Out of spec 12v and 5v. Recommendations?
  • MixMasta
    • Feb 2006
    • 142
    Re: Out of spec 12v and 5v. Recommendations?
    Originally posted by MixMasta
    Guess I will remove these caps I wasted my time putting on cause I don't know how to fix this problem... what a waste.
    Actually, is there a vsense wire or anything for the 5v and 12v... and if so, are they visible in the above pictures?
    • starfury1
      • May 2006
      • 1256
      Hi All
      Ok can't help you with the chip 20 pin humm maybe a custom job?
      or more likely a standard job they removed the numbers off
      If you have done as suggested above and still no go
      I had a few supplies I repaired a while back so can't recall the full story.
      So don't know what chip they used
      The problem was they were not regulating under load, if memory serves me
      Anyway.
      Turns out the answer was a 10uF cap near the controller chip
      (part of the circuit some how....old age memory fading LOL)
      These were smpsu. for very large printers
      So if you haven't check and or replace the lower values around the controller chip...as you say most likely that big baby.
      Thats my wet finger in the air reply and not the voice of experience....
      but hope it helps......
      not familiar with these supplies so cant really be of much help.
      Didn't read through the whole post so I may have missed something
      You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        since it seems you have several different units acting up i bet its a combination of insufficiant load and an inaccurate meter.
        if you want to ship these units to me i can fix them up.
        but i suggest you get a way to load these units and buy or borrow another meter first.
        • MixMasta
          • Feb 2006
          • 142
          I appreciate the offer, however I have two meters which show the same readings within .02v and the supply is under load, which I mention on my post to this thread from 01-16-07. Also, all the other supplies I mention have been successfully recapped (pathetically all the others are antec)... anyways this is my only power supply that I can't seem to bring back within spec... and considering it was probably less then $30 new less than a year ago...
          • SolomonMan
            HP Docking Stations Power Supplies...?
            by SolomonMan
            All,
            I recently purchased for a colleague and myself two used HP Docking Stations. They are for home use and are exact model as the ones we use at work for our laptops. We are both Software Developers.
            Anyways these docks are HP Model 5TW10UT#ABA.
            Unfortunately they did not come with there Power supplies (PSU) and I got them reasonable from eBay.
            I purchased 2 new from Amazon After Market Power Supplies(PSU). Same Voltage and Same Amperage and in fact it mentions on the Amazon page they are supported for these docks as well.
            h...
            05-09-2023, 08:04 AM
          • iMic
            Vintage AT Power Supplies - Selecting Capacitors
            by iMic
            Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
            The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
            02-19-2023, 06:45 PM
            Meanwell Switching power supplies intermittent every capacitor under 100uf
            by sam_sam_sam
            Here is the eBay website link where I bought them from
            https://www.ebay.com/itm/276135936202
            I have been waiting for these switching power supplies to come well they came in today so I took one apart and found that it Capcon and EIite and another brand that is on my list of capacitors to replace on site it has several 0.47uf @ 50 volts ESR value twice the reading of a new one 10 UF @ 50 volts almost twice the ESR value of a new one 47 UF @ 59 volts with double the ESR value 100 UF almost the same as a new one it got replaced for good measure Iit was a brand if I see them...
            11-25-2023, 06:05 PM
          • caprider
            Recommendations of quality soldering station and (separate) hot air station
            by caprider
            Hey,
            I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
            I now have a TS100 and some soldering irons and looking for some better tools.
            1. Soldering station, budget around 200-240€
            JBC BT-2BWA seems to be a good product in the budget.
            2. Hot air station, budget around 200€
            Up to now I've found ATTEN ST-862D to be a good option....
            01-15-2022, 02:05 AM
          • Rgyver2
            Cougar BXM850
            by Rgyver2
            Just picked up a working Cougar BXM850 PSU.
            Noticed that the main input cap is a Teapo LS (420V 560uf).
            appears to be a date stamp on the cap of 09/19 - so is likely to be a bit over 4 years old.
            any recommendations for which cap to use to replace this LS cap?
            Teapo LS spec sheet shows 1600 mA ripple (30x50mm) for this cap. last time i changed a main input cap i used a Rubycon MXK
            i am still looking this over and dont see any other signs of concern. but if someone knows this PSU and has any other recommendations for components to replace, let me know. (secondary...
            01-22-2024, 02:09 AM
