iMAC G5 PSU (again.. sigh)!
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    Manu - AcBel
    http://www.acbel.com.tw/eng
    Model - API4PC46
    Apple P/N - 614-0326
    System unit stuck on LED1
    Will not start
    Removed PSU, recapped
    Tested PSU out of unit post recap
    On standby
    1 : +0.028 VDC (Black)
    2 : +0.028 VDC (Black)
    3 : +0.000 VDC (Black)
    4 : +0.009 VDC (Grey/Purple)
    5 : +0.000 VDC (Black)
    6 : +0.009 VDC (Grey/Purple)
    7 : +0.000 VDC (Black)
    8 : +0.000/1 VDC PG (Blue) - swings between these two values
    9 : +5.196 VDC 5VSB (Purple)
    10 : +0.025 VDC (Brown)
    11 : +0.000 VDC (Black)
    12 : +0.028 VDC (Black)
    13 : +0.025 VDC (Brown)
    14 : +0.000 VDC (Black)
    15 : +5.196 VDC On/Off (Grey)
    16 : +0.000 VDC (Black)
    17 : +0.000 VDC (Black)
    18 : +0.000 VDC (Black)
    19 : +0.025 VDC (Brown)
    20 : +0.009 VDC (Grey/Purple)
    21 : +0.009 VDC (Grey/Purple)
    22 : +20.42 VDC (Brown)
    Jumpered 15-16
    1 : +3.332 VDC (Black), ripple 4.7mV VAC
    2 : +3.332 VDC (Black), ripple 4.7mV VAC
    4 : +5.145 VDC (Grey/Purple), ripple 36.8mV VAC
    6 : +5.145 VDC (Grey/Purple), ripple 36.9mV VAC
    8 : +0.079 VDC PG (Blue), ripple 3.5mV VAC
    9 : +5.196 VDC 5VSB (Purple), ripple 3.8mV VAC
    10 : +11.970 VDC (Brown), ripple 149.9mV VAC
    12 : +3.332 VDC (Black), ripple 4.5mV VAC
    13 : +11.970 VDC (Brown), ripple 3.5mV VAC
    15 : +0.000 VDC On/Off (Grey), ripple 3.5mV VAC
    19 : +11.970 VDC (Brown), ripple 98.3mV VAC
    20 : +5.135 VDC (Grey/Purple), ripple 32.6mV VAC
    21 : +5.135 VDC (Grey/Purple), ripple 32.8mV VAC
    22 : +23.530 VDC (Brown), ripple 270mV VAC
    Is PG 8 correct for this type of PSU?
    Anyway, put PSU back in the unit.
    Same problem, still only LED.
    Unit logic board has 1 domed 6.3V 1800uF Nichicon on the VRM O/P.
    Took the PSU out again.
    Now cannot get the PSU (15-16) to start again.
    Odd...
    Suggestions...
    Q1 on the PSU? Why would it just let go?
    Are there TopSwitches in these?
    Advice appreciated.
    Thx
  • Toasty
    • Jul 2007
    • 4171
    Re: iMAC G5 PSU (again.. sigh)!
    Have to fix the mainboard. That's the problem. All those Nichi's have to go. TC sells a kit, I think.
    Reduce the reports down to the basics. Every wire is not necessary.
    Look at the board and see what goes where.
    Essentially, you have 5vsb, 24vsb, ground(blacks), +3.3, +5, +12.
    If 5vsb is up, then you have 1/2 the battle solved.
    Topswitch is a -VERY RARE- failure. (how's that for a subtle hint)
    If 5vsb is there, the TOP is fine.
    Check Q1 and ZD6. What is the SB voltage @ Q1 collector?
    Have you recapped the unit, especially the 4 next to the mains caps?
    Search the forums for these either by 4PC46 or API4PC46.
    T
    veritas odium parit
    • JEWilson
      • Sep 2007
      • 369
      Y - recapped the PSU
      All of them except the main large can lytics for the primary and PFC
      Someone had been there before me - did part of the job
      Funny, post recap
      Got the unit to start (with 15-16 jumpered)
      Now it won't - very odd....
      So will check Q1 and ZD6 - thx
      Does the earth tag in the PSU need attachment to the PSU case?
      It was not with this PSU
      Will get the PSU right before the logic board recap
      Will check the posts as recommended
      • Toasty
        • Jul 2007
        • 4171
        >> Does the earth tag in the PSU need attachment to the PSU case? <<
        Not sure what you mean by that question.
        If you mean the ground wire coming from the socket, then yes. Once the board is installed back in the case, that wire goes to the PSU case on the nearby tab.
        Your voltages all look(ed) good.
        Need that collector voltage on Q1 at standby. ~16v
        Make sure you're measuring from the HOT side (-)
        T
        veritas odium parit
        • JEWilson
          • Sep 2007
          • 369
          Update
          This unit had a bad Q1
          I replaced D2 and ZD6 anyway
          Replaced Q1 with a 350mW part
          Seems to be ok again
          Now... load testing
          Any thoughts on using an ATX go/no go PSU tester
          with the cables mapped to the Apple PSU?
          Ok... before people start saying no; this is just for
          future use with these PSU, before, that is,
          I get my hands dirty
          How would you handle 24V on an ATX tester
          • Toasty
            • Jul 2007
            • 4171
            Parts used? Numbers? Supplier?
            You could rewire the connector I'm sure. Or make up a "patch" one to use it on either. Grab the male connector from an old mobo and the female from a trash PSU and wire it for the Apples.
            The 24v would be a matter of a resistor or Zener with a LED or 2. Remember that on some of these, the 24v line doesn't come up full until the unit is running. It sits around 19-20v in standby.
            T
            veritas odium parit
            • JEWilson
              • Sep 2007
              • 369
              Ok
              Zener ZD6 - NXP BZV55-B16,115, Mouser P/N - 771-BZV55-B16115
              Diode D2 - Fairchild FDLL4148_D87Z, Mouser P/N - 512-FDLL4148D87Z
              Transistor Q1 - Fairchild MMBT2222A, Mouser P/N - 512-MMBT2222A
              Thx
              • Toasty
                • Jul 2007
                • 4171
                Have you been using that Zener with success?
                T
                veritas odium parit
                • JEWilson
                  • Sep 2007
                  • 369
                  Well....
                  This is the first time I have used this part
                  So.. we will see if it does the trick
                  Will do load testing and see how this plays out
                  Have another of the same PSU model (and got a working delta)
                  What would you typically use for ZD6?
                  • Toasty
                    • Jul 2007
                    • 4171
                    I was curious as to how you arrived at a 16v zener. Did you test a good part or go by the color coding?
                    T
                    veritas odium parit
                    • JEWilson
                      • Sep 2007
                      • 369
                      No code
                      No Test
                      Took your word for it (found it in the forum)
                      Thx
                        HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                        This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                        09-12-2024, 02:00 PM
                        MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black N4000 Specification for Upgrade or Repair
                        This specification for the MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi N 8GL-063DE/N4000/4GB/W10P/Black boardview and Cubi N 8GL-063DE/N4000/4GB/W10P/Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                        09-12-2024, 01:58 PM
                        Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                        This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        09-07-2024, 05:00 AM
                        Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                        This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-07-2024, 04:10 AM
                        LG Gram LG gram 16Z90P-K.AA85A1 16GB_512GB - Black Notebook Specification for Upgrade or Repair
                        This specification for the LG Gram LG gram 16Z90P-K.AA85A1 16GB_512GB - Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LG gram 16Z90P-K.AA85A1 16GB_512GB - Black boardview and LG gram 16Z90P-K.AA85A1 16GB_512GB - Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                        09-07-2024, 03:40 AM
