UC3842 basics
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: UC3842 basics
    Originally posted by daverave56
    i replaced the two tant capacitors with electrolytic 63v 47uf and did some voltage tests on the UC 3842 chip.
    Pin 1 - 0v
    Pin 2 - 0v
    Pin 3 - 0v
    Pin 4 - 0.7v
    Pin 5 - ground
    Pin 6 - 0v
    Pin 7 - 13v
    Pin 8 - 2v
    Definitely something going on here.
    Did you check for shorts (and shorted diodes) on the output side of the PSU?
    Muh-soggy-knee
    • daverave56
      • Mar 2015
      • 16
      • united kingdom
      #102
      Re: UC3842 basics
      i did check the secondary electrolytics some time ago with esr meter and found nothing wrong,i will have another look at the regulators and diodes,could any faulty chip on the secondary side cause this shut down ??? we did have some dampness in the room where i keep the scope,my digital multimeter also will not work anymore,maybe same problem.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Re: UC3842 basics
        Sounds like some electrical gremlins! :P
        Strange that your meter won't work anymore ... I'm assuming you tried replacing the battery. What brand is it? (Like, is it a cheap one or a good one?)
        Yes, a shorted diode or voltage regulator (or anything connected to the output of the power supply) would cause it to shut down.
        Muh-soggy-knee
        • daverave56
          • Mar 2015
          • 16
          • united kingdom
          #104
          Re: UC3842 basics
          both my scope and multimeter failed after being in the same room,we had some water come into the room from the above flat which went over my oscilloscope but i did take the lid off at the time and could not find any water inside scope maybe just a coinsidence,even after the water problem the scope worked for several months after,when i first bought the scope second hand i always had to push the mains switch in quick and firmly then the scope would fire up and was like this for about two years then one day i went to use the scope and it would just not fire up,i really dont want to scrap this scope cause i like it very much,but im running out of idea's on how to fix this as im not expert on switch mode power supplies.
          • daverave56
            • Mar 2015
            • 16
            • united kingdom
            #105
            Re: UC3842 basics
            im coming now so close to binning this scope which will sadden me as i really wanted to see this scope light up again !!! i feel the fault is too difficult for me or maybe other people to work out
            • rievax_60
              • May 2012
              • 897
              • australia
              #106
              Re: UC3842 basics
              Pin 2 measuring 0V is suspicious. There could be a short to ground or a protection circuit acting on it.
              You need to confirm that pin 7 is getting to 16V. The best is with another oscilloscope and isolation transformer. The Min/max on a DMM might catch it.
              Or measure pin 7 while slowly increasing the input ACV with a variac.
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Re: UC3842 basics
                Well, I'm sure one of us could figure out what is wrong with it, it's just that it is harder to do that through the computer screen ... lol
                Don't bin it just yet! :S
                https://www.badcaps.net/forum/showpo...9&postcount=89
                Have you checked the voltage on that big blue capacitor, in that picture you posted (in the above post I linked to)?
                Also, for example, start checking diodes, for example, like D109, and D110.
                Could we possibly get a picture of the whole power supply too?
                Muh-soggy-knee
                • daverave56
                  • Mar 2015
                  • 16
                  • united kingdom
                  #108
                  Re: UC3842 basics
                  the large 400v electrolytic has 320v across it and after 15 hours of the power supply being disconnected the 320v was still present and i had to bleed it with a resistor,i think i will try connecting a separate power source direct to the UC 3842 and see what happens and measure pin 6 with a frequency counter,i just wish i could understand the workings of this UC 3842 chip as i find it very complecated.
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Re: UC3842 basics
                    Yes you can try connecting a separate power source to the 3842. I don't know what sort of other circuitry could be connected to the power pins, so be sure to use a current limited PSU, maybe to say 100mA or so. Just in case! Also, I'd probably use about 18V or so.
                    Strange that the capacitor still has a lot of charge left after a while, because there should be a resistor which supplies initial start-up power to the 3842. I would think that resistor would drain the voltage on that capacitor much more rapidly.
                    Muh-soggy-knee
                      • 31086
                      Re: UC3842 basics
                      startup resistor(s) - they used to change value slowly in a lot of set-top boxes i had to fix.
                      • rievax_60
                        • May 2012
                        • 897
                        • australia
                        #111
                        Re: UC3842 basics
                        The start resistor might be connected back to one of the AC phases, this can be traced and confirmed. We need to know what is really happening on pin 6.
                        • rievax_60
                          • May 2012
                          • 897
                          • australia
                          #112
                          Re: UC3842 basics
                          A while back, the power supplies in my HP 54645A DSOs failed. I found a protection circuit that was meant to disable the UC3842 while ever the mains voltage was too low. The UC3842 was being permanently disabled because of a high voltage resistor going high in the protection circuit.
                          • daverave56
                            • Mar 2015
                            • 16
                            • united kingdom
                            #113
                            Re: UC3842 basics
                            i connected 18v DC supply to the UC 3842 and these are the results.
                            Pin 1 - 0.09v
                            Pin 2 - 0.06v
                            Pin 3 - 0v
                            Pin 4 - 1.91v
                            Pin 5 - ground
                            Pin 6 - no osc
                            Pin 7 - 18v
                            Pin 8 - 5v
                            • daverave56
                              • Mar 2015
                              • 16
                              • united kingdom
                              #114
                              Re: UC3842 basics
                              just been looking at a schematic of he UC 3842 and it shows a 56k 1W resistor from the 320v supply to pin 7 of the UC 3842,which i guess is the startup resistor,but i cannot see any 1W resistors in the power supply but only very small surface mounted types
                              • rievax_60
                                • May 2012
                                • 897
                                • australia
                                #115
                                Re: UC3842 basics
                                Something is holding pin 2 low. You will have to trace it.
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  Re: UC3842 basics
                                  I second this.
                                  You should be looking for somewhere around 2.5V on the feedback pin.
                                  Perhaps there indeed is some sort of protection circuit kicking in.
                                  As to where the large resistor is, I can't see the whole power supply, so I can't say where it might be. But it might be hiding inside a heatshrink sleeve, or something like that.
                                  It is also interesting that the oscillator isn't running. I don't know why that could be.
                                  Muh-soggy-knee
                                  • rievax_60
                                    • May 2012
                                    • 897
                                    • australia
                                    #117
                                    Re: UC3842 basics
                                    I made a mistake. It's pin 1 that has the problem. With the voltage readings on all the other
                                    pins, pin 1 will be wanting to go up to a few volts. Something external to the IC is holding pin 1 low. Look for a transistor. Check for a short to ground first.
                                    • daverave56
                                      • Mar 2015
                                      • 16
                                      • united kingdom
                                      #118
                                      Re: UC3842 basics
                                      i noticed that there is a opto coupler 4N25 near to the UC 3842,i measured 13v going into pin 5 of the opto coupler but nothing coming out of pin 4,the 13v which should be present on pin 4 of the opto coupler then go's through several resistors and two small transistors and then to pin 1 of the UC 3842, i was tempted to power up the UC 3842 with the 18v external supply and short pins 4 & 5 of the opto coupler and see what effect this has on pin 1 of the UC 3842
                                      • rievax_60
                                        • May 2012
                                        • 897
                                        • australia
                                        #119
                                        Re: UC3842 basics
                                        The transistor inside of the opto coupler should not be passing any current until its LED on the isolated side gets some current passed through it when the output rails rise to their regulation voltages.
                                        Don't force anything until the circuitry is better understood. Is there a transistor's Collector pin connected to pin 1 of the UC3842?
                                        Its best if you draw out the circuitry involved with pin 1. You have not mentioned the result of checking for a short to ground on pin 1.
                                        • daverave56
                                          • Mar 2015
                                          • 16
                                          • united kingdom
                                          #120
                                          Re: UC3842 basics
                                          between pin 1 and ground there is a resistance of around 200k.
                                          • tony359
                                            Faulty CRT AKF12/Philips CM8500: bad flyback?
                                            by tony359
                                            I have a CRT (Acorn AKF12, based on the 240V version of the Philips CM8500) which has stopped working. It's making a high pitched noise but not too high. I know this is symptom of a faulty flyback.
                                            What happens when a flyback fails? I see that the main voltages out of the PSU are not reaching rated values, as if there is a short.
                                            There are supposed to be 125V/26.5V/15.5V outputs but I am reading something like 48V, 10V and 8V. If I unplug the PSU from the rest of the PCB, I can measure the expected values.
                                            Can it be a short somewhere...
                                            08-22-2023, 04:39 PM
                                          • прямо
                                            Viper22A 5VSB circuit
                                            by прямо
                                            So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                                            In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                                            01-13-2024, 07:05 PM
                                          • kotel studios
                                            FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                                            by kotel studios
                                            Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                                            Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                                            I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                                            Any ideas where to go next?
                                            02-23-2025, 11:47 AM
                                          • mrcliem
                                            CM V700 no +5vsb, ICE2QR4765 low VCC in... Need guidance please...
                                            by mrcliem
                                            Hello...
                                            I got my self a dead CM V700 PSU, with nothing on +5vsb
                                            I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
                                            As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
                                            The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
                                            I have read the datasheet and and still can not...
                                            06-29-2023, 08:18 AM
                                          • socketa
                                            Zalman ZM500-GV stops after 40s and 5VSB drops to 2.5V
                                            by socketa
                                            Rescued this one
                                            Started it up in the computer case, and noticed that it would shut down after about 10s in the BIOS
                                            Took it out, connected to hard drive and it loses all power on all rails (except for 5VSB) after about 40s or so. (the same result happens without a hard drive connected)
                                            The 5VSB drops to 2.5V when it 'shuts down'
                                            And the voltage across the primary cap falls from 335V to 330V at the same moment
                                            I think that the 5VSB is regulated by an A6069H PWM chip (which was initially dropping to 2.5V even before the the PS-ON was grounded - but it now stays at...
                                            12-20-2022, 03:06 AM
