EVGA supernova 750 G+ missing -12V.
This topic has been answered.
  • technonenehno
    • Nov 2025
    • 31
    • Slovenia
    Hi everyone!
    I have an EVGA supernova 750 G+ that suddenly stopped working. The PSU powers ON , but then immediately powers OFF(can be seen by the fan slowing down and i probed all the power lines with an oscilloscope). All the power lines have their respected values even 5V standby and after initial ON stay on their voltages for a few milliseconds, except for -12V and PG(expected since its missing one line). I used a red circle to indicate where the -12V goes to the output connector but was unable to trace it over the board. Since i didn't find any boardview files or schematics i am kind of stuck. Any help or ideas would be welcome.
    Thanks in advance!
  • Answer selected by technonenehno at 04-16-2026, 04:13 PM.
    technonenehno
    • Nov 2025
    • 31
    • Slovenia
    Hi there, thanks for your help CapLeaker . I have successfully found the issue it was the burnt Schottky diode D16 which shorted the -12V to GND. The pulses were clearly visible on the oscilloscope on the Anode side but it never reached the resistor R62.
    Edit: There was no L7912 responsible for the -12V it was rather on the same coil than the 12V line. I didn't bother bypassing the IC but good to know for the future.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8880
      The power supply is shutting down because of the supervisor IC IN1S429I kicks in protection mode.
      Datasheet here:
      https://www.badcaps.net/forum/troubl...sheet-evga-psu
      You can easily defeat that protection on the supervisor IC and power the PSU up and check all the voltage rails.
      It’s an L7912 that is responsible for the -12v. See in the review below for a similar power supply.
      https://www.tomshardware.com/reviews...-supply-review
      Datasheet for L7912 here:
      https://www.st.com/resource/en/datasheet/l79.pdf
      All in a nutshell, either that regulator doesn’t get any power (open) or something is shorted.
      check each rail against gnd and see if one is shorted. Remember, a linear voltage regulator like that needs a bigger unregulated negative voltage to make regulated -12v. The pinout in the datasheet tells you what pins is GND, input and output. Unfortunately if you got no input, you have to painstakingly trace it back.
      This should be all to get you going. No schematic needed. Good luck!
      • technonenehno
        • Nov 2025
        • 31
        • Slovenia
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8880
          At least you were able to fix it! Good job!
