Re: Cheap PSU: Piece of junk or semi-decent?
didnt remember you mentioning a 100v part.
hell a 50v would give plenty of margin.
I'm confused now ... :
... i doubt you need anywhere near 100v though.
i like twice the output voltage.
vf is lower on lower voltage parts so less heat ...
https://www.badcaps.net/forum/showthread.php?t=3759Leave a comment:
(Most amazingly) my switcher swap looks like a success.
No explosions and the PSU seems to work OK giving coherent voltages.
Next I'm going to swap the +12V rectifier diode, let's see if lowering the Vrrm brings fireworks or not ...
.Leave a comment:
Oh, roger, two Panny FC are underway.
"Electros" = short for "Electrolytics". So yes, those two is what he was talking about.Leave a comment:
Miniature long- and needle-nose pliers are excellent for removing and replacing the screws and insulators for the power transistors.
Something like this, but with less bulky handles:
http://www.harborfreight.com/6-piece...set-94931.htmlLeave a comment:
I always unsolder the whole heatsink, saves a lot of sweat.Leave a comment:
Would a couple Panasonic EE-TS 800uF 200V 105C 22x50mm Ripple=3.08 ESR=0.15 do the job OK?Leave a comment:
So yeah, the 12V rectifier is probably the only thing you need to upgrade.Leave a comment:
Thanks a lot pals .
One last detail if you don't mind. To replace this crap:
I think that 60 V is usually suggested minimum for +12 V rail and STMiro part should not have any problem with that…
Just a notice, you should compare under same circuimstances. MBR has voltage drop specified as maximum at 10 A/25 °C. STPS has 0,405 V on the frontpage, but it is typical under different circuimstances. Under same conditions, it is 0,535 V. So be aware of that, quite often you can find parts are not that impressive as they seem on first view.Leave a comment:
My guess is that it will be ok.Leave a comment:
Thanks c_hegge .
I'm also thinking on beefing up the +12V rectifier:
If '20150CTP' is something like the MBR20150CTP, it is a Schottky 20A, Vrrm=150, Vf=0.9 .
How about replacing it with a STPS40SM60CT? Double the amps and half the Vf. Would lowering the Vrrm from 150 to 60V make it go?
Yup, it would do fine as well.Leave a comment:
As implausible as it sounds, both pieces of junk starring in this thread are still alive & kicking and stubbornly keep working like a charm.
The 'TOOQ' thing, complete with with its world famous ghetto-modded secondary PI coils, is now propelling a P4 Preshott overclocked to a non trivial 4.25GHz
Most amazingly the 'TOOQ' hasn't exploded yet. But judging from the tropical heat that comes from PSU rear and the 311W from the wall that the Kill-a-Watt shows at full Preshott burner (311 x 0.8 = ~250W DC) it must be on the very edge of
So I think the time has come to plunge into more serious PSU tinkering: The black art of switchers and rectifiers replacement.
The 'TOOQ' thing has this on the primary:
I think the 8A 13007s could perhaps be replaced with 12A 13009s.
The MJE13009G is out of catalog in Farnell. How about the Fairchild FJP13009H2TU, could it do the job?
.Leave a comment:
That thing looks GREAT!I can't help but not trust those Cheng caps though, and if they are really as much uF as they claim. Wouldn't want them limiting your awesome mods
can anyone tell whether ive knackered this from the photos. In relation to black piece of something that appears to left in component in image with 156 at the end ?...05-11-2025, 05:13 PM
by antibotandaxktdmb8c0
Maybe someone has a photo of a section of the board, otherwise there are no diagrams or boardview... -
by desone01Hi Everyone,
I was hoping some kind individual could provide a copy of the bios bin file for this desktop computer. I have a CH341A eprom burner. I managed to read the file and copy it back again, however, this did not fix it. The computer powers up but won't boot so the bios update program is of no use to me.
The full details of the particular model are: Compaq Presario CQ3430AN
I am attempting to repair this piece of junk for a friend of mine.
I told my friend to NEVER buy such a piece of junk in the future. HP Compaq support is virtually...-
by DevonavarI have a Vizio M43-C1 stuck in a reboot loop with no backlight.
I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
So, I've ruled out the PSU for now.
The reboot loop... -
by RotsingerSo the 16v 1500uF capacitor C9B1 near the power connector on the back of a Phat started leaking. Haven't been able to find the right cap, so I replaced it with a larger 25v 2200uF capacitor a couple weeks ago and everything is working fine since then. I didn't replace the other six 16v caps, they were all good.
When putting the fan plastic cover back I remember there were maybe 2-3 mm of clearance on top of it and 1-2 mm of clearance to the side of it.
For those that don't remember what the fan cover looks like I found this picture https://cdn.quade.co/wp-content/uploads/2... - Loading...
