HP-D3057F3H recap
  • Shocker
    replied
    Re: HP-D3057F3H recap
    I don't have an oscilloscope.
    Neither the 1000uF MBZ nor the 3300uF HM were from Vcore.
  • c_hegge
    replied
    I doubt it would be much. I polymodded one once, and used a 6.3v 1000uF Nichicon L8 in that position. I got exactly 2.0mV from the 5vsb with 1A Load. My main concern is actually where they came from. If he scavenged them from the VRM low side of a motherboard, then they will have de-rated to 1.5V or so.
  • mockingbird
    replied
    I am curious how much ripple is coming out of your +5VSB line with that MBZ in there...
  • Shocker
    replied
    I would have used closer caps to the originals if I had some
    But the MBZ were the only quality 1000uF 8mm I had, and while I had a third Hipro to take parts from (which was where I got the Chemi-con primaries), I chose to save the 2200uF 16V KZEs for something that actually needs 2200uF 16V 10mm caps.
    Anyway, it works, and that's what matters.
  • c_hegge
    replied
    I've recapped about 20 of those in the past. Usually, the 1000uF teapo on the 5vsb fails, and the PSU won't start. They are good PSUs, though, after a recap.
  • Shocker
    started a topic HP-D3057F3H recap
    HP-D3057F3H recap
    I did this earlier today using capacitors from old motherboards. I'm glad I didn't wait longer to do it. Even so, I should have done it much earlier. You'll eventually find out why...
    Original capacitors (all are 10mm except the +5VSB):
    • +3.3V: LTEC LZP 2200uF 10V
    • +5V: LTEC LZP 2200uF 10V
    • +12V: Chemi-con KZE 2200uF 16V
    • -12V: Chemi-con KZE 2200uF 16V
    • +5VSB: Teapo SC 1000uF (bulged) and 470uF 10V
    Replacement capacitors:
    • +3.3V: Nichicon HM 3300uF 6.3V
    • +5V: Nichicon HM 3300uF 6.3V
    • +12V: Not replaced
    • -12V: Not replaced
    • +5VSB: Rubycon MBZ 1000uF 6.3V
    I also replaced the primary caps (Teapo LH 680uF 250V) with Chemi-con SMQ (same value and voltage). Best to be on the safe side.
    I was originally keeping it on the list of spare PSUs to be (eventually) recapped. Only today did I discover that the repair was overdue.
    I went to install the fixed PSU in my PC. I pulled another (unrepaired) unit out of my PC. I waited long enough for one of the +3.3V caps in that one to go from non-bulging to leaking. (In case you're wondering, the +5VSB caps in that one weren't bulging.)
    The only symptom of that crap was a faint high-frequency whine.
    Morals of the story:
    • Even totally busted caps don't always show obvious symptoms.
    • NEVER leave crap caps alone.
    • Never, EVER use an HP-D3057F3H with the original caps.
    Any comments???
  • прямо
    Viper22A 5VSB circuit
    by прямо
    So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
    In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
    01-13-2024, 07:05 PM
  • kotel studios
    FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
    by kotel studios
    Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
    Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
    I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
    Any ideas where to go next?
    02-23-2025, 11:47 AM
  • mrcliem
    CM V700 no +5vsb, ICE2QR4765 low VCC in... Need guidance please...
    by mrcliem
    Hello...
    I got my self a dead CM V700 PSU, with nothing on +5vsb
    I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
    As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
    The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
    I have read the datasheet and and still can not...
    06-29-2023, 08:18 AM
    BFG Tech BFGR550WGSPSU [LW6550SE Rev. K] – recapping & modding
    by momaka
    Rather than post in the PSU build quality pictorial thread, again I am splitting off the recapping info into its own thread. Also, I plan on doing some possible modding/experimentation on this PSU, so I figured that info would also be better to go here.
    The PSU in question is this one:
    Detailed post with parts and build quality is here:
    https://www.badcaps.net/forum/showpo...postcount=3085
    So this PSU has very simple output filtering: two 2200 uF caps on each major rail (3.3V, 5V, and 12V.)
    Here is a cap diagram showing the caps...
    06-13-2020, 12:41 PM
    no-name Radeon 9600 XT recap and cooler
    by momaka
    I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
    This one was actually suggested to me by ChaosLegionnaire....
    11-06-2020, 07:54 PM
