I would have left them if they were standing up but I don't think they'd stay cool enough like that
Replacing 4 diodes with a bridge
Re: Replacing 4 diodes with a bridge
You guys have good points, and they probably don't care either wayLeave a comment:
They're easier to ship and package that way, take less space.
Easier to handle in the factory.
Can be reused in other designs where there are tall parts near the heatsinksLeave a comment:
Because it adds about a tenth of a cent worth of wear to the machine! Think about it: if they make 10,000 units, that's an entire TEN DOLLARS that they save!Leave a comment:
Not bad. I always bend those fins outwards too. The stock configuration is hopeless for getting airflow between the two rows of fins.Leave a comment:
Was pretty frustrated, I went to put those MBR20100CT's in the PSU, even had them bolted to the heatsink and the legs were too short on them
So I left the original one....
Here is the final picture with the new diode, a Panaflo DC Brushless fan, the new caps (Except the -12V and -5V) and I also bent the fins on the heatsinks outwards, I think they will cool better this way. Now hopefully this thing can last in a computer
I only trust it up to 200W for long periods of time
Attached Filesif you find these attachements useful please consider making a small donation to the site
Or just worked with a very low load? I hope Khron is right in the fact that the reverse voltage is a little lower but shouldn't affect it. After recapping it I plan on replacing the TOBA MUR1620CT with two MBR20100CT's in parallel to reduce some of the heat on that little heatsink...Last edited by Pentium4; 04-24-2013, 03:29 PM.Leave a comment:
Um, wtf. Maybe it was somehow being rectified some way, but not well.Leave a comment:
Thanks for the replies
Really? Because it got 5VSB but wouldn't power up. I will see how it goes! The SB540 is mounted to a little heatsink that should help
Edit: Woohoo it powers up now!
Now I can continue modifying it in confidence
40V vs 60V reverse voltage rating shouldn't be much of a problem, in this case. Judging by the location next to the 5Vsb transformer, i'd say it's a safe bet this is the 5Vsb rectifier
I had suspicions about this diode being shorted so I took it out and it measured 1.3Ω both ways and it diode check mode it reads 0 both ways, is it bad? It's an SB560 diode. And I have an SB540, would that be a suitable replacement?Attached Filesif you find these attachements useful please consider making a small donation to the site
Haha, thanksNot sure what your plans for that PSU are Pentium4, but it appears to be very similar (although slightly cheaper judging from the heatsinks) to this one I rebuilt a while back if you want some ideas.
https://www.badcaps.net/forum/showth...hlight=gutless
Hey, thank you very much for the link, i wish mine had heat sinks like yours
link directly to the rebuild post:https://www.badcaps.net/forum/showpo...93&postcount=8
Yeah, I will for sure replace all the caps in this thing! I don't trust any of the ones that came in itHi P4
the cap that is in it is only rated at 85 deg so I would up grade to 105 deg the peak esr 70 is showing that the cap is within spec (ie 20%+or-)
I would replace it anyway where there any other components blown it the primary side of this PSU? if so you will need to replace them as well then you need to check the secondary side.
Good luck with your project.
I will keep this thread updated
Hi P4
Good luck with your project.Leave a comment:
Can you please stop hijacking P4's thread?
You can buy it directly from PEAK, like I have done. They ship very fast.
And yes, I love my ESR 60 analyser...
http://www.peakelec.co.uk/acatalog/jz_esr60.htmlLast edited by Tube_Dude; 12-30-2012, 08:18 AM.Leave a comment:
by Ross KohlerHi,
I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
- There's no sign of any attempt to power on when pushing the power button.
- No PSON signal is reaching the 24-pin ATX connector.
- The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
- The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
- If I pull the Super IO S_SLPS#_R pin... -
by DvsrHi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
After replacing the caps I started testing out the speaker. It seemed...4 Photos-
09-10-2025, 10:20 AM -
by _AcE_I have two of these soundbars, both with the exact same issue. The soundbars were hit by lightning and no longer power on. The PSU does not output any voltage on the DC side. When plugged into mains, the DC output is a stone-cold 0.0 volts. The AC side of the PSU seems to be functioning correctly (as far as I can tell). When checking the plugged-in PSU with my thermal camera, the OB5269CP PWM controller (U1) and the two resistors (R12 and R13) pulse on and off. These run to the positive DC side of the bridge rectifier (among other components along the way).
There's no physical damage... -
by caspianDear members,
I have a linear variable power supply with unknown brand name that I used for voltage injection.
Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
In addition, I discovered that its zener diodes are defective.
I can replace the burned transistors.
But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
Therefore, I cannot replace the zener diodes.
I do not want to test the zener diodes in a test circuit to discover their model or value.
no schematics are available... -
by Roman555Bad symptoms when Ivy Bridge CPU (3rd-gen 22nm) is installed:
- Won't boot OS (just blank screen or stucks at asus logo, monitor is turned on) with hangs at debug (post) code A3;
- USB stick with MS-DOS can be loaded via F8 boot menu;
- Other OSes won't load - hangs or goes reboot;
- Postponed for several seconds reaction to Alt-Ctrl-Del, Reset and Power buttons;
- An operating system starts loading but won't finish if it's left only 1 CPU core in BIOS settings;
- Cleared CMOS many times;
- Flashed different versions of BIOS in a CH341 programmer;
- Updated
- Loading...
