Eaton 5130 1750VA RT2U UPS Fault
  • Avalonnw
    • Feb 2026
    I've got a failed Eaton 5130 UPS unit that started beeping constantly and got essentially thrown away. Being a curious person I decided that I would like to try and fix it. Well... So far I was unsuccessful. I am hoping to get some help here, where to look and what to try.
    Model: Eaton 5130 1750VA RT2U
    Problem:
    Unit powers on but immediately faults. After startup it performs relay clicks in sequence 5-2-2, lights “Unprotected Load” LED, and emits continuous alarm beeping.
    USB monitoring reports only: “UPS Fault” (no code or details).
    History / Initial Faults Found
    Front fan seized → replaced
    Auxiliary PSU unstable → 12 V rail oscillating between 3–9 V
    Replaced all electrolytic capacitors on auxiliary board (Jamicon low-ESR)
    Batteries new
    Result:
    No change in fault behaviour.
    Current Observations
    Startup relay click (loud) followed by quieter relay sequence (5-2-2)
    Fans now operate normally
    Unit still enters fault immediately after startup
    Measurements / Tests Done
    Thermistor under main transformer wrap measures ~0.8 Ω
    → assumed OK (appears to be temperature sensor for protection circuit)
    No visibly damaged components
    No bulged caps (all replaced anyway)
    No obvious burnt traces or cracked solder joints
    Debug Attempt
    Trying to access internal diagnostics via serial:
    UPS uses RJ-50 (10-pin) serial port next to USB
    Identified:
    one GND pin
    one pin at approx -9 V (assumed RS-232 TX)
    Connected suspected TX + GND to USB-RS232 adapter → no output
    Tried multiple baud rates → no response
    → Unable to determine correct pinout or protocol
    Questions
    Does anyone know correct RJ-50 serial pinout for Eaton 5130?
    Should this model output boot diagnostics over serial?
    Does the 5-2-2 relay click pattern indicate a known fault code?
    Any common failure points in these units besides caps/fans?
    Goal
    Trying to determine whether failure is:
    protection trip condition
    inverter stage fault
    logic board issue
    or something simple I'm overlooking
    Essentially, I am stuck and desperately need help.
  • Agent24
    I see dead caps
    • Oct 2007
    • 5401
    • New Zealand
    • Electronics and computer repair
    Some pictures of the boards etc would be helpful. What ICs are on the thing? Have you checked all diodes, power semiconductors etc for shorts or opens?
    -David VanHorn
    • Avalonnw
      • Feb 2026
      Thanks for your response.
      Here are some photos:
      Mains input:
      Click image for larger version  Name:	Mains.jpg Views:	0 Size:	752.6 KB ID:	3827274
      Inverter top view:
      Click image for larger version  Name:	Top-overview.jpg Views:	0 Size:	717.2 KB ID:	3827275
      Inverter and Aux power/brains:
      Click image for larger version  Name:	Inverter_and_APS.jpg Views:	0 Size:	864.8 KB ID:	3827276
      Inverter from side:
      Click image for larger version  Name:	Inverter.jpg Views:	0 Size:	688.6 KB ID:	3827277
      Comms board and serial port (next to usb):
      Click image for larger version  Name:	comms_board.jpg Views:	0 Size:	736.8 KB ID:	3827278 Click image for larger version  Name:	Serial.jpg Views:	0 Size:	679.7 KB ID:	3827279
      I afraid I've neglected power components like diodes and mosfets, I assumed for some reason they are fine. I was probably wrong and will check those.
      Regarding ICs, surprisingly not many there. Control board has F3062F25V MCU that looks like the brain of it all.
      Interface board has STM ST72F63BK2M1, which, I assume, deals with actual comms.
      There are some PWM control chips and what I would assume some comparators.
      Edit:
      Confirming all mosfets and power diodes are operational as far as I could tell by measuring them in place.
      • CoinCoin88
        Garage door RX unit (Cardin S38C) does not short relay to send opening signal
        by CoinCoin88
        I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
        Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
        09-15-2025, 03:36 AM
      • CuriousJohn
        Burco boiler power problem
        by CuriousJohn
        Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
        Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
        This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
        12-22-2024, 10:25 AM
      • PatElectron
        Denon AVR-X1400H — no audio from any source, internal test tone OK, no HDMI output, "Assigning" phase at every boot
        by PatElectron
        I bought this AVR-X1400H (E2, Europe) cheap as faulty, to repair. Seller said it died suddenly: no sound, no picture, headphones silent too. I have the service manual and a **working AVR-X1500H** on the bench as a reference. I've done a fairly complete diagnostic already — full details below so nobody wastes time on ground I've covered.
        Symptoms
        - No audio from any source: HDMI, USB, network/HEOS, analog IN1 and IN2, tuner. Nothing, on any input.
        - The internal DSP test tone plays correctly** through the speakers, on every channel.
        - No...
        09-10-2026, 09:11 AM
      • maxnode
        PS5 Pro CFI-7000 — 2-second blue light shutdown, PSU confirmed good, repeated unknown UART 80801002
        by maxnode
        I’m looking for board-level diagnostic advice for a PS5 Pro CFI-7000 that shuts down approximately 1–2 seconds after power-on.
        I’m from Ukraine, where obtaining official PlayStation repair is currently extremely difficult. The main official service facility available to us was destroyed during a missile strike, and the remaining out-of-warranty option was an expensive exchange for a refurbished console rather than component-level repair of my own unit.
        The console is approximately 18 months old and has only about 250 hours of use. Because...
        07-23-2026, 04:08 AM
      • jm1234
        9V relay temperature 40C
        by jm1234
        Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
        I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
        05-09-2024, 03:03 AM
