UC3842 basics
    Re: UC3842 basics
    The size of the transformer is rated in VA hwich is how much power it can supply, so let says that the old transformer is made to produce 5Volt at 1A, if you want it to put out 10V, then you max curent will be only 0.5A. Since the turn ratio does noe not change, the you primary voltage has to go up for the secondary to put out higher voltage. The 3842 is just the controller with its output is used for driving the transistor or MOSFET that actually drive the transformer, the feedback circuits are used to regulate the desired output voltage.
    • rogfanther
      • Jul 2006
      • 458
      • Brazil
      #42
      Re: UC3842 basics
      Then , theoretically, if a transformer is already for 5V 1A, it could be used in another circuit producing the same 5V 1A, even if different MOSFETs and controllers are used ?
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Re: UC3842 basics
        Yes, I think so. As long as the mosfet and controller are properly rated for the situation (correct frequency, feedback, operating mode, etc...).
        Muh-soggy-knee
          Re: UC3842 basics
          Yes, same as ben7 statement. You will also need to know more about the spec of the transformer since it will have stary capacitance and resonance frequency of the tarnsformer, etc. Best to learn by searching "how to design switching power supply" it has many mode of operation as well.
          • rogfanther
            • Jul 2006
            • 458
            • Brazil
            #45
            Re: UC3842 basics
            I understand the concept. My original idea was to have ready some skeleton boards, with most of the components in place, then just complete the circuit with the control part to configure it for the desired voltage. But that was in the case when I could re-use the transformers.
            Barring that , I think what would work better is to get a bunch of cores that satisfy the design parameters for most of the voltages I need, then winding them accordingly for said voltages.
            Of course, it would be easier to buy some power supplies from China / AliBaba, but where is the fun in that ?
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Re: UC3842 basics
              Load testing them and blowing them up
              I like the idea of a skeleton board. I have even thought about doing that for using the DM311 5vsb mod to replace the crappy 2-transistor 5vsb.
              Muh-soggy-knee
              • rogfanther
                • Jul 2006
                • 458
                • Brazil
                #47
                Re: UC3842 basics
                Yes, having it ready would make the decision easier when the need arises, without having to source parts, building another board, etc.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Re: UC3842 basics
                  Maybe we should design a board
                  Muh-soggy-knee
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Re: UC3842 basics
                    Ok I had a go at this again, and I did get it to work!
                    Im using a UC3844, and a 5vsb transformer. (again xD)
                    Its regulating the output to just about 5v like it should, BUT, the transformer whines! Does this mean the feedback loop is unstable??? I have the filter capacitor (an NCC RX(discontinued!), 330uF, 35v, low esr) right after the diode, but before the TL431. Could that be why it is whining?
                    The opto is a PC817.
                    I can post pics tm
                    Muh-soggy-knee
                      Re: UC3842 basics
                      Did you check the frequency it is running at? May be running at the wrong frequency or it has loose core assembly.
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Re: UC3842 basics
                        My fluke 87 says its running at 21khz.
                        Strange, b/c I built the circuit just like the one Th3_uN1Qu3 posted. (used the same cap values for the UC384x)
                        Muh-soggy-knee
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          Re: UC3842 basics
                          Update. When I put the probe to measure the voltage on the output (it was 4.8v), the pitch of the whine changed! So, there IS a problem with the feedback being unstable. Nothing is getting hot, the only things that are warm are the load resistor and the snubber resistor.
                          Muh-soggy-knee
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            Re: UC3842 basics
                            ANOTHER update
                            I found another circuit which is MUCH nicer.
                            I modified the psu on my breadboards, and now it is working better. That is, with a light load. A heavy load makes it hiss. So it still has some tweaking to be done. But I tested it with a 1A load, and the supply happily kept up a constant 4.95v output, and 4.99v with only 10mA load (an led).
                            Muh-soggy-knee
                              Re: UC3842 basics
                              When you build this kind of circuits on bread board like that, you will have to really watch out how you route the ground current return path for each section of the the circuits. You may want to search "how to do PCB LAYOUT for switching power supply" to get more understanding. You need to keep high current path as short as possible for the return current to flow back to the source without modulating other sensitive circuits such as feedback, ref voltage source, etc.
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                Re: UC3842 basics
                                Ok, I had a feeling that was the problem, will do some research now...
                                Muh-soggy-knee
                                  Re: UC3842 basics
                                  Please read the good app notes here:
                                  https://cdn.badcaps-static.com/pdfs/...c8af2b1f18.pdf
                                  i.e. page 12. That is how you learn. I and my co-worker go through this exercise every time we lay out new PCB's, it takes more than one time to get them right.
                                  • ben7
                                    Capaholic
                                    • Jan 2011
                                    • 4059
                                    Re: UC3842 basics
                                    You design PSU's? Awesome! I wanna do that
                                    Ah, gonna go re-build it now, the ground rail is carrying current from one end to the other end of the breadboard
                                    Muh-soggy-knee
                                    • ben7
                                      Capaholic
                                      • Jan 2011
                                      • 4059
                                      Re: UC3842 basics
                                      Update.
                                      So, I used wires to connect the mosfet and transformer directly to the bridge rectifier. Now there is no hiss or whine, but the output voltage is low
                                      I used some 20 gauge single conductor copper wire, but it didn't do anything better.
                                      Muh-soggy-knee
                                        Re: UC3842 basics
                                        Check your feedback section. I work with an expert that used to design power supplies for ALCATEL, very lucky to have good him to guide me, still learning every day.
                                        • ben7
                                          Capaholic
                                          • Jan 2011
                                          • 4059
                                          Re: UC3842 basics
                                          It turns out that I was missing a 470pF capacitor on the Isense pin, so it was triggering the overcurrent protection, causing the whole circuit to turn on and off, making the whine/squeal sound.
                                          With a 1A load, it is dead silent now!
                                          Muh-soggy-knee
                                          • tony359
                                            Faulty CRT AKF12/Philips CM8500: bad flyback?
                                            by tony359
                                            I have a CRT (Acorn AKF12, based on the 240V version of the Philips CM8500) which has stopped working. It's making a high pitched noise but not too high. I know this is symptom of a faulty flyback.
                                            What happens when a flyback fails? I see that the main voltages out of the PSU are not reaching rated values, as if there is a short.
                                            There are supposed to be 125V/26.5V/15.5V outputs but I am reading something like 48V, 10V and 8V. If I unplug the PSU from the rest of the PCB, I can measure the expected values.
                                            Can it be a short somewhere...
                                            08-22-2023, 04:39 PM
                                          • прямо
                                            Viper22A 5VSB circuit
                                            by прямо
                                            So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                                            In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                                            01-13-2024, 07:05 PM
                                          • kotel studios
                                            FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                                            by kotel studios
                                            Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                                            Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                                            I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                                            Any ideas where to go next?
                                            02-23-2025, 11:47 AM
                                          • mrcliem
                                            CM V700 no +5vsb, ICE2QR4765 low VCC in... Need guidance please...
                                            by mrcliem
                                            Hello...
                                            I got my self a dead CM V700 PSU, with nothing on +5vsb
                                            I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
                                            As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
                                            The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
                                            I have read the datasheet and and still can not...
                                            06-29-2023, 08:18 AM
                                          • retrotechrestoration
                                            Looking for a flyback transformer for an Eizo TX-C7 MA-791 17" CRT
                                            by retrotechrestoration
                                            I just saved this magnificent RGB input Eizo Flexscan TX-C7 MA-791 from the local e-waste...good news, the tube works and the board looks great...the bad news, it sounds like the flyback is shorted. (Turns on...perfect picture...systemic high voltage crackling heard while the picture flickers...then it blows the 5A fuse in my isolated A/C power supply.)
                                            Anyone have any leads on possibly finding a replacement? (photo shows the flyback model numbers)​...
                                            03-22-2024, 06:50 AM
