Kenwood KPS-15 PSU repair
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8882
    Went to work and found a bunch of AM radios off that do the audio recording. Hmmm... that's not good! Looked at the PSU and it was turned on, but dead. Anyway I opened it up and here is the list that went bad in it.
    Fuse 5x20mm 250V AL 6.3A blown to smithereens.
    2x NPN transistors 2SC2625 full short on all 3 legs.
    One of the two 200V 680uF main filter capacitors only had like 10uF!
    While I am at it, I am going to change all capacitors, since the PSU is running 24/7/365.
    I am replacing the 2SC2625's with BUV48A.
    Anyway here is a bonus quick repair:
    After I swapped the PSU out, one of the audio recorders an ALGO 4105 AUXBOX would not want to record anything on the computer even so it was powered through USB A and the lights are on, but nobody home? Turns out that one of the 4 surface mount capacitors had over 10 Ohm ESR. Changed that out and put it back to work this morning. Working fine as kind. These legacy ALGO 4105's are very hard to get. They do run a custom firmware to be able to record audio from a radio. I forgot to snap a picture of the ALGO, but I did snap one from the Kenwood KPS-15.
    • 32055
    i'm not sure why they put a condom on the MOV and then cheaped out with a glass fuse!
    conductive glue everywhere too.
      • 32055
      btw, why are you recording AM? is this more aviation stuff logging airband?
        master hoarder
        • May 2008
        • 12190
        • Fixing stuff
        Heh, CapXon doing CapXon stuff again.
        Seems like they can't even make primary caps properly.
        I've been getting old LCD monitors from the local flea market for the last 2 years, and have noticed that from all of the monitors with failed caps, the only ones where the primary cap was also starting to fail or marginal, was on PSU boards with CapXon.
        They are utter trash, I am convinced now.
        The failed primary cap is probably what took out the BJTs in your PSU.
        Good work getting it fixed. At least it's a simple half-bridge design that can be repaired and not some of the more modern garbage made with unobtanium parts, tiny SMD silicon with cryptic codes, and a "green" design that really only puts more strain on parts (read: APFC.)
        Probably because it's all in a metal case and they (the manufacturer) knew that the chances of that fuse blowing out and somehow continuing to arc over are very low... so they took the chance.
        Hey, at least it's better than control boards in modern washing machines, which often these days don't even bother with a fuse - they just make the live trace extra thin in a special spot to act as a designated "fuse". Now let me tell you how well that works....
        Oh, did you expect me to say something?
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8882
          Our airport always had audio recording. One for the emergency frequency 121.5Mhz, then one for the airports allocated frequency, then the 2 tower phone lines. There original recorders where reel to reel 4 channel with a GPS clock. Then it got digitalized using 4 ALGO 4105 AUXBOX and a computer. I can go back about 6 months worth of recordings. Same thing with the security cams. No, that audio recorder is not on the internet for security reasons. I do know about Liveatc.com and hint our airport is on there too, but that is a private owned upstream using SDR radios and a pie.
          Reason for the AM recording is if something goes wrong and one of these birds has a crash or whatever. Could be also let’s say the tower giving wrong information to the pilot. This way there is no he said / she said.
          The recordings have a precise time stamp, day and time, which channel and the length of the recording.
          I am toying with the idea to replace that PC and the ALGO 4105, but I’d have to come up with something to record all these channels and phone lines.
          Here is something funny, there is actually a separate receiver that is tuned to the main airport channel, that audio is broadcasted to the toilets. Just in case one tower dude sits on the can and someone is radioing in. They also broadcast this before they go and call it “weather related duties”. In plain English : tower dude sits on the shitter.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8882
            I am damn sure that this bad main filter capacitor took out the 2 transistors. After all it is an easy power supply. So it should be 0 problem to fix it with all the parts I ordered. I just don’t want to repair it again, so every capacitor gets replaced.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8882
              The Kenwood KPS-15 is identical to Samlex SEC-1223.
              So I put all the parts in, had it mostly assembled and only got 1.3VDC out of it?
              Dayum! Has to be something that drives the big NPN transistors… disassembled it again and found a blown trace!
              Fixed that and now got 14VDC. Turned that down to 13.8VDC and all is good!
              • DrDos
                Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
                by DrDos
                Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
                08-08-2025, 03:16 AM
              • slimmy182
                Polaroid Snap Touch – Completely dead, board-level repair help needed
                by slimmy182
                Hi everyone! I'm troubleshooting a Polaroid Snap Touch that shows absolutely no signs of life.
                • Battery: 7.4V Li-ion (2S), successfully charges up to 8.37V.
                • USB 5V reaches the motherboard.
                • Some components have approximately 3V present.
                • No screen, backlight, charging indication or response to reset.
                • Not detected by PC via USB.
                • Flash/power switch mechanism inspected and reassembled, no improvement.
                • Battery temperature sensor (NTC) measures approximately 11kΩ.
                I've also tried powering the board using...
                10-19-2026, 06:39 AM
              • Billathome65
                kenwood KA-76 amp resisitor advice
                by Billathome65
                Working through my mess up which burnt out a few things on a kenwood KA-76 amp
                I've got to the point where through the dim bulb the amp relay clicks but im getting no power through the bias pots so I measured these resistors they say 103J so I assume 1kohms?
                But the 2 by the pots read 1.804ohm and the 2 by the output transistor read 567.8 in cercuit i'm assuming these are bad and need replacing?...
                04-11-2026, 09:49 AM
              • freethink
                Kenwood KR-A70 Receiver Balance changes with volume controls?
                by freethink
                I have a Kenwood KR-A70 Receiver on the bench, and the digital volume control is acting very funky. When I adjust the volume, the balance also changes. Volume Up = balance goes Left, Volume Down = balance goes right. Has anybody ran into this issue, or know what the problem might be?
                11-23-2025, 07:53 PM
              • DrDos
                kenwood kr-6030 Mosfets?????
                by DrDos
                Hello everyone, I have decided to try and replace the mosfets in my power amp (the one with relay and left and right sides) on my kenwood kr-6030. I'm trying to get the A side of my speakers working. I have replaced all the caps in the power board and I thought why not change the mosfets. They seem to be working since I have great music coming out of the B side speakers and since I am not an electronic guru (but I am learning) I don't want to make any mistakes. The mosfets I have are listed A913 so I guess 2sa913 and 2sc1913. Can't really find those in mouser or digikey at least with the info...
                09-20-2025, 04:42 PM
