Modding Sparkle FSP300-60ATV
  • Polymorph
    • Jun 2012
    I want to do more than the usual mods to make this a bench power supply.
    This is for a workshop for OlyMEGA, a maker group in Olympia, WA. We have a bunch of 300W ATX power supplies, the majority are Sparkle Power Int'l Ltd FSP300-60ATV.
    What I'd like to do: Retune it to put out 5V from the 3.3V output, this will cause the 12V output to go up to about 18V. Swap the diodes on the erstwhile 5V and erstwhile 12V, because the shottky diodes on the 5V line are rated for more current.
    In this way the power supply will still have a regulated 5V line, and we'll add an adjustable regulator connected to the 18V, using the -12V (now -18V) to bias the regulator so that it can go from 0 to 14V.
    Of course the stock adjustment only goes up a few tenths of a volt. Someone on BadCaps.net put up an unfinished schematic he'd reverse engineered, it appears to combine the 3.3V, 5V, and 12V outputs as part of the feedback. I can hack that. What I'm concerned about is any output overvoltage protection. An attachment about 2/3 of the page down:
    https://www.badcaps.net/forum/showth...t=FSP300-60ATV
    It uses a proprietary chip (at least I cannot find any information on it), FSP 3528. I did find some generic schematics on a few Russian websites. From those and the partial reverse engineered schematic, I see that 3.3, 5, and 12V lines all go back into the feedback. I should just be able to disconnect all but the 3.3V, but recalculated to regulate it to 5V. The 12V should go up to 18V since it'll be proportional.
    But there are two more trimpots on the PCB. One is connected to a 3.3V Sense line, which goes to several transistors which may be part of the overvoltage protection on 3.3V.
    I thought I'd swap the 3.3V output to where the 5V is now connected to the FSP 3528, and put a resistor and 3.3V zener from there to the 3.3V over voltage protect on the FSP 3528. If the 3.3V Sense line mentioned above requires some voltage on it, I might connect that 3.3V zener to it, too.
    About halfway down the page:
    http://www.rom.by/forum/BP_FSP_ATX-4...vyhoda_resheno
    More schematics:
    http://www.rom.by/files/plata-ShIM-3528.gif
    http://www.overclockers.ru/images/la...sp3528_big.png
    This one seems to be telling how to mod the power supply to put out 12V and 40V, plus and minus, possibly for a CNC mill or an audio amp? Looking at the picture at the bottom of the page, it looks just like my PC supply.
    http://www.overclockers.ru/lab/44201...y_chast_2.html
    Maybe all I really need to do is cut the 5V secondary out of circuit, cross jumper the 3.3V secondary to it, swap the 3.3V rectifier to 12V circuit, and add the 3.3V zener from the 5V lines just to run voltage to the chip. Or better, an LM317 adjusted to 3.3V out.
    Then it will up the PWM so 5V comes out of the 3.3V winding, which is about (5-3.3)/3.3 = 51% greater voltage, 12V x 1.51 = 18V. Then everything expecting a particular voltage will still get it.
    The supply should then be able to output over 20A on 5V, at least an amp on 3.3V, and depending on the linear regulator, 0-14V at up to 20A.
    Steve Greenfield AE7HD
  • Polymorph
    • Jun 2012
    Re: Modding Sparkle FSP300-60ATV
    I think I also need to put a 7812 or 12V zener to present 12V to the 12V overvoltage sensor.
    • caspian
      What Zener Diodes on a Linear Power Supply
      by caspian
      Dear members,
      I have a linear variable power supply with unknown brand name that I used for voltage injection.
      Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
      In addition, I discovered that its zener diodes are defective.
      I can replace the burned transistors.
      But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
      Therefore, I cannot replace the zener diodes.
      I do not want to test the zener diodes in a test circuit to discover their model or value.
      no schematics are available...
      05-26-2025, 12:38 PM
    • Dvsr
      On M-Audio AV40 active studio speaker's two zener diodes get really hot.
      by Dvsr
      Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
      I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
      After replacing the caps I started testing out the speaker. It seemed...
      09-10-2025, 10:20 AM
      Acer Extensa EX215-52-3528 Notebook 15 Specification for Upgrade or Repair
      This specification for the Acer Extensa EX215-52-3528 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EX215-52-3528 boardview and EX215-52-3528 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
      09-06-2024, 08:40 PM
    • nev1001
      What zener diode might fix the sound on Maestro Mayhem gaming chair?
      by nev1001
      Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
      The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
      It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
      I think an issue could be a zener diode (or capacitor) which has shorted out.
      The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
      04-17-2025, 05:09 PM
      NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
      I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
      I bought this from an eBay seller but unfortunately they only had one
      I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
      I bought three of from them to also make battery packs with this output power limit in mind
      I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
      04-23-2025, 05:50 AM
