Out of spec 12v and 5v. Recommendations?
  • MixMasta
    • Feb 2006
    • 142
    I have a few power supplies where the 12v is pretty low and the 5v is high. I also have a couple where just the opposite is occuring, 12v is at like 13.3 and the 5v is somewhere around 4.5v. I have at least one where the voltage drops when the 12v is under load. Many of these have Fuhjyyu caps, but none appear to be leaking. Could they be causing these conditions? Any recommendations or background info on this condition would be great. (Maybe a crash course on how the 12v and 5v is regulated is already on the forum, but I guess I missed it then.) I'm thinking about replacing some of the caps, but I'm not sure if its worth the investment. I'd hate to order a bunch of caps, only to find that my situation with out of range voltage remains the same. What are the chances that my 12v and 5v would be within 5% of spec with new caps, these being apparently not so great power supplies and all? How do I test a cap anyway, all I own is a Radio Shack multimeter? And why is it such a pain to get the circuit board out of the power supply housing? Am I supposed to desolder the on/off switch to get the thing completely out? Anyone want me to send them ~10 ps to evaluate whether they are worth saving?
  • japlytic
    • Oct 2005
    • 2086
    Re: Out of spec 12v and 5v. Recommendations?
    If you still get out of spec 12V and 5V rails after replacing the electrolytic capacitors, check out the high power rectifiers. In some units I have seen, the current ratings of the output rectifiers are less than the output current rating printed on the power supply.
    • MixMasta
      • Feb 2006
      • 142
      Aren't they the same rail on the cheaper power supplies? Some of mine have a pots inside. Adjusting it causes both the 5v and 12v to increase or decrease. I can't adjust either separately.
      • davmax
        • Dec 2005
        • 899
        One adjustment means one regulating circuit just monitoring one of the outputs often only the 5 volt output. This means all other outputs are relative to the one monitored. None are on the same rail. Sometimes low current outputs will take power from a higher voltage rail, but because this is done with a regulating chip that dissipates heat, it is definitely for low current outputs only.
        Gigabyte EP45-DS3L Ultra Reliable (Power saver)
        Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
        160Gb WD SATAII Server grade
        Nvidia 8500GT 256Mb
        160Gb WD eSATAII Server grade for backup.
        Samsung 18x DVD writer
        Pioneer 16x DVD writer + 6x Dual layer
        33 way card reader
        Windows XP Pro SP3
        Thermaltake Matrix case with 430W Silent Power
        17" Benq FP737s LCD monitor
        HP Officejet Pro K5300 with refillable tanks
        • linuxguru
          • Apr 2005
          • 1564
          Most of the secondary circuits regulate both the +5v and +12v with one feedback loop. Both voltages are sensed with a simple resistive wye-divider with one leg to ground, and compared with a reference voltage, usually +2.5v from a TL431 band-gap reference. That's the reason that +5v will
          increase when +12v drops (on heavy loading) and vice versa.
          If you find that it's dropping on light cross-loading, then it's most probably a bad caps issue. Replace all secondary caps as usual with the recommended replacements (from other threads on this forum). Fuhjyyu is a known bad cap, and it's alarming that even reputed brands like FSP (Fortron-Sparkle) have been using them extensively.
          • MixMasta
            • Feb 2006
            • 142
            Yes, I have 2 FSP (one of which is rebranded Sparkle) with the Fuhjyyu caps! I don't really know what brand of power supply is reliable any more. I have another 2 bad Antec ones...
            • gonzo0815
              • Feb 2006
              • 1600
              As far as i know, not much on the lower price tag, and a few at the higher. I normaly go for cheap, most FSP`s oem i had are at least equiped with Teapo caps, wich is fine methink.
              Some FSP oem's from MDM are obviousely equiped with not that good caps, IMHO due to the price pressure from the oem customer (some 250w units, mostly sold with some Medion p4 3ghz systems without the needed airflow, to keep it silent but very hot)
              Any way, for personall use, i think recapping a psu will not hurt and is well worth the effort, if the rest of the circuit is of honest enginering work. It is not that hard to do it, because the soldering is in most cases very easy, with an high wattage sodering iron.
              • MixMasta
                • Feb 2006
                • 142
                Damnit. These things are full of 10v 3300 uF 10mm and 16v 2200 uF 10mm. Maybe I'll just throw them away.
                • linuxguru
                  • Apr 2005
                  • 1564
                  FSP and Channel Well are known for stuffing their PSUs with Fuhjyyu 10 mm caps. The 1650uF/16v/10mm is infamous, but even worse are the 4700uF/10v/10mm and the 3300uF/16v/10mm. I'm still looking for inexpensive universal low-ESR caps, and I've only turned up Taicon HD 1200uF/16v/10x25mm - which has worked well so far.
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    i have found that i can get most of the fsp units to take 12.5mm caps.sometimes they have to stay 1/2 in or so off the board but it doesnt seem to hurt.i have several 350-400 w fsp units in my own stuff that have all 12.5 mm caps.iff i need 10mm i use ncc lxz 2700@6.3.
                    but most places i use rubycon yxg 3300@6.3.they outperform the fuhjjyu's even though they are old school as low esr caps go.
                    and it helps that i stumbled onto 3000 of them dirt cheap at a hamfest :-)
                    • MixMasta
                      • Feb 2006
                      • 142
                      Sorry to bring this thread back but...
                      Replaced all large caps on a FSP ATX-350PA and I still have a low 5v and high 12v. If I adjust the pots, I can get 5v at 5.00 and 12v at 12.95v with no load. Plug it into a pc, and the 5v drops to 4.82 and the 12v jumps to 13.49. Obviously, I'll want to adjust the pots while the supply is under load, but not while the 12v is so out of whack (yeah 14v is crazy). What should I look for... and assume I have little knowledge of a powersupply, and my only real tools are a multimeter and soldering station.
                      • Brian C
                        • Dec 2006
                        • 156
                        There are few resistors other than the trimmer pot to adjust the balance between 5V and 12V line. Can u take a photo of the parts around PWM IC (TL494, KA7500, etc)... The 5V and 12V line are summed to the feedback of PWM controller IC.
                        SMPS has minimum load condition for high power output like 5V and 12V. Load the P/S with this condition and adjust the resistor value. (pls check the minimum load current from the specification label)
                        Since 5V and 12V share some part of the secondary windings, Loading on the 5V line will cause significant increase in 12V line and vice versa (if one supply line is left unloaded). The effect is not so significant when both are well loaded.
                        It is quite hard to achieve tighter regulation on low end ATX P/S.
                        • MixMasta
                          • Feb 2006
                          • 142
                          Here are some pics... apparently I am not very good at taking them... how does everyone else get such clear ones? Anyway, what should I do now?
                          • Shroomie
                            • Apr 2006
                            • 356
                            "Good lighting, no flash" works for me. The flash is terrible with electronic components, but a fluorescent light or sunlight tends to create a good picture, even with an older camera like mine (2 megapixel Kodak EasyShare).
                            Still, those pictures aren't bad at all.
                            You know there's something wrong when you open up a PSU and are glad to find Teapos.
                            Why I don't buy cheap cases!
                            • Brian C
                              • Dec 2006
                              • 156
                              What is the IC part no. in the picture ? It is probably the PWM controller IC.
                              • gonzo0815
                                • Feb 2006
                                • 1600
                                Most important is, that the cam has a macro mode, withouth that, i have had no luck (ok, only have had lend some cheaper cams (about 120€). Withouth that i haven`t got sharp pictures of elektronic devices.
                                • willawake
                                  Super Modulator
                                  • Nov 2003
                                  • 8457
                                  • Greece
                                  most importantly make sure you are not going closer than the minimum focusing distance of the camera.
                                  enable macro mode
                                  dont zoom
                                  best results are on a tripod or mini tripod with flash disabled. the camera will do a 1s or 2 sec exposure. but for that you have to enable the timer so you can press the button and the camera will stop shaking on the tripod before it takes the pic. sometimes flash is necessary though to show stuff in shadow.
                                  one problem is depth of field. at large apertures (say f2.8) the depth of field may be very shallow. so while you focus on one component and it is in focus, everything closer or further away will be out of focus. check if thats the issue.
                                  sometimes the camera is just focusing on something which you did not intend to focus on.
                                  and actually i get better close up product shot pics with my canon a700 than my DSLR. (although the a700 makes the corner of the photo dark cos the lens makes a shadow with the flash). so dont blame the equipment.
                                  • Rainbow
                                    • Aug 2005
                                    • 1375
                                    I use Canon Powershot G3 with flash power set to -2 (minimum), macro mode and either f2.0 or f8.0 (for minimum/maximum focus depth) depending on my needs.
                                    • MixMasta
                                      • Feb 2006
                                      • 142
                                      FJ 3528
                                      536 J771C
                                      The FJ part is a logo...
                                      willawake, I enjoy all your yatch photos. They are really great. Even cooler to me (a lover of ancient greek history and mythology) is that many are taken at Piraeus.
                                      • MixMasta
                                        • Feb 2006
                                        • 142
                                        Guess I will remove these caps I wasted my time putting on cause I don't know how to fix this problem... what a waste.
                                        • SolomonMan
                                          HP Docking Stations Power Supplies...?
                                          by SolomonMan
                                          All,
                                          I recently purchased for a colleague and myself two used HP Docking Stations. They are for home use and are exact model as the ones we use at work for our laptops. We are both Software Developers.
                                          Anyways these docks are HP Model 5TW10UT#ABA.
                                          Unfortunately they did not come with there Power supplies (PSU) and I got them reasonable from eBay.
                                          I purchased 2 new from Amazon After Market Power Supplies(PSU). Same Voltage and Same Amperage and in fact it mentions on the Amazon page they are supported for these docks as well.
                                          h...
                                          05-09-2023, 08:04 AM
                                        • iMic
                                          Vintage AT Power Supplies - Selecting Capacitors
                                          by iMic
                                          Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
                                          The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
                                          02-19-2023, 06:45 PM
                                          Meanwell Switching power supplies intermittent every capacitor under 100uf
                                          by sam_sam_sam
                                          Here is the eBay website link where I bought them from
                                          https://www.ebay.com/itm/276135936202
                                          I have been waiting for these switching power supplies to come well they came in today so I took one apart and found that it Capcon and EIite and another brand that is on my list of capacitors to replace on site it has several 0.47uf @ 50 volts ESR value twice the reading of a new one 10 UF @ 50 volts almost twice the ESR value of a new one 47 UF @ 59 volts with double the ESR value 100 UF almost the same as a new one it got replaced for good measure Iit was a brand if I see them...
                                          11-25-2023, 06:05 PM
                                        • caprider
                                          Recommendations of quality soldering station and (separate) hot air station
                                          by caprider
                                          Hey,
                                          I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
                                          I now have a TS100 and some soldering irons and looking for some better tools.
                                          1. Soldering station, budget around 200-240€
                                          JBC BT-2BWA seems to be a good product in the budget.
                                          2. Hot air station, budget around 200€
                                          Up to now I've found ATTEN ST-862D to be a good option....
                                          01-15-2022, 02:05 AM
                                        • Rgyver2
                                          Cougar BXM850
                                          by Rgyver2
                                          Just picked up a working Cougar BXM850 PSU.
                                          Noticed that the main input cap is a Teapo LS (420V 560uf).
                                          appears to be a date stamp on the cap of 09/19 - so is likely to be a bit over 4 years old.
                                          any recommendations for which cap to use to replace this LS cap?
                                          Teapo LS spec sheet shows 1600 mA ripple (30x50mm) for this cap. last time i changed a main input cap i used a Rubycon MXK
                                          i am still looking this over and dont see any other signs of concern. but if someone knows this PSU and has any other recommendations for components to replace, let me know. (secondary...
                                          01-22-2024, 02:09 AM
