Troubleshooting Cramer RV power supply
  • madan1
    • Nov 2016
    • 682
    • Bulgaria
    Good day.
    I'm currently on a vacation and a friend from the camp site asked me to check why his camper power supply does not charge the batteries when hooked to the mains.
    The PSU is cramer and from what I've found the same mainboard is used in both cbc-b7 and bcc-b7. The control module/interface panel is Cramer D-5750.
    So what I've found so far - the transformer seems to be working fine and the board has no visually damaged components. I tested most of the diodes and transistors with a multimeter (the only tool I got here) and they read fine.
    The two thyristors have been disconnected from chassis/ground/anode and gate and at some point someone has soldered a resistor between the cathode and the gate to keep them non stop open(?).
    I connected the thyristors as shown in the schematics (gates to gate connectors on the mainboard and anode to chassis), but now I'm getting some strange voltage readings (Vac).
    When using chassis for reference with disconnected gates:
    T1
    Cath. - 17.1 Vac
    Anode - 0
    Gate - 16.6
    T2
    Cath. - 1
    Anode - 0
    Gate - 1
    When using transformer winding midpoing for reference (this is the V+ used for charging the batteries) with disconnected gates:
    T1
    Cath. - 12.34
    Anode - 9
    Gate - 12.34
    T2
    Cath. - 12.3
    Anode - 9
    Gate - 12.3
    I suspect the thyristors went bad and that is why they were disconnected.
    Is there a way to test them with only a multimeter?
    On the board, both gates show 3.3Vac 50Hz and 1.3-1.4Vdc so probably there is some switching going on there..
    Click image for larger version  Name:	rv7.jpg Views:	3 Size:	236.7 KB ID:	3680880
  • madan1
    • Nov 2016
    • 682
    • Bulgaria
    I got lucky and found the schematics.
    • CapLeaker
      Leaking Member
      • 8158
      The lid sez there is a 4A fuse for the battery charger. Check it. Also there is a switch for the charger.
      Btw. It does tell you to NOT operate the unit on the power grid without batteries being connected.
      I did find a manual of this thing but it is in Dutch. There is supposed to be a charger relay?
      • CapLeaker
        Leaking Member
        • 8158
        Could also be whatever drives the gate of the thyristor is bad.
        • madan1
          • Nov 2016
          • 682
          • Bulgaria
          The fuse is bypassed, because the holder broke, when opened it to test the fuse (the fuse was ok). The switch works fine.
          I guess it should not be used without batteries because they are also used as capacitors and if there are no batteries, the power would be so chopped that it might damage the consumers. Looking at the schematics, I do not see any other reason.
          The gates are driven by T1 and T2, which test fine. Both transistors are controlled by comparator LM 339 and if I get it right - the output signals are same, but with reversed phase. There is some signal pull down circuitry, which I'm still trying to understand. Looks like it is controlled by Vref and B2 ( the power rail for charging the batteries ), but no input from the main controller. Hmm, now writing that, this circuit might not work correctly without the batteries smoothing the rail.
          Well, I just ordered the thyristors and expect them to arrive by the end of the week. Then will test it again, but this time installed in the vehicle.
          • CapLeaker
            Leaking Member
            • 8158
            This circuit has been obviously modified for a reason. Fix that PSU properly up like the fuse holder, thyristor and go from there.
            • madan1
              • Nov 2016
              • 682
              • Bulgaria
              I'm not sure the previous guy knew what he was doing... for instance the transformer auxiliary power coil was connected to the gate connectors.
              But, yes, once the psu is working, I will fix all the small things like fuse holders, connectors, solder joints, etc. As mentioned, I'm on holiday now and away from my solder irons, dmms, parts and so on.
              • Lvsitano
                Asus X532FL 3.2V at source and gate
                by Lvsitano
                I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
                First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
                I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
                First...
                06-26-2024, 02:13 PM
              • howardc64
                Macbook Dust-Gate Preventive Cleaning
                by howardc64
                Just did this on my 2021 13" MBP M1. Dust-Gate design flaw still present. Depending on cleanliness of the operation environment (often eating while using MB is probably the worst). Periodic cleaning is probably warranted.
                Note this is quite challenging effort. One misstep will damage the LCD flex and render it useless. So take it to someone more experienced if uncertain.
                https://www.ifixit.com/Guide/MacBook...leaning/177920
                10-09-2024, 10:10 AM
              • prototypedoc
                Lenovo Legion 5 15IAH7 NM-E241
                by prototypedoc
                Hello guys,
                Got my hands on this laptop and started troubleshooting. The only thing I know is it turned off and never came on. No lights and not coming on.
                Started doing some checks and found the main rail present everywhere. Something weird though as the gate of the first input mosfet is 3.7V and the output is 20.3V.
                Tried to trace the gate and it looks like it's connected to pin 61 on the io. Is the IO supposed to monitor the gate voltage?
                5V and 3.3V are missing from the coils. Found by lifting PL6202(on the 5V rail) the clicking fet sound goes...
                04-24-2024, 02:32 PM
              • irfan karatela
                MOSFET no voltage at gate Quanta G7HA DAG7HAMB8EO
                by irfan karatela
                I'm working on a HP Pavilion Laptop Model 15-eh1508sa that is missing 19v. I've looked at the schematics and want to know what conditions the ISL9238C checks before it enables the gate for MOSFETs PQ8200 and PQ8201,
                I havent found any shorts on the board.
                I get 19v at +PRWSRC but around 1.7v at the Drain of PQ8201(+vin)
                On Page 82 of the attachment. Link to schematic - https://www.badcaps.net/forum/troubl...ilion-laptop-p...
                01-20-2025, 07:15 PM
              • wagivem657
                Sharp LC-55LE643U, bad gate drivers?
                by wagivem657
                Just received a busted Sharp 55" Aquos (LC-55LE643U) from a coworker. He tried swapping all three boards (power, main, TCON) to fix the problem, but it had the same issue. He was kind enough to give me the TV and both sets of boards for free, so I can try to get it working for myself.
                Unfortunately, I think I may have made the problem (much) worse, but I'm interested to see if the original problem was fixable at all regardless...
                Pictures show the issues:
                1. shows what happens when you first turn the TV on. Well, kinda, the white column wasn't there at
                01-29-2021, 08:13 PM
