Fire in the hole!
  • Wester547
    • Nov 2011
    • 1268
    • USA.
    Re: Fire in the hole!
    Originally posted by momaka
    From what I was told, it is likely a cap issue... inside the flyback (i.e. you can't replace it without replacing the flyback). But the good news is it takes a while for it to break down fully. See this thread:
    https://www.badcaps.net/forum/showth...hlight=D1626HT
    I just find it confounding because I have the flat CRTs so they should be more failure prone. And again, 20,000 hours later (of usage; shelf life wise it's much older of course) and many thousand of cycles later, the first monitor of mine hasn't done it.... that seems to be stretching it even for "slowly" breaking down. When you say a capacitor inside the flyback, do you mean around one of the flyback circuits or do you mean that there's another capacitor inside the flyback itself that's breaking down? Is it electrolytic or something else? Going by that thread, it seems I'd need a whole new flyback.
    EDIT: Why didn't I think of that. Yes, these monitors have flybacks from different companies. One is made in Japan (that's all it says) and the other has some part number I can't find any info on. No wonder one is starting to break down. Also, the UCC SMH in one of them has no plastic cover on the top...
      • 31278
      out of curiosity, is the flyback made by Eldor ??
      those have a VERY bad record in the arcade industry in monitors made by Hantarex.
      how bad? lets just say a monitor more than 5 years old is VERY unlikely to have the original transformer!!
      philips also had a reliability problem wih tv flybacks, but i dont know who was making those.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        how bout a 9v battery and steel wool.
        or what i more commonly carry an 18650 and anything thin metal.
        Originally posted by ben7
        It's possible to start a fire with even less energy than that! Scary isn't it?!
        • silberdrache
          Burnt Hole under IC on MacBook Pro M1 Pro 14"
          by silberdrache
          I'm new to this Forum, so I hope it's the right place for this topic.
          Im a student from germany, and as a hobby I repair electronics. I started microsoldering maybe 1-2 years ago.
          I have a MacBook Pro 14" m1 Pro with 10 Cores and 16/1tb storage. The board Number is 820-02098-A.
          The MacBook has a light water damage. Coffee got spilled over it, but the Mac continued working only the battery didn't charge anymore and when the battery was empty the Mac turned off and doesn't show any sign of life now.
          I opened it up and there were only three drops of coffee...
          11-10-2025, 11:19 AM
        • TortureGarden
          RCBS Chargemaster 1500 scale & powder dispenser
          by TortureGarden
          Good morning all.
          I have an RCBS Chargemaster 1500 combo electronic scale/powder dispenser that I have been using without issue for 15 years or more. I powered her up to do some reloading the other week and the LCD panel backlight & characters lit-up and then immediately, the characters faded-out, leaving just the backlight illuminated. I thought it may have been a one-off so, I tested again (and again...), with the same result.
          I separated the scale from the dispenser and disassembled the scale. Nothing obvious observed that could be causing the issue, caps look...
          02-06-2024, 07:35 PM
        • jczarniak
          JVC Fire TV or any other Android based firmware
          by jczarniak
          Is there available any Android Fire TV ROM backup ( Fire TV Firmware ) which I can download, save on USB stick and then load into the TV ?
          I have got JVC LT-50CF810 Fire TV with firmware not working properly.
          Thank you very much for any support.
          Regards.
          10-18-2023, 01:43 AM
        • 13mh13
          Aluminum SMD caps vs thru hole caps (reliability)
          by 13mh13
          The PCB motor for 1987 Technics SLP-120 CD player has slow spin-up issues. Similar to what another tech in the below video reported.
          https://i.postimg.cc/kGrR6BpZ/image.jpg
          I replaced the three bi-polar 47uF electros but that made no difference. The orig three bi-polar 47uF electros tested okay on my ESR M-tester.
          I have not tested/replaced those alum. SMD electro PCB caps.
          Are Al smd caps are more prone to failure (or degradation) than regular thru-hole electros?
          All the thru hole electros I removed / replaced on this CDP (and most...
          04-05-2024, 07:41 PM
        • spleenharvester
          GRT60-145410 brick PSU, how much of a fire hazard is this thing exactly?
          by spleenharvester
          I bought an Alpicool C20 fridge, which is a 60W compressor fridge that runs on 12V or 24V, which can come from either an AC/DC adapter from mains (240V here in UK) or a car battery. The fridge itself is really good quality, so I was surprised to find the power supply (DC14.5V, 4.1A) pretty questionable. Despite being 240V/1.5A the plug was fitted with a 13A fuse - concerning, but not all that uncommon for imported chinese electronics here. But when I felt how light the brick was I immediately said hell no and transferred the proprietary connector to a MeanWell GS90A12-P1M brick (this supply is...
          07-08-2025, 06:02 PM
