Metrix 803B Oscilloscope power supply issue
    • 31281
    Re: Metrix 803B Oscilloscope power supply issue
    btw, maybe this will be usefull.
    • itsthatidiotagain
      • Dec 2014
      • 39
      Thanks. Where did you find that? It looks very promising, lots of similarities, but also this...
      "(∗) The same SUB-D 25 pin output (at the back of the oscilloscope) is used
      for the RS232 and CENTRONICS interfaces (use an RS232 or CENTRONICS lead
      as required)."
      ... the internal connector on the 803B that I thought might be the serial option is a 14 way inline header, but that probably isn't enough pins for a combined centronics and rs232 port.
      Maybe there are some significant differences betwen OX 8100 and the OX 803B of course, since centronics and GPIB are not offered on the 803B, only serial.
        • 31281
        a microcontroller could use the same pins for either interface.
        it was on a romanian site btw.
        • sydmc
          • Jan 2015
          Hi, was looking for the OX863 schematics but could only find this user manual, seen this post, so maybe it will be of some help with the RS232 output connections. I bought the OX863 on ebay with some issues hoping to repair, can't find the schematics.
          • itsthatidiotagain
            • Dec 2014
            • 39
            Thanks for the link to the manual, it seems to confirm what I suspect, namely that the Metrix scopes all use the same serial protocol, and pinouts.
            What are the issues on your OX863? Also is there a daughter card mounted on J18. Can you share some pictures of the inside of the OX863.
            A fairly complete set of teardown pictures of my OX803B are here.
            https://plus.google.com/u/0/photos/1...81872199591361
              • 31281
              the '863 service manual was being sold for about 20Euro by an italian company, i ran across the site a few days ago.
              • itsthatidiotagain
                • Dec 2014
                • 39
                I found a couple of other links to Metrix user manuals.
                Another couple of copies of the OX 863 user manual.
                https://cdn.badcaps-static.com/pdfs/...3f3f3e5329.pdf
                www.ghvtrading.cz/download.php?fileid=1880
                (both with the same md5sum, so both are the same manual)
                .. and a photocopy of the 8620/8627 manual ..
                http://www.ghvtrading.cz/download.php?fileid=1880
                .. I also connected up a chunk of ribbon cable to J18 and brought it out through the base of the scope, so I can prod around on that connector without much risk to life and limb. I ran out of time, so I can't yet report on the signals on the pins on that header yet, but I hope to probe it with the office Rigol tomorrow.
                I'll also see if I can get some voltage readings from the PSU <-> main board connector to assist others if they need to fix one of these in the future.
                Also of interest are J19 (unpopulated, not sure of its function) J301 (unpopulated, may give access to the analog multiplexer to allow the D to A card to overlay its image to the tube), and the front panel key connector I described previously (also unpopulated on the 803B).
                One other minor issue with my OX 803B, the component checker seems to have a minor defect, it shows a dot, offset from the zero ceter point, rather than a straight line throug the centre of the screen, although sometimes when you tap the front panel it turns in to a line. Looks like a dry joint or cracked resistor or similar. I'll take a look at that later, it is pretty low priority. Ill prod the area of the associated components with an insulated object of some sort, fire the freezer spay on it, that kind of thing.
                • itsthatidiotagain
                  • Dec 2014
                  • 39
                  I also found a programming manual for the OX8040, OX8042, OX8062, OX8050 and OX8100, but I can't remember where I found the original link.
                  I've attached it in case it proves useful to someone in the future.
                  Also there is a slight screwup in the previous post's links, but I only spotted it after the 90 minute edit window had closed.
                  • itsthatidiotagain
                    • Dec 2014
                    • 39
                    What is the fault on your OX 836?
                    • itsthatidiotagain
                      • Dec 2014
                      • 39
                      I had 5 minutes to spare today, to check the signals on J18 this is what I have so far.
                      The colours in the list below are just those of the bit of ribbon cable I used, so they have no particular significance.
                      Code:
                      J18 Pinout - Pin1 at PSU end (same as J19)
                      Pin- Colour - Signal
                      1 - Blue1  -  0V slight periodic ripple (Polled output perhaps???)
                      2 - Purple1 -  0V slight periodic ripple (Polled output perhaps???)
                      3 - Grey1  -  0V slight periodic ripple (Polled output perhaps???)
                      4 - White1  -  0V slight periodic ripple (Polled output perhaps???)
                      5 - Black   -  0V slight periodic ripple (Polled output perhaps???)
                      6 - Brown  -  +12V
                      7 - Red    -  -12V
                      8 - Orange  -  10ms +5V pulses (20ms pk to pk square wave)
                      9 - Yellow  -  0V slight periodic ripple (Polled output perhaps???)
                      10 - Green  -  Ground (Confirmed zero ohms to BNC Earth)
                      11 - Blue2  -  0V but not tied to ground (serial port I/O perhaps???)
                      12 - Purple2 -  0V but not tied to ground (serial port I/O perhaps???)
                      13 - Grey2  -  +5V slight ripple (serial port I/O perhaps???))
                      14 - White2 -  +5V slight ripple (serial port I/O perhaps???))
                      I'll take a closer look at the signals, take a few pictures of the scope traces and probe with the multimeter to see if I can determine which are inputs and outputs when I get more time.
                      Now that i know the serial port protocol and that it can use 3 wires i.e. no hardware handshake and xon/xoff I can then experiment with a TTL level 9600 baud serial signal fed to which ever I think might be the inputs, so see if I can control the front panel.
                      The serial port consists of 5 wires and is described thus...
                      Serial link characteristics
                      Oscilloscope connector : 25-pin cannon plug
                      Cable : five wires (two transmission wires, one ground wire, two
                      control wires)
                      Protocol : RTS
                      Data rate :
                      Data format :9600 bauds
                      8 bits - no parity - 1 bit stop
                      Protection : per EIA RS232C standard
                      .. which may match up with the bottom 5 wires on J19
                      I haven't found any 3V3 signals so far, so I think everything should be 5V TTL
                      Pin 8 is interesting, I presume this is an accurate 50Hz pulse, which is the same frequency as the UK mains, and this might be for blanking sync perhaps for the A/D daughter cards. Pure speculation on my part of course.
                        • 31281
                        trace the signals back to the source.
                        the chip may have a uart, so RX/TX with give you the pinout.
                        • itsthatidiotagain
                          • Dec 2014
                          • 39
                          Tracing back to the source would require me to dismantle the front panel, which I might end up doing, but for the time being I'm trying to avoid doing so.
                          • itsthatidiotagain
                            • Dec 2014
                            • 39
                            Quick update on the pinout of the connectors.
                            Code:
                            Metrix 803B PSU
                            12 pin power connector
                            Although the board has no obvious markings, assume pin 1 is the one with the black stripe.
                            Note: DC ground is tied to main earth, and that for safe operation of the scope it must be earthed.
                            As with most scopes, all scope input BNC connectors therefore have the Ground side tied to mains earth.
                            DC Power connector (J1)
                            Pin 1) -12V Checked on multimeter
                            Pin 2) -5V Checked on multimeter
                            Pin 3) +12V Checked on multimeter
                            Pin 4) +5V 10mS pulses> See Scope trace.
                            Pin 5) +5V Checked on multimeter
                            Pin 6) GND
                            Pin 7) GND
                            Pin 8) ??? Looks like 0V perhaps feedback power good signal to PSU. Needs confirming
                            Pin 9) +120V DC Verified (6 x 2 x 10 V) Scoped Measured at 118.0V on multimeter
                            Pin 10) +180V DC Verified (3.6 x 5 x 10 V) Scoped Measured at 177.7V on multimeter
                            Pin 11) GND
                            Pin 12) +5V regulated checked on multimeter-> Option Card (A/D board) - scoped.
                            Note the +5V on Pin 12 is the same power rail as the +5V on J2 which goes to the option card (Digital (A/D) board in an 8050 etc).
                            2 pin DC Power connector (J2)
                            ===== <--Locking tab
                             1 2
                            Pin 1) GND
                            Pin 2) +5V
                            J18 Pinout - Pin 1 at PSU end.
                            1 - Blue1  -  Floating input???
                            2 - Purple1 -  Floating input???
                            3 - Grey1  -  Floating input???
                            4 - White1 -  Floating input???
                            5 - Black  -  Floating input???
                            6 - Brown  -  +12V
                            7 - Red   -  -12V
                            8 - Orange -  10ms +5V Pulses (20ms pk to pk)
                            9 - Yellow -  Floating input???
                            11 - Blue2  -  Floating input???
                            12 - Purple2 -  Floating input???
                            13 - Grey2  -  +5V (floating input ?)
                            14 - White2 -  +5V (floating input ?)
                            • itsthatidiotagain
                              • Dec 2014
                              • 39
                              I'm trying to figure out what the purpose of Pin 8 is on the PSU board, my best guess is that this is some sort of crowbar protection, but I thought I'd find out if anybody else has any better ideas based on the previous images and the image below.
                              • itsthatidiotagain
                                • Dec 2014
                                • 39
                                For the record, the tube in a large number of these Metrix scoopes is almost certainly..
                                D14-364GY / 123
                                CRT Heerlen BV
                                Made in the Netherlands
                                https://cdn.badcaps-static.com/pdfs/...0274745688.pdf
                                Furthermore, the tube in my OX 803B is most probably very similar (the principal difference being the Phosphor coulour).
                                • daverave56
                                  • Mar 2015
                                  • 16
                                  • united kingdom
                                  #56
                                  i also have a metrix scope that is dead with switch mode power supply problem which has caused me much frustration cause metrix refuse to supply me with a service manual !!!!!!! my model is a metrix ox 8042 but uses a UC 3842 pwm/oscillator chip rather than the TDA 4605 as used in your scope.
                                    • 31281
                                    uc3842 datasheets have lots of example circuits - one is probably similar.
                                    and this thread.
                                    https://www.badcaps.net/forum/showthread.php?t=20675
                                    • daverave56
                                      • Mar 2015
                                      • 16
                                      • united kingdom
                                      #58
                                      i did some voltage tests today in the switch mode power supply with the UC 3842 chip.
                                      Pin 1 - 0v
                                      Pin 2 - 0v
                                      Pin 3 - 0v
                                      Pin 4 - 0.7v
                                      Pin 5 - ground
                                      Pin 6 - 0v
                                      Pin 7 - 13v
                                      Pin 8 - 2v
                                      changed the two tant capacitors with electrolytics and made no difference scope still dead
                                      • Keeze101
                                        • Jun 2015
                                        • Netherlands
                                        #59
                                        Very interesting thread.. I have got an Philips OP400, which is the Metrix803b. The Metrix is a Philips design, manufactured by Metrix. The unit seems to be working, but the vertical measurement is off by about 20%. When I feed a 5V DC signal the scope shows about 4 volts. I get the same offset when I use the onboard testpoint (2.5v/1kHz)
                                        Does anyone know how to calibrate the vertical axis? Timebase is correct.
                                        Cheers,
                                        Kees
                                        • rbarreiros
                                          • Nov 2016
                                          • Portugal
                                          #60
                                          I'm sorry to revive this thread, but I do have an oscilloscope like this one, metrix ox 803b, and it's not powering on, but, not completely dead, makes a sound like a relay trying to close circuit, very fast, continuously, some leds in the panel light up, others blink, no display.
                                          Could it be related to the same PSU issue itsthatidiotagain had ?
                                          Cheers,
                                          Rui
                                          • Soulzink
                                            Samsug washing machine. Power supply DC41-00189a board issue
                                            by Soulzink
                                            I am trying to fix a samsung washinmachine power supply main board.
                                            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                            The power supply board reference is the following: DC41-00189a
                                            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                            04-19-2025, 06:26 AM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • KYBOSH
                                            Eufy Floodlight Cam 2 Pro Dead. Power Supply issue...
                                            by KYBOSH
                                            I have a floodlight-security camera that recently died on me.
                                            its hardwired to 115v po115v outlet. One evening it simply died. After some troubleshooting (ensuring it had power and ensuring the electronics were actually functional by supplying 5v via usb port) i realized the power supply must be the issue. The supply was noticably warm to the touch even though it was not powering anything.
                                            Trying to understand what i was up against i went looking for others with similar issues and anyone who might have attempted a repair. While a few ppl have had the...
                                            07-01-2024, 06:54 AM
                                          • Cookybaby
                                            Samsung UN60ES6500FXZA Power Supply Issue
                                            by Cookybaby
                                            Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                            I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                            Make: Samsung
                                            Model: UN60ES6500FXZA
                                            Power Supply P/N: BN44-00525A
                                            Symptoms: The TV was...
                                            08-20-2023, 12:26 PM
                                          • lp20th
                                            Samsung Plasma TV Power Supply Issue
                                            by lp20th
                                            I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                                            11-28-2023, 10:28 AM
