Did I broke Fortron?
  • Behemot
    • 4845
    • CZ
    Got this FSP300-60PN (PF). Seems like the good old platform with daughter board containing the compensation circuitry, now with 12cm fan.
    This one was very nastly full of dust, several caps bulged. Did complete recap, including the small ones on the daughter board. Tough work, my new solder pistol is too powerful Burned some traces but it should be all right…at least I think so
    It is working almost fine, with just one small problem…voltages are terribly up Don't know whether something is shorted or broke somewhere, I don't think so, Fortrons are sensitive on this and usually do not even start in such occasions. So maybe too low ESR now? There were some nasty brands before recap (usual Teapo and OST but Jamicon also).
    I tried to play with potentiometers, best result is some 15 V on +12 V, 6 V on +5 V SB and so on. One potentiometer gives lowest values when there is lowest resistance on him, I was thinking of lowering it from 8 ohms even lower, to some 1-2 ohms, or even using wire connection…? Otherwise it has big spread, up to several kiloohms.
    And if the regulation is based on +5V SB, may I somehow lower the voltage so the rest will go down too? Cause the SB rail cannot be regulated by that potentiometer.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Did I broke Fortron?
    5vsb is always its own power supply. Are you really really really sure your multimeter is working right? A bad battery on a cheap 830B type meter gives higher readings than normal.
    A working TV? How boring!
    • Behemot
      • 4845
      • CZ
      Mmm, well it is true that I have very weak battery these days in my multimeter It is some FK Technics, this or similar: http://www.elektroeden.cz/digitalni-...8500+dp113541/
      I hooked it to a motheboard with bad BIOS, it didn't burn, so, do you think it would be wise to hook it to a good MoBo and use internal voltage measurement?
      ADD// fucking shit, U right. I should have realized it is no longer useful when the beeper inside the multimeter ceased to make any sound on the diode tester. Not mentioning I kept it on AGAIN the whole last night.
      Man I think I will leave my school. I can learn much more here on the forums than in the school. PCBONEZ could even teach me how to operate NPP, so really, what's the point in visiting to my university?
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        That's a 830B with beeper and temperature, aka a 838. It adds a beeper to the diode checker and sacrifices the 200uA range for a temperature probe. It suffers from the same issues the 830B does, being based off the same chip. Low battery will give higher readings, and won't always be detected by the onboard "battery low" indicator.
        And yes i agree that uni in some countries is basically pointless and doesn't teach you sh*t. Still, you need that piece of paper called a diploma.
        • Behemot
          • 4845
          • CZ
          Another good PSU for sale
          Well this school is able to gimme much, but I am begining to dislike it anyway. I think am just not for this kind of „high-end“ math and physics and stuff. Also lazy, but I definitelly dunno liek it as I did at secodnary grammar school (currently at faculty of nuclear and physical engineering studies)
          I suggest you to write down how many beers I own you, I definitelly won't remember that. Make it two now
            master hoarder
            • May 2008
            • 12175
            I had a similar experience with my cheapo 830D. A while back I was testing a trash-picked PC. When I checked the 5VSB, I immediatelly unplugged it as I was unsure if it would damage my (one and only) favorite keyboard and mouse (that's all I had for testing back then). The 5VSB read nearly 6V. Seemed strange as the power supply was a nicely-built Astec with all Japanese caps and a proper chip-based 5VSB circuit. When I tried a different power supply (before suspecting my meter), it too read really high on the multimeter. Finally checked it against a known-good source and it read 2V over. Changed the battery and everything was back to normal.
            I feel the same way too. The college I go to is only teaching us theory. I was testing a DVD drive laser today to see what kind of current would give me the required wattage output (needed 2 *good* multimeters, so I couldn't test this at home). The TA who instructs our lab had no idea which was the laser diode, and I had only 2 components on the breadboard - a MOSFET and the laser diode . We also have a few "smart" kids in the lab that always have trouble building the circuits. Took them the entire class time (almost 3 hours) to complete the midterm. I did mine in 10 minutes - 5 for getting the probes and wires, and 5 for actually building the circuit and answering the questions . But I fail at theory, so... dropping out might happen sooner than later.
            • rogfanther
              • Jul 2006
              • 458
              • Brazil
              Theory is important, to understand the reasons things work / don´t work. It is hard to endure some classes, more so when the teacher is not that good, but, like eating vegetables, it is an important thing.
              We had that kind of lab classes, where the girls with the top grades, those who would write down in their notes even when the teacher sneezes these girls would stare at the logic simulators, not knowing what to do. And us, the plebeian portion of the class, would have ours up and running in the first hour, even with some bells and whistles...
              But to be fair to the ladies in question, when writing the essays about what we had done, we would have difficulties too, because we knew how to do it, we knew how and why it worked/didn´t worked, but were not able to explain in an adequate manner.
              • Behemot
                • 4845
                • CZ
                Did one testing of a recapped board today when noticed the board shouts about having just 2,59 V on +3,3V rail. I've stared as calf at barn-door, but multimeter (this time with good battery) confirmed it. Well, I should have checked it after my playtime Its fine now with 12,15 V and 3,35 V no load, 12,3 V/3,34 V mild load
                • b700029
                  Banned
                  • Sep 2010
                  • 640
                  That almost sounds like an attempt at fail-safe... because a meter that is reading under the real voltage could lead to worse results than one that's reading over.
                    Cheap Chinese meters don't care about safety. It occurs by coincidence - the voltage reference falls when the battery is too low.
                      After all of...
                      07-13-2024, 08:14 PM
                    • Xenon-Codex
                      Volume potentiometer loudness tap bypass?
                      by Xenon-Codex
                      I salvaged a Sony TA-F170 with broken volume potentiometer. It has a special pot with a loudness tap in the middle, of course not available anymore.
                      Is the loudness somehow possible to get to work, at least constant instead of variable? I have a regular potentiometer which works, but the loudness does not.​
                      01-16-2024, 01:53 PM
                    • nerdmafia
                      Broke off RTC Coin battery pin on HP EliteBook 840 G1 - Operating Systems do not load or install
                      by nerdmafia
                      Hi first question posting here, but no need to go easy on me!
                      I have an HP EliteBook 840 G1 non touchscreen. The symptoms are that: Repairing or reinstalling windows freezes no matter how i try it. Live Ubuntu that works on any other computer also freezes while trying to load it. The RAM sticks and the harddrive work fine in other computers. I broke off the connector by accident, CN4750 and was using the laptop for a while with no coin battery. According to this schematic I found on here, which I THINK is the correct schematic, pins 2, 3, and 4 should short to ground, and they do....
                      05-21-2025, 09:39 AM
                    • eccerr0r
                      lowest current galvanometer/analog meter (passively powered!)
                      by eccerr0r
                      Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
                      On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
                      04-16-2025, 12:41 AM
                    • nobbnobb1
                      BASH Subwoofer Amp No Sound, Power Ok (Atlantic Technology 642eSB)
                      by nobbnobb1
                      I have a really nice Atlantic Technology 642eSB subwoofer that I would love to get working. The problem is that the power appears ok (LED light is on), but there is no sound. I don't believe it to be the audio input board or anything wrong with the power as when in standby mode (LED = red), I can play a source and the LED turns green suggesting the input is being detected ok.
                      The amplifier is a common BASH design, my interpretation of the layout based on Picture #1:
                      - Top most hanging board is the audio input section. Note I accidentally broke the crossover...
                      09-30-2022, 03:46 PM
