seperate transformers? I have plenty of room and can mount another inside chassis.
                    • paulstef
                      • Dec 2013
                      • 724
                      Just out of curiosity, what resistance do you measure? And what fuse did you use?
                      I'd say it's not impossible to use separate transformers, you'd need to find the right wattage...
                      • mikay786
                        • Aug 2014
                        • 765
                        I'll check for you tommorrow Paul.
                        What options do I have for this transformer, I'm willing to put £100 towards a transformer.
                        Is a repair feasible, professional rewind?
                          The smaller transformer 12-0-12 (24V center tap) 2 A will be fine.
                          The larger one 40-0-40, 7~8A will be OK. 40V will give DCV on the filter cap about 56VDC (40V * 1.414), in case if the line Voltage goes up by 20%, the Voltage on the cap will be about 67V (48V *1.414) , the filter cap is rated at 80V so you will still have some head room left.
                          • mikay786
                            • Aug 2014
                            • 765
                            So will that be for two seperate transformers?
                              Yes. But you should try to locate the original one first, I will not use two transformers in customer set or sell it using two transformers.
                              • mikay786
                                • Aug 2014
                                • 765
                                So just spoke to a few transformer places and one saying roughly around £150 for a rewind on a laminated unit.
                                The 2nd place I called (http://www.jmstransformers.co.uk/pages/rewinds.php) are saying they can build a new 600va one for around £90 and a rewind wouldn't be much cheaper than a new one. I'm ok to spend upto a £100 so that sounds ok to me?
                                He wants me to send over specs and photos
                                600VA Shielded Transformer
                                Dual Primary (4 cables (1 split with thermal fuse) (115-230v)
                                6 Output Cables
                                2 x 55ac (8A)
                                2 x 12vc (2A)
                                2 x GND
                                Is that ok for specs, or anything I'm missing that they would require?
                                  https://www.badcaps.net/forum/showpo...56&postcount=9
                                  I still have doubt that it should be 55V, and 55V*8A*2 will be much higher than 600VA.
                                  BTW, what is the output rating of this sub woofer?
                                  • mikay786
                                    • Aug 2014
                                    • 765
                                    360w RMS
                                    Uses 2 x 12" Drivers, class A-B Amplifer
                                    Will it being overpowered be harmful, or can we just class it as having room to spare?
                                      @55V there is not much room for error, especially if the line Voltage goes up, caps are only rated at 80VDC (55V *1.414 = about 78Vdc) so the circuit probably not designed for Voltage that high.
                                      I would use 40V-0-40V.
                                      • mikay786
                                        • Aug 2014
                                        • 765
                                        I told them what you said so they had me send in the old transformer and they reverse engineered it to original spec. I've got the replacement in a couple of days ago so will get it fitted as soon as I get time. Will need some help when reinstalling as the colours don't match on new transformer!
                                        • mikay786
                                          • Aug 2014
                                          • 765
                                          Quick question, is this a regular film cap or a suppression film cap?
                                          Looking to buy this to replace - http://uk.farnell.com/epcos/b32912a3...rad/dp/2469104 which is a suppression one.
                                          • Steph.hen
                                            Bridge rectifier identification part number KPB305G
                                            by Steph.hen
                                            Hi all, a newby question about a bridge rectifier I'm trying to identify.
                                            I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
                                            08-29-2024, 09:52 AM
                                          • mpn78
                                            Fujitsu Q556, What capacitor for bridge rectifier?
                                            by mpn78
                                            Hello
                                            My Fujitsu Esprimo Q556 motherboards blew up. At least fuse, bridge rectifier and capacitor got damaged. I have changed fuse and bridge rectifier (DF1508S), but I don't know what capacitor it is (picture). I know that capacitors size is 47nF, but I don't know other specs for it. Can you help me to choose right capacitor for my motherboard?
                                            There is 240V AC on input side of bridge rectifier and 340V DC as output on capasitors side.
                                            Thanks....
                                            04-05-2022, 12:31 PM
                                          • EasyGoing1
                                            Reading input and output of bridge rectifier on the same scope?
                                            by EasyGoing1
                                            I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
                                            When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
                                            06-26-2022, 12:52 AM
                                          • snipersquad100
                                            Dewalt DCR020 Power Board – No Power, Need Help Identifying ICs / Possible Replacement
                                            by snipersquad100
                                            I’m working on a Dewalt DCR020 jobsite radio that won’t power on.
                                            So far, I’ve checked the following:
                                            • The mains is reaching the transformer
                                            • Transformer outputs ~15-20 V AC
                                            • Bridge rectifier outputs ~15-20 V DC
                                            • All fuses test OK
                                            • The on/off button signal reaches the PCB connector
                                            Despite this, the unit does not power up at all.
                                            Inside, I’ve identified some of the ICs:
                                            • ST7317 (appears to be an LCD driver, not the main MCU)
                                            • LM2937L (voltage regulator)Not putting out power, 0.5V on the input
                                            • Markings like FS1235, unknown IC
                                            • Board number:
                                            09-01-2025, 10:57 AM
                                          • mikkele86
                                            Power amplifier SMPS IGBT keeps blowing - Artcoustic PDA1000
                                            by mikkele86
                                            hello.
                                            I have two power amplifiers, both having their IGBT blown on the PSU.
                                            The original mounted IGBT where marked with IRGB20B60PD1PbF and the gate driver is a IR2156STRPBF.
                                            I looked at mouser and digikey and could not find any available IRGB20B60PD1PbF and somehow ended up using a Bourns BIDW20N60T.
                                            I replaced the gate driver, the gate resistor and both IGBT. But as soon power is turned on, both IGBT shorts out completely (gate, emitter, collector) and the fuse on the AC line gets killed.
                                            So I though i missed a capacitor or diode. I removed...
                                            01-06-2024, 06:45 AM
