UC3842 basics
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: UC3842 basics
    The schematic.
    Note: lol, the 100n cap marked 'C1' should be 'C8'
    Muh-soggy-knee
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Re: UC3842 basics
      I tried using a different transformer, but I couldn't get it to work.
      Its markings are:
      22L-T07
      TDK X 93®
      Some measurements:
      top to bottom of core : ~30mm
      side to side of core : ~22.5mm
      core thickness : ~6mm
      primary side pins : 4
      primary side windings : 2
      secondary side pins : 5
      secondary side windings : ?
      insulation tape : black/white
      Any ideas?
      This was from a VCR psu (I think). Also, I soldered the wires on there, as the pins didn't fit in the breadboard.
      Muh-soggy-knee
        Re: UC3842 basics
        That I sense feedback needs just enough filter so it will not response to the noise and when the MOSFET first starting and causes the circuits to go into shutdown. Same thing for the opto feedback circuits.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Re: UC3842 basics
          Tried different caps in feedback, no change. Tried different filter caps, no change. The only thing I haven't tried is to change the switching frequency.
          Muh-soggy-knee
            Re: UC3842 basics
            Oh, The feedback I am talking about is not related to this new transformer you are trying to get it to work. Since you have two primary windings, one of them will be for the drive winding, the other will be for supplying the DC to the SMPS IC once the circuits start running on its own.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Re: UC3842 basics
              Yeah, I got the primary and AUX windings sorted out.
              Oh, I think you have gotten confused, this circuit does work with a regular 5vsb transformer! I just tested it and it still works. It doesn't seem to like this transformer though :/
              Muh-soggy-knee
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Re: UC3842 basics
                Hm, well, I have powered the 3844 with an external source, and it is working.
                How could I get the AUX winding to supply a higher voltage without re-winding the transformer? could I use a voltage doubler?
                EDIT: Um, yeah, my DMM says the AUX winding is giving out about 70mV! Does this mean the transformer is toast?!
                Muh-soggy-knee
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Re: UC3842 basics
                  Thats interesting, why can't I edit my posts in this thread anymore?
                  Muh-soggy-knee
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Re: UC3842 basics
                    Could a transformer used in a quasi-resonant smps work in flyback mode? I think I found the problem, the TDK transformer was in an smps with a STRW6765 - a quasi-resonant smps ic.
                    Muh-soggy-knee
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      Re: UC3842 basics
                      I guess nobody else wants to contribute to this thread?
                      Muh-soggy-knee
                      • rogfanther
                        • Jul 2006
                        • 458
                        • Brazil
                        #71
                        Re: UC3842 basics
                        Well, I still could not find some uninterrupted time for building my first try in this, but expect to be able to in the next week(s). As you, I believe I will start with a 5VSB transformer, due to it having reasonable turn proportions already in place, later moving to rewound transformers for different voltages
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          Re: UC3842 basics
                          Ah great!
                          I want to make my own transformers too, but to use OP's transformer design spreadsheet, I need windows office
                          I have at least two dozen transformers for experimenting with.
                          The Pirate Bay, here I come!
                          Muh-soggy-knee
                            Re: UC3842 basics
                            Originally posted by ben7
                            Ah great!
                            It worked fine for me with OpenOffice.org Math / LibreOffice Math.
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              Re: UC3842 basics
                              I have a question.
                              Could the chip be used as a variable PWM source, by changing the voltage on the VFB pin, and yet still have a current limit?
                              Muh-soggy-knee
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                #75
                                Re: UC3842 basics
                                It's not designed to be used that way. However, it is possible if you make the source resistor low enough. Make it so in normal operation the voltage feedback alone limits the pulse width, and the Isense threshold isn't reached.
                                I know i haven't been contributing to this lately, but there's been a whole lot of stuff coming in to be fixed, and i've hardly had time for my own projects.
                                I haven't been slacking off tho - i've been sorting all my parts nicely to have them handy, and i'm gonna have a bunch of stuff coming up. I'm kinda running on my spare tire tho due to the lack of computing hardware since my dv9000 finally bucked the kicket a couple months ago (or rather, i got fed up of fixing it all the time), the DV5 is used by my mom most of the time, and there's a lot of stuff that doesn't run on this little ibook i have now, most notably i don't have PCB design software and LTSpice...
                                It ain't all bad tho, as i'm more inclined to experiment with the physical parts instead of mucking around on the computer.
                                I recall i'd blown the 3842 in the little SMPS i built - i'll have to check, as i have like a dozen of them waiting in a ziploc bag hanging from a screw above my bench
                                Edit: That perfboard is a real messy piece of work... That's why i got lazy and never swapped out the blown 3842. That's it - from now on i'm making a PCB for every SMPS project i do... Oh wait, i'm back to square one - no PCB design software running on this thing. Hmm... i have to whip up a PC together, quickly.
                                A working TV? How boring!
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  Re: UC3842 basics
                                  Source resistor? Which resistor is that?
                                  Its not going to use a transformer, it is for a buck circuit (single inductor).
                                  No, it isn't going to run off mains voltage either
                                  Muh-soggy-knee
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    #77
                                    Re: UC3842 basics
                                    The resistor in the source of the switching MOSFET. Anyway... UC3842 is designed for mains-powered applications as a primary side controller in a transformer-isolated power supply. The current sense resistor needs to be between the source of the power switch and ground, so it won't work for a DC-DC buck.
                                    For a dc-dc buck converter there are other chips to use, like the MC34063, which is very easy to implement.
                                    • kaboom
                                      "Oh, Grouchy!"
                                      • Jan 2011
                                      • 2507
                                      Re: UC3842 basics
                                      Two schematics for you.
                                      First, the 'normal' Panasonic VCR PS, as well as an example ckt with a STRW6765.
                                      Maybe there's something in those that can help.
                                      -Paul
                                      "pokemon go... to hell!"
                                      EOL it...
                                      All style and no substance.
                                      guilty,guilty,guilty,guilty!
                                      guilty of being cheap-made!
                                        • Jul 2011
                                        • 6040
                                        Re: UC3842 basics
                                        If someone get this project to work I would like to buy a board and make a 5 volt @ 5 or amp more power suppply
                                        So I hope some will get one working I will keep my eye on this post
                                        • ben7
                                          Capaholic
                                          • Jan 2011
                                          • 4059
                                          Re: UC3842 basics
                                          I would like to build one too, but just for the heck of it. I havent gotten bored of circuit design yet
                                          Plus, I have tons more to learn
                                          I fried my only UC384x yesterday, by a stupid mistake
                                          Will have to put that on my parts list for next order...
                                          Muh-soggy-knee
                                          • tony359
                                            Faulty CRT AKF12/Philips CM8500: bad flyback?
                                            by tony359
                                            I have a CRT (Acorn AKF12, based on the 240V version of the Philips CM8500) which has stopped working. It's making a high pitched noise but not too high. I know this is symptom of a faulty flyback.
                                            What happens when a flyback fails? I see that the main voltages out of the PSU are not reaching rated values, as if there is a short.
                                            There are supposed to be 125V/26.5V/15.5V outputs but I am reading something like 48V, 10V and 8V. If I unplug the PSU from the rest of the PCB, I can measure the expected values.
                                            Can it be a short somewhere...
                                            08-22-2023, 04:39 PM
                                          • прямо
                                            Viper22A 5VSB circuit
                                            by прямо
                                            So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                                            In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                                            01-13-2024, 07:05 PM
                                          • kotel studios
                                            FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                                            by kotel studios
                                            Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                                            Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                                            I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                                            Any ideas where to go next?
                                            02-23-2025, 11:47 AM
                                          • mrcliem
                                            CM V700 no +5vsb, ICE2QR4765 low VCC in... Need guidance please...
                                            by mrcliem
                                            Hello...
                                            I got my self a dead CM V700 PSU, with nothing on +5vsb
                                            I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
                                            As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
                                            The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
                                            I have read the datasheet and and still can not...
                                            06-29-2023, 08:18 AM
                                          • socketa
                                            Zalman ZM500-GV stops after 40s and 5VSB drops to 2.5V
                                            by socketa
                                            Rescued this one
                                            Started it up in the computer case, and noticed that it would shut down after about 10s in the BIOS
                                            Took it out, connected to hard drive and it loses all power on all rails (except for 5VSB) after about 40s or so. (the same result happens without a hard drive connected)
                                            The 5VSB drops to 2.5V when it 'shuts down'
                                            And the voltage across the primary cap falls from 335V to 330V at the same moment
                                            I think that the 5VSB is regulated by an A6069H PWM chip (which was initially dropping to 2.5V even before the the PS-ON was grounded - but it now stays at...
                                            12-20-2022, 03:06 AM
