Replacing 4 diodes with a bridge
  • Pentium4
    replied
    Re: Replacing 4 diodes with a bridge
    I would have left them if they were standing up but I don't think they'd stay cool enough like that
  • ben7
    replied
    Originally posted by Pentium4
    Another 4 diode replacement... just wanted to double check to make sure this is correct
    Yep it's correct.
  • Pentium4
    replied
  • Pentium4
    replied
    You guys have good points, and they probably don't care either way
  • mariushm
    replied
    They're easier to ship and package that way, take less space.
    Easier to handle in the factory.
    Can be reused in other designs where there are tall parts near the heatsinks
  • cheapie
    replied
    Thanks, I'm glad you approve! I don't understand why they don't do that from the factory
    Because it adds about a tenth of a cent worth of wear to the machine! Think about it: if they make 10,000 units, that's an entire TEN DOLLARS that they save!
  • Pentium4
    replied
    Originally posted by c_hegge
    Not bad. I always bend those fins outwards too. The stock configuration is hopeless for getting airflow between the two rows of fins.
  • c_hegge
    replied
  • Pentium4
    replied
    Was pretty frustrated, I went to put those MBR20100CT's in the PSU, even had them bolted to the heatsink and the legs were too short on them So I left the original one....
    Here is the final picture with the new diode, a Panaflo DC Brushless fan, the new caps (Except the -12V and -5V) and I also bent the fins on the heatsinks outwards, I think they will cool better this way. Now hopefully this thing can last in a computer I only trust it up to 200W for long periods of time
  • Pentium4
    replied
    Or just worked with a very low load? I hope Khron is right in the fact that the reverse voltage is a little lower but shouldn't affect it. After recapping it I plan on replacing the TOBA MUR1620CT with two MBR20100CT's in parallel to reduce some of the heat on that little heatsink...
  • ben7
    replied
    Thanks for the replies Really? Because it got 5VSB but wouldn't power up. I will see how it goes! The SB540 is mounted to a little heatsink that should help
    Edit: Woohoo it powers up now! Now I can continue modifying it in confidence
    Um, wtf. Maybe it was somehow being rectified some way, but not well.
  • Pentium4
    replied
  • Khron
    replied
    40V vs 60V reverse voltage rating shouldn't be much of a problem, in this case. Judging by the location next to the 5Vsb transformer, i'd say it's a safe bet this is the 5Vsb rectifier
  • ben7
    replied
    I had suspicions about this diode being shorted so I took it out and it measured 1.3Ω both ways, is it bad? It's an SB560 diode
    Yep, it indeed is bad.
  • Pentium4
    replied
    I had suspicions about this diode being shorted so I took it out and it measured 1.3Ω both ways and it diode check mode it reads 0 both ways, is it bad? It's an SB560 diode. And I have an SB540, would that be a suitable replacement?
  • Pentium4
    replied
    Originally posted by dmill89
    Not sure what your plans for that PSU are Pentium4, but it appears to be very similar (although slightly cheaper judging from the heatsinks) to this one I rebuilt a while back if you want some ideas.
    https://www.badcaps.net/forum/showth...hlight=gutless
    Hey, thank you very much for the link, i wish mine had heat sinks like yours
    link directly to the rebuild post:https://www.badcaps.net/forum/showpo...93&postcount=8
    Originally posted by ben7
    Can you please stop hijacking P4's thread?
    Haha, thanks
    Originally posted by popeye
    Hi P4
    the cap that is in it is only rated at 85 deg so I would up grade to 105 deg the peak esr 70 is showing that the cap is within spec (ie 20%+or-)
    I would replace it anyway where there any other components blown it the primary side of this PSU? if so you will need to replace them as well then you need to check the secondary side.
    Good luck with your project.
    Yeah, I will for sure replace all the caps in this thing! I don't trust any of the ones that came in it I will keep this thread updated
  • popeye
    replied
    Yeah! Here is the before and after, and a pic of a typical Chinese cap lying about the specs! I think maybe some of the little caps on the 5VSB are bad because this thing has no signs of life. I will work on it more on the 31st and hopefully get it going
    Hi P4
  • TELVM
    replied
    Ouch, my apologies.
  • ben7
    replied
  • Tube_Dude
    replied
    Originally posted by TELVM
    Man that capacitance/ESR gadget is exactly what I'm looking for ! Where can I get one of these? How much does it cost?
    You can buy it directly from PEAK, like I have done. They ship very fast.
    And yes, I love my ESR 60 analyser...
    http://www.peakelec.co.uk/acatalog/jz_esr60.html
  • Ross Kohler
    Diagnosing South Bridge (FH82H370) on Asus H370-Pro Gaming Motherboard
    by Ross Kohler
    I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
    - There's no sign of any attempt to power on when pushing the power button.
    - No PSON signal is reaching the 24-pin ATX connector.
    - The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
    - The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
    - If I pull the Super IO S_SLPS#_R pin...
    04-16-2024, 09:36 AM
  • Dvsr
    On M-Audio AV40 active studio speaker's two zener diodes get really hot.
    by Dvsr
    Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
    I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
    After replacing the caps I started testing out the speaker. It seemed...
    09-10-2025, 10:20 AM
  • _AcE_
    JBL Soundbar 2.1 Deep Bass PSU No DC Power Output (Detailed, w/ Schematics)
    by _AcE_
    I have two of these soundbars, both with the exact same issue. The soundbars were hit by lightning and no longer power on. The PSU does not output any voltage on the DC side. When plugged into mains, the DC output is a stone-cold 0.0 volts. The AC side of the PSU seems to be functioning correctly (as far as I can tell). When checking the plugged-in PSU with my thermal camera, the OB5269CP PWM controller (U1) and the two resistors (R12 and R13) pulse on and off. These run to the positive DC side of the bridge rectifier (among other components along the way).
    There's no physical damage...
    08-10-2025, 09:27 AM
  • caspian
    What Zener Diodes on a Linear Power Supply
    by caspian
    Dear members,
    I have a linear variable power supply with unknown brand name that I used for voltage injection.
    Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
    In addition, I discovered that its zener diodes are defective.
    I can replace the burned transistors.
    But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
    Therefore, I cannot replace the zener diodes.
    I do not want to test the zener diodes in a test circuit to discover their model or value.
    no schematics are available...
    05-26-2025, 12:38 PM
  • Roman555
    Asus H77 LGA1155 mainboard stopped working with Ivy Bridge CPUs
    by Roman555
    Bad symptoms when Ivy Bridge CPU (3rd-gen 22nm) is installed:
    • Won't boot OS (just blank screen or stucks at asus logo, monitor is turned on) with hangs at debug (post) code A3;
    • USB stick with MS-DOS can be loaded via F8 boot menu;
    • Other OSes won't load - hangs or goes reboot;
    • Postponed for several seconds reaction to Alt-Ctrl-Del, Reset and Power buttons;
    • An operating system starts loading but won't finish if it's left only 1 CPU core in BIOS settings;
    What I've already done and it hasn't helped:
    • Cleared CMOS many times;
    • Flashed different versions of BIOS in a CH341 programmer;
    • Updated
    01-18-2024, 06:26 AM
