Corsair CX600 power supply issues no power good intermittently all other voltages were good resolved!
  • cheeky2
    • Dec 2012
    • 361
    • uk
    I have this Corsair CX600 power supply that wouldn't always give me the power good signal from the output. So initially looked at the capacitors and output voltages from the power rails which were all good! Which was a little confusing initially so thought to check whether the pfc was working on the unit which it wasn't ramping up to around 380V and was staying constant at around 340V. So looked at the CM6800 ic and it's circuit surrounding it.
    Anyway I discovered that R2 and R3 both 820K 1% resistors were around 750K and 732K which is significantly lower than the 1% tolerance. So I removed both of them to discover they were in tolerance out of circuit, which I came to the conclusion that the glue that was used to place them had become slightly conductive. Initially I just removed one of them to ensure that the meter wasn't being affected by being in circuit. The resistance of the other resistor was constant 750K in circuit with the other one removed! Removed the other resistor and found to again be in tolerance of 820K. I cleaned any residue of the glue off the pcb and they were both put back in place.
    These two resistors plus another through hole resistor (330k) goes from the main 400V on the positive side to the pcb that has the CM6800 ic on it. I was going to remove the small pcb after I had checked the surrounding components, but was lucky to discover these resistors being lower resistance than they should be. I guess the voltage being higher to the pcb meant the cm6800 wasn't being turned on and was triggering the over voltage protection causing the CM6800 to shut down.
    The power unit powers up all the time now so issue resolved.
    With this fault you could go round in circles fortunately I found the issue relatively quickly. So worth bearing in mind if you have the same issues check the resistors R2 and R3.
    Happy repairing
  • cheeky2
    • Dec 2012
    • 361
    • uk
    I should have highlighted the two resistor locations. So see attached image for the location of these resistors. Bear in mind one of them has been removed in this image.
    I will no longer be uploading anything to this site that requires a subscription to download it. Generally I have stopped using this site as a result of this and see other users will go elsewhere!
    • Apoco_ lips
      gigabyte x870i aorus pro ice stuck on dram light, ddr5 power good voltage 0 when ram stick installed
      by Apoco_ lips
      I have a gigabyte x870i board I am attempting to repair. I have a working board as well to reference. The board is stuck on the dram light, wont post and I found the power good pin has 0 volts when powered on with a stick of ram installed. With out the ram it is 3.3v. Another weird issue with the board is when trying to use qflash to update the bios, the qflash light blinks for about 15 seconds then turns off for 30-45 seconds and then turns back on solid for about 3 minutes. My working reference board will flash the qflash led for about 15 seconds, turn off for a few seconds then turn back on...
      06-30-2026, 04:15 PM
    • Ibod
      Corsair cx600 psu & ASRock B450Pro4 mobo wont start
      by Ibod
      HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
      With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
      Not sure where to go from here ?
      Is the PSU at fault or is the mobo causing the problem
      Look forward to any help :-)
      If I plug the 24...
      02-08-2023, 11:00 AM
    • Tesla
      Need recommendations for a good chip-programmer please
      by Tesla
      Well, my account here still works. I still remember those days … replacing the caps to save a motherboard. Back before our current disposable-mentality really took-hold. I’ve looked around at the recent threads … it’s really cool how yall help each other. I’ve still been upgrading and fixing desktops and laptops. Replace a laptop-MB, install a NVMe-SSD, new thermal compound apply, pull a coin-battery to clear-cmos (that kind of thing).
      Now that we apparently have to try to build laptops like phones (solder almost everything to the motherboard) looks like the idea of repairing...
      03-15-2026, 06:39 PM
    • bimole
      Weird behavior on 3.3V rail of a CORSAIR CX600
      by bimole
      A colleague gave me an apparently ill CORSAIR CX600.
      He told me that he heard a banging noise, and smelt the magic smoke.
      After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
      I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
      It's another story on the 3.3V rail...
      I have some devices to test deeply PSUs (scope, AC source, electronic load)...
      02-13-2025, 04:49 AM
    • irepair559
      Ps4 1215a hdmi diode readings good everything good but no pic??
      by irepair559
      PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
      01-05-2023, 12:32 AM
