ATX PSU, 13.8v
  • dimitris1977
    • Oct 2014
    • greece
    #41
    Re: ATX PSU, 13.8v
    Originally posted by Pinhead
    I haven't had trouble increasing the voltage on this supply; it is stable at 14v using a single variable resistor, though admittedly it won't go much higher. The supply uses an ATX-2005Z PWM Controller which has the ability to monitor the 3.3v, 5v, and 12v rails.
    Ripple voltage on the output is well within acceptable limits, <20mv at idle and <75mv under a steady load. Problems only arise when the load is extremely transient and knocking on 15 amps, as in the case of transmitting in SSB mode.
    i have 2005z, what single variable resistor have you use and where did you conect it to increase the voltage?
    • oa4asd
      • Sep 2015
      • Perú
      #42
      Re: ATX PSU, 13.8v
      i have the same cuestion!!! and the same ic...
        • 30932
        Re: ATX PSU, 13.8v
        if you have a pulsed load, increase the capacitors to handle more ripple - a lot more!
        • Pinhead
          • Nov 2013
          • 28
          Re: ATX PSU, 13.8v
          http://boginjr.com/electronics/lv/atx-mod/
          • SURYA2K
            • Jun 2017
            • India
            #45
            I had the same chip 2005z in my smps, can somebody give schematic of modifications to get 13.8v output.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • Victor Moreira Silva
              Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
              by Victor Moreira Silva
              I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
              Well, my decice specs are the following:
              Model: Acer Nitro 5 AN517-54-55T5
              CPU: Intel Core i5-11400H
              GPU: NVIDIA GeForce GTX 1650
              Motherboard: GH51G LA-L181P Rev:1c
              The symptom:
              When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
              05-26-2025, 10:49 AM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
              03-31-2024, 02:12 PM
