The ZUA (KN4401S) transistor on the rear side of the vertical control board is bad - missing B-E junction.
Delta DPS-800GB Power Supply No Power
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by dragon3xHi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
that is still quite new, as it worked OK for some months until it failed.
At the time I was not into power supply electronics; it was put
aside and a new power supply installed inside the computer. Also at the time
power supplies were half the price of today's.
On the PCB there are a D339 and 7500B chips.
I have found that schematics with these 2 chips (see included file).
Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
Some measurements,... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
- Loading...
