AYWUN A1-5000 - 5VSB nearly fixed
  • socketa
    Asbelowsoabove
    • Jun 2014
    • 692
    • samsara
    • non-causation of suffering
    This PSU is the same as the one in the switchmode power supply article by c_heddge
    I got it with a non-operational 5VSB
    Quite a few damaged components - circled in the schematic (ignore the secondary side, i used a schematic from a different PSU, and only adjusted the 5VSB circuit)
    The electrolytic cap was high ESR; so i think what happened is that it couldn't charge up enough to turn on the TO92 transistor, thus over-heating the main MOSFET and causing it to short, which, in turn, damaged the other components
    The source of the MOSFET is connected to the base of the TO92 transistor, so it looks like it was also normally supplying some voltage to the TO92 base, but not enough to turn it on - and i think that the optocoupler circuit provided the bit of extra voltage to turn it on.
    The photo in the article was the only one that i could find to give me an indication of the value of the burned of resistor that is next the the middle (driver?) transformer (pretty sure that it's 620 ohms)
    After replacing what i thought were all of the faulty components the 5VSB came up but it was way too high, like 10V or more, IIRC
    Then i found an open resistor between MOSFET source and the TO92 base, so am waiting for that to arrive.
    AS you can see from the first resistor that i replaced, a 1/4W is a bit too long to replace a 1/8W; so i ordered 1/6W resistors
    Also, you can see that the position of the first 3.3V output cap in not ideal - housed-in by the three toroids, like a mini oven? (i'd image that they would get fairy warm).
    I'm going to test it, once i get the 5VSB oscillating to 5V
    Click image for larger version  Name:	Secondary1.jpg Views:	0 Size:	198.7 KB ID:	3796330Click image for larger version  Name:	Opto resistor..jpg Views:	0 Size:	29.4 KB ID:	3796331 Click image for larger version  Name:	Circuit - Damaged componets circled.jpg Views:	0 Size:	67.4 KB ID:	3796332 Click image for larger version  Name:	5VSB1.jpg Views:	8 Size:	166.2 KB ID:	3796329
  • socketa
    Asbelowsoabove
    • Jun 2014
    • 692
    • samsara
    After replacing that 36ohm resistor, the 5VSB was 22V
    So thought that there could be faulty components on the secondary
    Replaced the opto with another one that caused an LED to glow brighter, and then checked the output caps, which were both good
    Eventually found that the TL431 had low resistance (50Kohms-70Kohms)between reference and anode
    I guess that the 5VSB got so high that it exceed this this regulator's specs
    So after replacing it, the 5VSB is now 5V
    Will now have a look at that 3.3V output cap, and then see if the unit will start up
    • socketa
      Asbelowsoabove
      • Jun 2014
      • 692
      • samsara
      That 3.3V output cap tests good, and it's rated for 16V, which i guess increases it's tolerance for heat.
      There is some protection kicking in when i ground PS_ON wire - the rail voltages come up, but the PSU pretty much shuts down straight away.
      The output rails aren't shorted, so i guess that the problem is more likely to be on the primary
      Will start with checking the primary side...
        • 31709
        if the standby went to 22v, you should check the datasheets for the main chips - they are powered by the standby and may be damaged.
        some years ago there was a series of threads about converting the standby side of some psu's to use a proper controller chip to prevent this type of crap.
        i dont know if they survived the recent atachment loss thing.
        • socketa
          Asbelowsoabove
          • Jun 2014
          • 692
          • samsara
          Good point.
          It's an equivalent TL494/LM339 setup.
          The chips are probably ok, since the LM339 comparator is sending signal to the PWM controller dead time control pin, and shutting down the PSU.
          At first i thought that the rail voltages were all within spec using a multimeter, but i can now see on the analog scope that the 12V is initially hitting 15V, 5V is hitting 6V, and 3.3V is hitting 4V.
          The main switching transistors aren't shorted, so i wonder what's causing the overvoltage on all of the rails - I guess that the PWM part of the chip could now be faulty like you said - like maybe it's turning on, but not switching
            • 31709
            did you replace all the small electrolytics yet?
            • socketa
              Asbelowsoabove
              • Jun 2014
              • 692
              • samsara
              Not yet
              I'll test the other small elecrolytics on the next fine day, and update with results
              Will start with those two that look like they provide negative bias to the main switching transistors to turn them off faster
              • socketa
                Asbelowsoabove
                • Jun 2014
                • 692
                • samsara
                Replaced the PWM chip with a KA7500, which seems to be equivalent except for a reference voltage of 5.0V vs 4.9V for the original chip.
                PSU still shut down.
                So had a look around the LM339, and it all seemed to be good
                Then thought that maybe the PWM is not getting correct voltage input from the 12V or 5V rails
                So traced back to them (resistor in between each rail and the chip pin) and noticed high resistance of 40 ohms coming from this 5V rail trace.
                The trace is damaged, and looks like another trace is also damaged.
                  • 31709
                  you need to re-enforce that or the crack will spread.
                  i usually deal with that by putting a piece of old fiberglass pcb on the top with epoxy.
                  • socketa
                    Asbelowsoabove
                    • Jun 2014
                    • 692
                    • samsara
                    Thanks for pointing that out - thought that it was just a scratch. So yeah, right you are - i looked at the top of the PCB, and the damage is visible on the top of the PCB, on both sides of the screw hole - maybe it was dropped at some stage.
                    I'll get around to doing that, and post an update here.
                    • socketa
                      Asbelowsoabove
                      • Jun 2014
                      • 692
                      • samsara
                      Reinforced corner (could have used a longer piece of PCB)
                      The PCB had a fair amount bend along it's length, so i managed to straighten it but applying some force and a heat gun (only took about 10s of heating). I used a zip tie to help, and then after realizing that the board responded well to the heat, and wanted to return to it's original flatness, i then just applied a bit of pressure at the ends while heating, to straighten them.
                      Pretty straight now.
                      Since this PSU would probably have being installed with the components hanging downward (Cases have the smaller screw hole separation distance on the top of the mounting space), maybe that is what caused the PCB to bend and then start cracking at the corner.
                      I checked a couple of other PSUs, and and they are also designed with the same mounting orientation, which seems wrong to me, as it causes the board to bend because of gravity, and the plastic standoff that's between the primary and secondary would otherwise also act to prevent board-bending if the PSU mounting holes were the other way around - plus all of the heat rises upwards to the PCB, which, again, encourages board-bending.
                      Bridged the cracks with solder, after scraping the solder mask off of the two traces.
                      Then reapplied new solder mask.
                      Works nearly good, except the 3.3V rail quickly goes to 3.45V (5V rail goes from 5.12V to 5.16V, and 12V rail is good), with just a hard drive connected
                      I then put a 4.7ohm resistor across the 3.3V rail, and it started at 3.36V, and within a second (takes longer than before) it rose to 3.45V (5V rail, no change from aforementioned)
                      • socketa
                        Asbelowsoabove
                        • Jun 2014
                        • 692
                        • samsara
                        Also notice slight noise that's coming from around standby transformer when the PSU is powered up, but it pretty much goes away as the hard drive spins up
                        • socketa
                          Asbelowsoabove
                          • Jun 2014
                          • 692
                          • samsara
                          I just used another schematic in this post, because it's similar circuitry as this Aywun 3.3 magamp. (Had to add in next post)
                          My PSU has TL431 reference pin voltage divider of 680 and 1800 which would give 2.39V at ref pin
                          internal ref for TL439 is 2.495V
                          ... so is is possible that this PSU was manufactured with the wrong resistor 680, instead of 580 - would it be easy for the person making this PSU to use blue grey brown instead of green grey brown?
                          Blue could look like green in poor lighting
                          This higher value resistor would cause the TL431 to turn on more and regulate at a higher voltage, because the PNP transistor would cause the magamp coil to saturate for longer?
                          • socketa
                            Asbelowsoabove
                            • Jun 2014
                            • 692
                            • samsara
                            • socketa
                              Asbelowsoabove
                              • Jun 2014
                              • 692
                              • samsara
                              I see that standard resistor values would be 560, or 620; so i replaced the 680 ohm with a 620 (actually 615) ohm, so that now the 3.3V rail voltage has decreased from 3.45V to 3.397V.
                              Don't know why they didn't use a 620 ohm resistor rather than a 680 ohm, which brings 3.3V rail closer to 3.30V
                              Anyhow, it's fixed now
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5327
                                • New Zealand
                                • Electronics and computer repair
                                Aywun isn't exactly a great brand and 3.45v is still (just) within the ATX spec. So they probably just didn't care.
                                -David VanHorn
                                • socketa
                                  Asbelowsoabove
                                  • Jun 2014
                                  • 692
                                  • samsara
                                  Yes, ...because when i use a standard 560 ohm resistor, the 3.3V rail becomes 3.32V
                                  (5V rail is 5.177V)
                                  Will leave it at that.
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5327
                                    • New Zealand
                                    They probably ran out of 560 Ohm resistors, and being cheap AF, just used the next best ones they had.
                                    -David VanHorn
                                    • kotel studios
                                      FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                                      by kotel studios
                                      Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                                      Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                                      I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                                      Any ideas where to go next?
                                      02-23-2025, 11:47 AM
                                    • прямо
                                      Viper22A 5VSB circuit
                                      by прямо
                                      So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                                      In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                                      01-13-2024, 07:05 PM
                                    • howardc64
                                      Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                      by howardc64
                                      TV was fixed just after removing Samsung's rear snap cover.
                                      This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                      Maybe PSU->backlight connector didn't have a good contact?...
                                      07-23-2025, 12:34 AM
                                    • mrcliem
                                      CM V700 no +5vsb, ICE2QR4765 low VCC in... Need guidance please...
                                      by mrcliem
                                      Hello...
                                      I got my self a dead CM V700 PSU, with nothing on +5vsb
                                      I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
                                      As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
                                      The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
                                      I have read the datasheet and and still can not...
                                      06-29-2023, 08:18 AM
                                    • Ven
                                      Dell Vostro 14 3435 AMD – 2 amber / 1 white – FIXED
                                      by Ven
                                      Posting this in case it helps someone.
                                      Had a Dell Vostro 14 3435 AMD with 2 amber / 1 white LED. Mainboard LA-M36AP.
                                      Symptoms:
                                      • Fan spins once
                                      • CPU and RAM get slightly warm
                                      • No POST, no display
                                      • LED code does NOT change with display connected/disconnected
                                      • Board powers on/off by button normally
                                      • Power rails looked OK during initial power-on and CPU rail was not shorted, so it didn’t look like a dead CPU.
                                      What fixed it:
                                      • I had a BIOS chip from another same board (CPU-dead board, BIOS dump was already repaired for that board from here Badcaps)
                                      • Simply removed the
                                      01-07-2026, 05:30 AM
