It just keeps randomly turning off for some reason. Well, that reason is several very large capacitors seem to be leaking brown crud. Add another thing to the list of devices using junk caps.
HeroIchi HEC-300GR PSU
Re: HeroIchi HEC-300GR PSU
Ahh, an HEC. Those aren't too good if I remember correctly.
What brand and model are the capacitors, Ark42?You know there's something wrong when you open up a PSU and are glad to find Teapos.
Why I don't buy cheap cases!
by pcwhiz24This issue has me stumped! I have this Lenovo IdeaPad and the SSD (NVME) keeps on randomly disconnecting. It'll stop being detected in BIOS randomly and when I turn it off and back on sometimes it'll detect again and boot up just fine...only to crash after a few minutes and either boot again or stop being detected.
Things I tried so far:
- Reset the CMOS by removing battery, held power buttons 60 seconds, all that jazz.
- BIOS is fully updated (had to use CHA341 because I bricked it the first time trying to update it)
- Tried multiple working NVME drives... -
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by FernonGigabyte GA-Z170X-gaming 3 Randomly Power Off... This motherboard working fine sometime power off .when i power on again motherboard working Normally...can you help to repair this error ....this is not cpu overheat .
by Sokha Vitouhello everyone. please help i have a surface laptop 3 AMD model 1873 that randomly restart. i don't think it has bad CPU, because when tried to stress test by CPU-z it not restart or has anything wrong, it just randomly restart when normal use ( browser, or watch video....). i tried to replace U6701 and U6702 but don't see any thing change.
I'm tried to fine any glue on internet but no luck. I'm looking for any advice from you guy please.... -
by ktmmotocrossHello.
Have this A1398 emc 2876 that randomly goes to black screen and raising fan. I know this was problem of gpu or gpu voltage controller, but this one is without gpu.
Is there some known failure points on them or i just count on cold solder under cpu? - Loading...
