ZD-915 Desoldering Station when on the blink
    • Jul 2011
    • 6037
    About a week I went to turn the De-soldering Station and it did not come so I took it apart to see why
    and found a 5 pin IC chip so I look it up to see what it was and here is what I found---------->
    It has one of these regulator in the power supply FSCQ1565RTYDTU Power Switch ICs - Power Distribution 15A/650V QRC Power Switch
    https://cdn.badcaps-static.com/pdfs/...3d31708caa.pdf
    So let order two of them and see what happen
    I put one in and what do you know it came back to life
    So I look at old regulator with a magnifying glass and I see a crake from one side of the chip to the other side in the front of it
    https://www.badcaps.net/forum/showth...sam#post335581
    • Jul 2011
    • 6037
    Re: ZD-915 Desoldering Station when on the blink
    I had use my old ZD-915 which the vacuum pump is failing
    I still use it with a pencil soldering iron that I use the plug off of a bad De-soldering gun to make it work
    I am so glad that I was able to fix the newer ZD-915 power board
    It was very hard to get that 5 pin regulator IC chip off the board with a weak vacuum pump
    Dose any one have a ZD-916
    The problem with this one is that when you turn it on about 2 to 3 minute later the LCD display goes blank and then about a minute later the LED light for the display goes dark
    If you turn it off for about 10 seconds it work again and the same thing happen again
    This soldering station has never really work from day one
      • 30990
      check the state of the soldering on all those ZD units.
      and maybe recap them.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4951
        • New Zealand
        I have a Duratech (rebranded ZhongDi ZD-912) with iron and hot air (not desoldering) but it is the older version with a linear power supply
        -David VanHorn
          • Jul 2011
          • 6037
          I had recap the power board on the newer ZD-915 when I first bought it
          The ZD-916 dose not have a switching power supply in it
          If I am not mistaken it only has two cap on the power board
            • 30990
            if it's the soldering station in the foto,
            i'v had one of those with a bad thermal fuse in the transformer.
            put a meter on the transformer output and see if it drops when the unit dies.
              • Jul 2011
              • 6037
              Thanks for the info
                • Jul 2011
                • 6037
                vacuum pump
                This soldering station has never really work from day one also I could not understand why the back light for the display was so much brighter than the back light on the ZD-915 ones now I know why -------->
                I found what the problem is with the ZD-916 control board is that there was a really very small SMD chip that was a cap that was very discolored so I checked with my blue ESR meter and the reading 14 ohms
                I did no know what the value was but it is on one of the power rails right next to a diode so I put something that I had on hand now the back light is about the same brightness as the ZD-915
                I also recapped the power board and the control board
                It has been on for over an hour now and has not gone off once
                  • Jul 2011
                  • 6037
                  Well the ZD-915 was sick again
                  The switcher went out again
                  Here is what happen I went turn it on and it came on and went right back off in about one two seconds
                  Can anyone shed some light to why this switcher keeps going bad
                  I put a new one in and it started working again
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Ohh no I have one thats been heavily used for around 6 months, wander when it will fail :L
                      • 30990
                      got a foto of the psu board?
                      it may have a bad or under-rated snubber cap or something.
                        • Jul 2011
                        • 6037
                        It will a few days before I can get it apart again
                        Snubber caps are the blue colored caps right
                          • Jul 2011
                          • 6037
                          I had mine for about a year before I had trouble with it but I recaped it before I started using it
                            • 30990
                            hey, i just saw the other thread you bumped.
                            18v output.
                            25v caps - hell no.
                            for smoothing 18v you want 35v caps.
                            old rule, a smoothing cap should be atleast 1.5x running voltage to handle the spikes.
                            18+9=27
                            that's far too close!
                            also, if it pulses the element with DC does it have a reverse protection diode?
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4951
                              • New Zealand
                              It is true that blue-coloured high voltage ceramic capacitors are often used in a circuit for that purpose, but it does not mean that every time you see a blue capacitor it is a snubber capacitor, or that if a capacitor is not blue, that it isn't a snubber capacitor.
                              You have to look at the schematic or trace out the diagram and figure out which capacitor is the snubber capacitor.
                              It is usually part of a resistor, capacitor and diode snubber network which is in parallel to the transformer winding that the MOSFET drives, in a flyback style switching supply. See picture for a typical circuit.
                              If the capacitor has failed, they probably didn't use one with high enough voltage rating.
                              -David VanHorn
                                • 30990
                                they can be blue or yellow or orange, colour is irelevent.
                                what we are talking about is resin-coated high-voltage ceramics. usually 1-3Kv rated.
                                you can use them for lots of stuff.
                                but snubber circuits see short but hgh spikes so high voltage caps are a must.
                                  • Jul 2011
                                  • 6037
                                  Ohh no
                                  18v output.
                                  25v caps - hell no.
                                  18+9=27
                                  By the way that what the voltage value that was in there
                                  Do these two 2200uf caps ---------> are uf value high enough for 13 amps or do I need 2500 or higher
                                    • 30990
                                    you lost me - what 2200uf caps?
                                    ripple current is in the datasheets btw.
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4951
                                      • New Zealand
                                      We need photos, we have no idea what your power supply looks like.
                                      -David VanHorn
                                        • Jul 2011
                                        • 6037
                                        UpDate
                                        Here are some photos of the switching power supply for this unit
                                          03-31-2024, 02:12 PM
                                        • armini
                                          18VDC PSU completely dead - ZD-915 desoldering station
                                          by armini
                                          Hi everyone!
                                          Three years ago I got a ZD-915 desoldering station which failed just after a few months of light use. During a short desoldering session, the station simply shut down, and since then it has been completely dead and unresponsive. The failure was silent, without any pops.
                                          Due to a lack of time, I set it aside and didn't look at it.
                                          Yesterday, I took it apart and did some basic measurements. The 18v terminal shows 0v. In addition, there is no visible damage to the board itself.
                                          According to replies in 18VDC PSU has dropped to...
                                          04-25-2023, 07:49 AM
                                          07-01-2024, 06:34 AM
                                          HP Station de travail Z2 format tour G4 i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Station de travail Z2 format tour G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Station de travail Z2 format tour G4 boardview and Station de travail Z2 format tour G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-12-2024, 02:20 PM
                                          MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook GF Specification for Upgrade or Repair
                                          This specification for the MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF66 11UG-820FR Katana Dragon Station boardview and GF66 11UG-820FR Katana Dragon Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-07-2024, 05:20 AM
