Hanmatek HM310T bench PSU - schematics wanted
  • Dangerousk
    • Feb 2023
    • 13
    • England
    hey there
    I picked up a faulty bench PSU that was being discarded as was faulty. So the internal SMPS has some faults, bad thermistor, Schottky rectifier and Mosfets all blown and I have replacement parts on way. fingers crossed 😀
    I am looking for a set of diagrams for the power supply. has EST v1.15 along with 2022 date. Not sure if the EST refers to Edwards or some other manufacturer.
    thanks in advance.
    D
    • Jul 2011
    • 6040
    Please post some pictures of the device in question including the pictures of both sides of the circuit board so that we can read the components print and if you can point out the parts that are bad or missing
    • Dangerousk
      • Feb 2023
      • 13
      • England
      Hi sam_sam_sam
      will get some pics of the device and board and share. Will take a few hours
      Cheers
      D
      • Dangerousk
        • Feb 2023
        • 13
        • England
        Hi
        Photos as requested:
        Front panel
        from the right hand side
        the main SMPS board is loose as the heatsink is removed with 3 faulty components...i removed to test a 470uf 50v cap but has tested OK.its removed from near top left of the board on the DC side.
        all the issues appear to be on the hot side.
        from the rear of the bench supply - 5A slo blo fuse also blown. The USB port is for programming the supply
        the business side of the internal SMPS
        Notes on the above Photo...
        Board is loose as I removed the heat sink to check 2x mosfets and the schottky rectifier - all 3 are blown.
        the smps board
        the faulty parts on the heat sink are
        Q9 & Q10 = cs20200CT MOSFETS
        Q8 = 13N50A Schottky Rectifier
        NTC1 = NTC20D11 Thermistor
        close up - hope it will zoom
        board labels
        • Dangerousk
          • Feb 2023
          • 13
          • England
          all working great after replacing the blown items listed.
            • 31044
            plan on re-capping it at some point,
            it's probably full of crap like chang-x instead of rubycon/panasonic
            • Dangerousk
              • Feb 2023
              • 13
              • England
              I plan to - gets light use as not expecting it to cope with 'marketed rating'
              cheers
              • maxxcomputers
                • Mar 2015
                • 9
                • Romania
                Hello, have HM310 and HM605T. HM310 have ucontroler bad or unprogramed (STM8S00 5K6T6C). I have one HM310 with ucontroler good. Can this STM8S00 5K6T6C be copied?
                  • 31044
                  STM8 needs an ST-Link programmer and some luck - it has read protection but they may not have enabled it.
                  • shamsudeen
                    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                    by shamsudeen
                    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                    i know that in linear power supply the noise will be very low comparing to SMPS supply....
                    07-19-2025, 07:14 AM
                  • Eniaro
                    Bench test a series X
                    by Eniaro
                    How do you bench test a series X? I was planning to find a defective PSU to use its connector, but before I go about doing this, I was wondering if there's any bench PSU to the series X connector adapter available
                    06-17-2025, 01:46 PM
                  • rabsonnjala
                    LENOVO IDEAPAD 100 works only on bench power supply
                    by rabsonnjala
                    Hie I have a Lenovo laptop
                    Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                    it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                    below are my readings
                    with the original charger only
                    JBATT1
                    PIN1 0.22V
                    PIN2 0.22V
                    PIN3 0.45V
                    PIN4 0.45V
                    PIN5 O.43V
                    PIN6 0V
                    PIN7 GND
                    PIN8...
                    11-20-2021, 08:32 AM
                  • GPUTech
                    Hanmatek dos1104
                    by GPUTech
                    I picked up a dead no power hanmatek dos1104 from evilbay, it appears brand new in original box with the screen protector still on it.
                    Ends up with two shorted buck converters and shorted MCU F1C200s. After replacement the unit now boots to a splash screen then boot loops.
                    I'm hoping to find the software for the MCU. The manufacturer does not respond to emails, or have any type of support that can be contacted.
                    Paul​...
                    12-11-2024, 08:14 AM
                  • Crystaleyes
                    Bench PSU question
                    by Crystaleyes
                    Hi all.
                    Looking for some help regarding the workings of this unit.
                    Some time ago I picked up a digital bench power supply from the local flea market here in Rio. It's a 'Sincler SPS 3015/D' which I imagine is 30V, 1.5A 'Digital'.
                    Even though it would turn on and show a display, it wasn't working, and no matter how hard I have looked, I've found no reference let alone any kind of schematic. I imagine it is from the late 70's or early 80's? I can only assume that all the components are to the original specs although it had clearly had prior work done so it 'is' possible...
                    11-12-2024, 05:05 AM
