Startech - 12 V Sata HDD Docking stopped working - Need help to identify an IC
  • samstown
    • Mar 2021
    • 122
    • Switzerland
    Hello folks,
    One day my Startech HDD SATA docking stopped working, instead of buying a new one I want to repair it. I've measure PCB and I think U10 is a mosfet and the culprit but I don't know what chip to order to repalce it.
    Sam
  • kasfamily
    • Aug 2014
    • 769
    • Russia
    Hi, check out U7
    • samstown
      • Mar 2021
      • 122
      • Switzerland
      Thank you. U7 is the one on the 3rd pics (see voltage in red) , it has 12 V in and 10 V Out, that doesn't sound right ? it should be 5 V only ? I can try to inject 5 V at output and see if that work. Thanks.
      • samstown
        • Mar 2021
        • 122
        • Switzerland
        Ok I've tried to inject 5V at U7 output, it doesnt help.
        • kasfamily
          • Aug 2014
          • 769
          • Russia
          U10 does not look like a mosfet, wipe it with alcohol, at least part of the name may appear
          • samstown
            • Mar 2021
            • 122
            • Switzerland
            I've cleaned it with Isoproply alcool and tried to look with microscope and smartphone zoom with different light and angle.. I see nothing at all. what chip could taken the input from power button to pass power to start ?
            • kasfamily
              • Aug 2014
              • 769
              • Russia
              Still, once again a photo of U10 and foto this part number
              • samstown
                • Mar 2021
                • 122
                • Switzerland
                thank you for your time and help. I've tried searching online but couldn't find anything.
                • kasfamily
                  • Aug 2014
                  • 769
                  • Russia
                  Do these two have visible names?
                  • прямо
                    • Sep 2022
                    • 261
                    • Indonesia
                    You need to remove U7. It is faulty. 78L05 is a fixed 5V regulator and it shouldn't be outputting 10V. It's most likely the reason why that 8 pins IC (whatever it was) blew up because it was supplied with 10V instead of 5V.
                    And 78L05 has to be removed before you can inject 5V, although at this point it is pointless to inject voltage. You won't be able to fix this device until that blown IC is identified.
                    • samstown
                      • Mar 2021
                      • 122
                      • Switzerland
                      Thank you. I've remove it now and I removed U10 as well.I've tried to find any marks on it but there's no way. I'll give up on this repair. Thank you all for your help.
                      • прямо
                        • Sep 2022
                        • 261
                        • Indonesia
                        The photos you shared have a very bad image quality. Did you use a camera phone from 20 years ago???
                        If we could see everything clearly it may be possible to guess what IC it is, what it does and to bypass it entirely.
                        • DynaxSC
                          GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                          by DynaxSC
                          I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                          There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                          The board is generally working now, all PCIe ports are working, Windows installs normally.
                          However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                          The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                          03-10-2025, 12:27 PM
                          HP EliteBook 840 G6 + UltraSlim Docking Station Notebook 800 Specification for Upgrade or Repair
                          This specification for the HP EliteBook 840 G6 + UltraSlim Docking Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + UltraSlim Docking Station boardview and 840 G6 + UltraSlim Docking Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                          09-06-2024, 06:00 PM
                          09-06-2024, 12:30 PM
                          HP ProBook 640 G5 + UltraSlim Docking Station Notebook 600 Specification for Upgrade or Repair
                          This specification for the HP ProBook 640 G5 + UltraSlim Docking Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G5 + UltraSlim Docking Station boardview and 640 G5 + UltraSlim Docking Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                          09-06-2024, 10:56 AM
                          HP EliteBook 830 G6 + UltraSlim Docking Station Notebook 800 Specification for Upgrade or Repair
                          This specification for the HP EliteBook 830 G6 + UltraSlim Docking Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + UltraSlim Docking Station boardview and 830 G6 + UltraSlim Docking Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
