PLP-60-48 Single Output LED Power Supply - "chirping" noise
  • tester001
    Tony
    • Dec 2023
    • 24
    Dear Badcaps forum members,
    Hope that you are all well!
    I am a newbie on a mission to figure out the cause of the PSU making a "chirping" noise:
    Having searched for this symptom online I have found some indication that failed capacitors may be an issue. To help with the troubleshooting, I have tried to isolate the problem and disconnected the PSU from the rest of the device - the chirping remained.
    I have then found that the whole PSU (apart from a small add-on board) can be replaced, and there is even a datasheet for it: https://cdn.badcaps-static.com/pdfs/...72e3c7c9cd.pdf
    I then removed the small add-on board and the PSU started without chirping:
    The output should have been 48V, but I don't know what to make of this reading (is it even indicative of the PSU health? perhaps only putting a proper load on it can tell).
    Once I re-attach the small add-on board (even without connecting the full load!) the chirping returns:
    The white terminal on this board connects to the PSU output and the red/black wires then feed the actual device.
    What could this behaviour mean? Is the problem in the add-on board? Can the presence of the add-on board create a sufficient load for the problem in the PSU to manifest itself?
    Thank you in advance!
    Tony
    • 30997
    the small board may regulate the current.
    it's a fixed but ajustable current supply, so the voltage can move around a bit.
    i would test the supply without the small board by using a light bulb - 25w or 40w, as it's only rated to 60w.
    a old style filament lamp - not a halogen or led etc.
    • tester001
      Tony
      • Dec 2023
      • 24
      Thank you for the suggestion! You mean a 48v/25W filament light bulb would do for the test, correct? Does it have to be a 48V bulb or any filament bulb between 25-40W?
        • 30997
        240v is fine - only the wattage matters
        • tester001
          Tony
          • Dec 2023
          • 24
          I've connected the output of the PSU to an old projector bulb (8V 50W) and got the "chirping" again!
          Click image for larger version  Name:	image.png Views:	0 Size:	1.18 MB ID:	3158934
          Do any caps on this PSU look like they need replacement? If not, should I desolder them one-by-one and test using a capacitor meter?
          Click image for larger version  Name:	image.png Views:	0 Size:	225.0 KB ID:	3158936
          Click image for larger version  Name:	image.png Views:	0 Size:	267.4 KB ID:	3158937
          Click image for larger version  Name:	image.png Views:	0 Size:	1.27 MB ID:	3158938
          Thank you for your help so far! Happy to carry out more tests and learn
          • tester001
            Tony
            • Dec 2023
            • 24
            I have no clue of what I'm looking for, but I used the search on this website and found this:
            Does this mean that the pictured caps are bad and should be replaced?
              • 30997
              8v lamp on a 48v supply?
              i'm kind of glad it didnt work or you would be sweeping up glass!
              you cant tell if a cap is good by looking, and YXF is low end for a psu - i would be using rubycon ZL or panasonic FR
              • tester001
                Tony
                • Dec 2023
                • 24
                I read your '240v is fine - only the wattage matters' as 'voltage doesn't matter'
                Thank you, I will de-solder them and get them tested (will check online for methods)
                • CapLeaker
                  Leaking Member
                  • 8132
                  Usually a chirping in the power supply means there is something shorted in the secondary, as the PSU starts, shuts down, starts again and shuts down again. Over and over, wash rinse, repeat.
                  • tester001
                    Tony
                    • Dec 2023
                    • 24
                    Sorry, I'm a total newbie. What does 'shorted in the secondary' mean?
                    • CapLeaker
                      Leaking Member
                      • 8132
                      The low voltage side of the power supply. Just saying IF there is something wrong in the primary, it would have exploded in your face or there is an open circuit somewhere and is dead as a rock.
                      So the primary side works. The low power secondary has something wrong with it, Where does this little board hook up to… looks like into the secondary somewhere, as it got DC leads….
                      • tester001
                        Tony
                        • Dec 2023
                        • 24
                        It's an LED driver PSU
                        I've just tested the two 63V 470 uF capacitors:
                        one is reading 400 uF
                        the other 410 uF
                        Would this be sufficient to cause the described fault?
                          sam_sam_sam commented
                          Editing a comment
                          Did you test the capacitors off the board if not then remove them from the board and retest them
                        • 30997
                        in english - check the output diode
                        • tester001
                          Tony
                          • Dec 2023
                          • 24
                          Thank you very much! After reading up more about the subject I found a diode next to the capacitors and it failed basic diode tests (wasn't passing current in any direction)
                          Datasheet: https://cdn.badcaps-static.com/pdfs/...1c6b8e6590.pdf
                          Shall I try to replace the fast recovery diode and put the capacitors back? Is it OK for 63V 470 uF capacitors to be reading 400 uF and 410 uF​?
                          Thanks again!
                            • 30997
                            test the diode off the board,
                            if it's still bad then obviously replace it.
                            as for the caps, it really depends - if this is going somewhere hard to reach then it's better to replace the caps now than later.
                            but if it's easy to get to then i suppose it doesnt matter
                            • tester001
                              Tony
                              • Dec 2023
                              • 24
                              Something strange happened. I've been testing continuity with a Fluke meter and couldn't get any current flowing through the diode no matter how I connected the probes (in case I mixed up the polarity):
                              Then a colleague tested the diode with this thingie and it now works correctly on Fluke too:
                              So I'm back to situation where no components explicitly show as broken. But I think I may be getting the hang of the game: desolder and test everything..
                              Thank you for your continued help.
                              • CapLeaker
                                Leaking Member
                                • 8132
                                If diodes fail, they like to fail short. The best way to test any component is to check it out of circuit.
                                  • Jul 2011
                                  • 6037
                                  Click image for larger version  Name:	photo_2023-12-06_12-28-36.jpg Views:	479 Size:	199.8 KB ID:	3158286
                                  Click image for larger version  Name:	photo_2023-12-06_12-38-01.jpg Views:	44 Size:	58.9 KB ID:	3158287
                                  Tony
                                  I would focus on this little board
                                  Check the input pins ( the white pin connector) for a short if you find any thing lower than 500 ohms I would suspect I would go through the whole board what is the part number on the ic chip that has 4 pins on it would be the first thing I would check google search the part number to see what this device does and post it here so we can look at it as well
                                  Also what is the part number on the other ic chip that has 10 pins on it
                                  The voltage on the main board might be alright a few volts below because either it has no feedback which might come from the small board or this board needs a load on it to work correctly
                                  One way to check the main board for weather or not it is functioning correctly is to get 4 automotive tail light bulbs and wire them in series and see if the power supply complaint about its load if not then definitely focus on the little board for this issue that you have with it
                                  Can you please take another picture of the small board straight on and focus on the lettering so the image is clear so I can see the other components on the board thanks
                                  One note I am really interested in this little board to know what it's function is and how and what it does to the main board and how it effects the output of the main board ( my hunch is that it is the current controller board ) because the description of this switching power supply says that you are adjusting the current output
                                    • 30997
                                    i think the small board is a current regulation circuit.
                                    • tester001
                                      Tony
                                      • Dec 2023
                                      • 24
                                      I think you are right, as I have just received a replacement PSU and I get the following results with it:
                                      PSU plugged into the mains and switched ON - no chirping
                                      little board soldered on - chirping starts
                                      It is 290 Ohms!
                                      02680
                                      PEm
                                      1551 B3
                                      6123
                                      I can't find the datasheet, but it appears to be something like this:
                                      54F4
                                      5022
                                      Thank you for recommendation. Could I get away with connecting a 220v domestic filament light bulb to it?
                                      Straight on the light was bouncing off, but I've managed to get the writing on the components in photos above. Here's an overall view:
                                      Thank you for your help!
                                      • FrancescoV
                                        Onkyo HT-R390 no sound output, video output ok
                                        by FrancescoV
                                        Good morning everyone,
                                        I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                        The firmware reported is the following:
                                        M:1.00/11107BLP
                                        D:?.??/????????
                                        O:1.00/11107AL
                                        The DSP firmware given the question marks seems corrupt.
                                        On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                        05-11-2025, 02:59 AM
                                        NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                        by sam_sam_sam
                                        I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                        I bought this from an eBay seller but unfortunately they only had one
                                        I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                        I bought three of from them to also make battery packs with this output power limit in mind
                                        I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                        04-23-2025, 05:50 AM
                                        Corsair CX750M [Model 75-002019] - burned output toroid inductor
                                        by momaka
                                        Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                                        So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                                        09-19-2021, 08:44 PM
                                      • Francesc V.
                                        Tele-master AS-20 amplifier. No output sound, just noise
                                        by Francesc V.
                                        Hi:
                                        I bought this amplifier from the 70s to try to repair it. So far it has no output sound, just noise. You can volume it up and down.
                                        I've checked fuses and all are ok.
                                        I've continued with capacitors:
                                        • The main black one should have 4700uF, but it has lost half of its capacity during these years.
                                        • The ones that I've numbered have still a really low ESR and the full capacity after ¿40 years?
                                        The 4 transitors are perfect. Desoldered and tested individually.
                                        There are also components which I don't know exactly what they are....
                                        02-16-2023, 07:55 AM
                                      • MegaZAC
                                        Onkyo TX-SR805 noise in one channel
                                        by MegaZAC
                                        Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                        Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                        There's some logic behind it. As soon as I select an input I get only left...
                                        04-23-2025, 10:09 PM
