ADP-160FR ps4 slim PSU, shuts down under load and has severe coil whine.
  • Gjackson
    • Aug 2021
    • 134
    • Malta
    Could be, Definitely not the main filter capacitors as I swapped those, so maybe something on the secondary? I'll see If I can get something to test current draw since I don't have a load tester right now
    • прямо
      • Sep 2022
      • 261
      • Indonesia
      maybe a 12V DC halogen bulb as a load? or a few of high speed high current 12V DC fans that crypto miners use.
      • CapLeaker
        Leaking Member
        • 8195
        well... if these two pics are from the 12v rail... neither of them are any good! I am kinda baffled for a bit, because the secondary should be smooth as silk. I mean it's like all 16v caps are effed on the output?
        • Gjackson
          • Aug 2021
          • 134
          • Malta
          Checked all the 12v secondary output caps too, seem fine, unless there's one that's testing good but is a bit leaky or something I have no clue at this point
          • temyth
            • Jan 2024
            • 45
            • Brazil
            i don't know exactly how this PS4 PSU works but in ATX PSU's sometimes we have some open trafo. maybe one of the trafo's had open the circuit and thats why it shut downs when it has some kind of load. the wire inside of the trafo may doing just a little contact but when it get load and heats up it lost contact. it just a theory, worth checking. I just don't know if you can buy these trafo's
            • speggio91
              • Apr 2020
              • 83
              • Italy
              #26
              Hello, I have a similar case with a PS4 power supply, model ADP-240CR.
              It's story is that the PSU had the main fuse blown and the STF24N60M2 mosfet shorted.
              I've then replaced it mistakenly with a 24NM60M2 that has 17 A of max drain current compared to the 18A of the STF24N60M2.
              As soon as i powered the psu back on and enabled the 12V line, the 24NM60M2 bursted into pieces and damaged other components such as a tiny 50ohm resistor (R98), a diode (D63), the PFC IC controller NCP1608 (IC41) and the 12V controller DDA001AG (IC32).
              After replacing those components from a donor board, the PSU started to work again and I did a quick load test up to 17A for 5 minutes without noticing issues.
              I put the psu back on the PS4 and it worked for 2 months, after that it start failing under load, roughly one hour into the games.
              After a few days it wasn't even able to power on the PS4 again.
              I disassembled it and put it under the electronic load and the 12V is present, the voltage on the main filter cap is 406V. The pfc should be working, but as soon as i crank up the load to 15A i start hearing the coil whine at the primary side, i think on the L1 which is the PFC inductor.
              The voltage on the cap remain stable at 405V but the 12V output become 8V..
              Is this issue related to the PFC again in your opinion? I have to say that the PS4 was in a room without air conditioning and in the past month here has been so hot.
              • speggio91
                • Apr 2020
                • 83
                • Italy
                #27
                EDIT:
                I think I found the issue!
                I forgot that the 12V controller DDA001AG was not take off a donor board but isntead bought from an ebay seller who sold me also a defective NCP1608.
                After watching the video that another user posted on another thread (https://www.youtube.com/watch?v=sx0oBXsueFk) I then tried right away to extract a DDA001AG from a donor board i recently bought and guess what?
                Now the 12V is stable even at 18A of load and the coil whine is gone! The voltage is not going lower than 11V and the filter capacitor voltage is 409V. Amazing!
                This really tought me to buy only donor boards or from reputable component stores.
                I hope this will be helpful to anyone else having similar issues with coil whines or psu failing under load.
                • speggio91
                  • Apr 2020
                  • 83
                  • Italy
                  #28
                  EDIT 2:
                  putting the power supply back on the PS4 and trying to power it on, lead to the same issue of not powering on. After pressing the power button the blue led light on for a second and the it shut down.
                  The PS4 is fine, it works with another known good PSU.
                  I guess there is more issue to uncover on the faulty psu.
                  • speggio91
                    • Apr 2020
                    • 83
                    • Italy
                    #29
                    FINAL UPDATE ON MY CASE:
                    replacing the IC 41 (NCP1608) from a donor board made the power supply able to sustain the load and power on the PS4.
                    Be careful when you buy chips from ebay or alexpress guys.
                    • playgoods
                      • Jan 2014
                      • 18
                      • South Africa
                      #30
                      Could you please help identify this component in the ps4 power supply diagram. I just know it's some kind of voltage supervisor ic but different ps4 psu's have different markings on the same component. I'm trying to find the manufacturer part number.
                        • 31066
                        it's a mosfet transistor.
                        • playgoods
                          • Jan 2014
                          • 18
                          • South Africa
                          #32
                          It is something like a max809 ic.
                          https://www.google.com/url?sa=t&sour...qmF-RbXLOtZ1kK
                            SHUTTLE XPC slim DX30 XPC slim J3355 Specification for Upgrade or Repair
                            This specification for the SHUTTLE XPC slim DX30 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim DX30 boardview and XPC slim DX30 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for SHUTTLE...
                            09-12-2024, 03:30 PM
                            HP Slim Desktop S01-aF0010ns Slim Desktop J4005 Specification for Upgrade or Repair
                            This specification for the HP Slim Desktop S01-aF0010ns can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0010ns boardview and Slim Desktop S01-aF0010ns schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-12-2024, 03:28 PM
                            SHUTTLE XPC slim DH110SE XPC slim i5-7500 Specification for Upgrade or Repair
                            This specification for the SHUTTLE XPC slim DH110SE can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim DH110SE boardview and XPC slim DH110SE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            HP Slim Desktop S01-pD0117d Slim Desktop i3-8100 Specification for Upgrade or Repair
                            This specification for the HP Slim Desktop S01-pD0117d can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-pD0117d boardview and Slim Desktop S01-pD0117d schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            HP Slim Desktop S01-aF0017ns Slim Desktop S01 3250U Specification for Upgrade or Repair
                            This specification for the HP Slim Desktop S01-aF0017ns can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0017ns boardview and Slim Desktop S01-aF0017ns schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
