FSP400-60GLN worth fixing?
  • Behemot
    • 4845
    • CZ
    #141
    Re: FSP400-60GLN worth fixing?
    Well they have more common things, like the main transformer, the output inductor and of course - the feedback and regulation. The +3.3 V is magamp'ed so that's kinda failproof. If the inductor is designed to saturate early, it can still provide good enough voltage no matter what's comming from the +5 V.
    BTW, I took three other, non-FSP units, screwed one somehow (but that was slightly greater work with some operations and transplantations, so I guess problem is somewhere in there), the other two were just fine and very easy work: HP AcBel 300watter (with DC-DC even!) and Delta GPS300FB B or something like that, very nice, simple and airy unit, I like it. One G31 board from ASUS did not like the AcBel much but it was running with Biostar A780L so no prob.
    As for GLNs, I have found another 350watter so as soon as I'll have time I'll remove both SB transformers and compare the windings with Malish to test everell's theory…
    Originally posted by Elitist
    DM311/Fc270 & 6800 - where are these located, please?
    DM's or other SB PWM's are on the stand-by rail, that is in front of the SB transformer, IIRC next to the primary heatsink. The 6800 should be on a primary daughterboard if memory serves me well?
    • Elitist
      • Apr 2006
      • 159
      #142
      Many thanks, Bh. My DM311 is a Fairchild Q0170R, labelled M4. FWIW, it looks clean as a whistle no signs of burning/overheating either around (top of board) or SMEs under, although I don't like the way their adhesive dots are discoloured across the entire piece.
      My 6800 is a CM6800G lo srt-up current PFC/PWh controller. Had to engage in gymnastics, lights & lenses to read it on daughterboard. Again, looks clean.
      Testing these blighters in circuit isn't easy and probably not instructive. Don't have instrumentation to check out-of-circuit. Is replacement worth the effort?!
      T2, the SB transformer is unmarked, too, as is the main transformer. Removing either might not help as I don't possess equipment to test under load. I realise inspection alone isn't always a guide, but it often is! For me, the big puzzle is all three of my (identical) units, bought at different times exhibit the same shortcoming(s)/fault(s). Logical deduction usually suggests a single defect in most cases; perhaps this is the exception.
      It's said that one should know when to quit, but I don't usually subscribe to that philosophy. Masochist?
      • Stefan Payne
        • 1267
        When was your PSU made?
        If it's around 2006 or so, it may be better to throw it away because you might want to replace the PFC coil.
        Those units had issues with the material of the coil.
        As far as I know this only happens on smaller versions.
        So up to 550W you want to change the coil, on 700W it's not so much of an issue, if at all...
        • Stefan Payne
          • 1267
          Yea Behemot, I did not even check the price of the large bulk cap before I made this thread.
          I was shocked to see they go for around €10, and not only on my local Swedish electronics store but even on ebay! (Genuine Japanese caps of course).
          Where are you looking??
          Maybe you should learn German
          We have a rather cheapish electronics store here:
          https://www.reichelt.de/Becher-Elkos...0&SEARCH=%252A
          270uF/400V KMR for only 3,40€ (450V 4,35€)
          330uF/400V KMR for only 4,15€
          Also those tiny <50uF/50V Caps are dirt cheap there - sometimes cost half of mousers. And also you might want to get some Kemet A750 Polymer caps...
          • Elitist
            • Apr 2006
            • 159
            #145
            Thanks for those comments, Stef. No, much later, around 2012-ish. No sign of the transformers or coils overheating - copper wire and varnish still pristine. All are/were 400W and none overworked.
            As for price of caps, best price/delivery for quality stuff is rs-online - operates internationally now, can get a trade a/c with 'free' p&p, next day ail order throughout Europe and antipodes. Used to be a tiny little operation in a London back street (Radiospares)selling war surplus, now massive operation. Cheaper but 1yr warranted from CPC, part of the Farnell international group; also sells most gear any diy handiman/woman will ever need, like engine oil, kitchen appliance spares, consumer unit, memory, garden equipment, hammers...
            [in this context, esp. hammers]
            • Behemot
              • 4845
              • CZ
              #146
              Well I can't provide next day delivery, but my cap stock is generally much cheaper than of these big brands…
              • Stefan Payne
                • 1267
                Depending on where you live, they don't du business with "consumers", only Business to Business...
                • Elitist
                  • Apr 2006
                  • 159
                  #148
                  " they don't do business with "consumers" "
                  - you mean they won't do business with the SP Corporation?!
                  - only down side might be minimum quantities, ie can't buy one off 5ohm sme, but anything costing more than ~£2 is usually available in single units.
                  - but if Bh is marketing caps, problem solved.
                  • Behemot
                    • 4845
                    • CZ
                    #149
                    Did we ever found the right value of the Z41 zener? Got another bad one…if it is stabilising the voltage for the controller than something like 16-18 V would be OK? The datasheet for DM311 states the chip starts using the auxiliary winding as soon as the voltage reaches 9 V. And nominal is 20 V. So 18-21 V should be better choice I guess…
                    BTW I just got enough of this "every cable soldered in the board" crap which si terrible for any decent work and testing during the refurbishing procedure. So I've just made the fan unpluggable using a connectors from other stuff, and will solder an europlug cable to the board, which will give me enough of manoeuvrability to work on the board (=replace caps mostly) but also possibility to easily plug it to mains. It does not *need* grounding and ground reference for short-time testing.
                    • Behemot
                      • 4845
                      • CZ
                      #150
                      So, as for unit No. 2, I managed to make the SB working. Only reasonably close zener I found was 18 V something, than the 2R0 resistor was replaced (measured OK but it was burned almost as if fused) and also D41 for something reasonable, this time some old Vishay BYV26C ultrafast (1 A/700 V, 30 ns).
                      As for No. 1/2, I removed both the SB transformers, they seem to be both pretty much in the same condition according to Malish (Mikhails AVR tester). Actually now just tested transformer from No. 1 in the No. 2 and it still works. So I guess also the 2 in 1 will still show the same behavior (only 3 V @+5 V SB) which means the problem is elsewhere. Any guesses? I'd remind that the 1, unlike 2, has no scorched marks, it is absolutelly clean, besides few bloated caps there were no visible problems. Used chloroprene glue but nothing was darkened (yet).
                      As for the C5 I think somebody asked about, Fairchild's DM311 datasheet suggests 10-47 uF. It is true that I *think* I've seen 100uF caps only in the 500W Blue Storms II.
                        master hoarder
                        • May 2008
                        • 12175
                        #151
                        Pretty good guess. Should work. I had to do the same for a TV board made by Delta (had an ICE FET-controller combo for the standby IC). Used 18V Zener IIRC, and that worked fine.
                        Yeah, I hate that too.
                        That is one reason why I like those old Macron PSUs - there is a connector for everything. Even the fuse has a holder.
                        Check/replace the 431 shunt and maybe the opto too, just to rule those out.
                        The larger capacitance is there probably because the APFC controller and/or PWM controller on the primary may be drawing power from that rail as well.
                        • Behemot
                          • 4845
                          • CZ
                          #152
                          Yep, but still seen 100uF only in the retail Blue Storms II 500 W or so. And now also in a 500W Epsilon. Which is some decent crap as well, besides the D6.3 470/16 Teapos SC, it is somewhat crapping me with some boards where the stand-by rail oscillates in an on-off state, but when I hit the right time to turn the boards on, they work OK. Another board seems to be OK. Kinda a mystery…
                          BTW should we start new thread for Epsilon/Everest platform, or keep it here? Cause the platforms are very similar, the stand-by rail is almost the same, just the components are sometimes moved a few milimeters here or there.
                          • Behemot
                            • 4845
                            • CZ
                            #153
                            Interesting this is. This Epsilon of mine I mentioned above works fine when I turn it on from no load @SB rail. Than I can go as high as 3 A and it still kicks.
                            However, when I keep it in stand-by mode, and hook as low as 0.5 A on that rail, it starts restarting so the output voltage is close to none. Than it also can not start in such state as both primary driver and secondary supervisor are powered from it. Any idea what this strange thing may be?
                            Anyway, man, I am starting to think about tossing anything labeled FSP into fire next time. This is really crazy. You always think after all the work everything's OK, and it always comes with some brand new crap on you…
                              master hoarder
                              • May 2008
                              • 12175
                              #154
                              IDK. If it was up to me, I would probably start a new thread and link back to this one for reference (particularly to posts with relevant info).
                              That way, those PSUs get more attention on their own, but people still get to find this thread too.
                              Could be something related to a marginal component value used, where over time the part ages, drifts, and causes the PSU not to start. Most likely something that affects the restart/UVP/OPP of the DM311 IC.
                              Probably best to look into the DM311 datasheet and see how the application circuit they give in that compares to what is in your PSU.
                              Compensation and feedback to the 431 shunt may be another place to look into. See what is in the DM311 datasheet again. Also compare that to what you see in other non-FSP PSUs.
                              Yeah, I never fully recap a PSU just like that. First I make sure to get the 5VSB running, if it isn't already (and also make sure it works under load). Then I do the rest of the recap.
                              • Behemot
                                • 4845
                                • CZ
                                #155
                                I just realised, there is some change though. Besides normal link to the input filter and so on, there is also some strange wiring from the AC switch directly close to the SB controller. I am not sure what it does or how it works yet, gonna have to investigate.
                                AS for recapping procedure - well I started doing that with these terrible things, but as you, even when you think all is fine, it is not in the end…sp I have to drag my load tester to half done, opened-while-being-worked-on unit each time and test it under load? I'd rather toss it to fire, really
                                • Elitist
                                  • Apr 2006
                                  • 159
                                  #156
                                  Your website is now showing insecure - message overwriting the U/N, P/W area?!
                                  Well, I did the caps & D's + few R's - SB OK, all lines showing correct V s on o.c.. Is Z41 so mission-critical? Yes, already reported above some sme s had overheated and charred the adhesive spot underneath, probably making them 0R s. Why is my +5V restored to full capacity, but not other lines, esp. with clean transformers? Why is this possible if DM311 controller misbehaving. Still a can o' worms - where to turn next? How do you build in obsolescence for ~3yrs? What collateral damaged have the leaky caps perpetrated? And all the other unfathomable questions...
                                  • Behemot
                                    • 4845
                                    • CZ
                                    #157
                                    What website, what message?
                                    There is another zener just by the DM311, but I don't think there's something for the CM6800 and the supervisor so it should be there, and OK
                                    • Elitist
                                      • Apr 2006
                                      • 159
                                      #158
                                      This website. Something like "This website is not secure, etc, etc..."
                                      It overwrites the log-ins which seem to be required every time now.
                                      The pop-up obscures the log-in panel but just keep typing and press <enter>.
                                        • 31262
                                        what browser are you using??
                                        • Elitist
                                          • Apr 2006
                                          • 159
                                          #160
                                          Ff !
