Fake primary capacitors
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Fake primary capacitors
    Fake NCC cap, has a Hermei/Jamicon style vent. Looks pretty horrible, except the bottom of it doesn't look too bad
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Wow that sucker has high ESR.
      Try blowing it up, and video tape it. That vent looks like it wouldn't work that well ... notice the middle of it.
      Muh-soggy-knee
      • Behemot
        • 4845
        • CZ
        #63
        Seems like made in 1995. Is it possible it jsut went bad?
        • c_hegge
          • Sep 2009
          • 5219
          That capacitance is still in spec, but yeah, with ESR that high, I'd toss it into a fire and see what it does.
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            I bought the cap new off a crap Chinese site because I was curious. Out $1.99, no big deal. Should I blow it up or dissect it?
            • c_hegge
              • Sep 2009
              • 5219
              Blow it up. It's more fun
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                How shall I do it?
                • kaboom
                  "Oh, Grouchy!"
                  • Jan 2011
                  • 2507
                  Like this:
                  "pokemon go... to hell!"
                  EOL it...
                  All style and no substance.
                  guilty,guilty,guilty,guilty!
                  guilty of being cheap-made!
                  • domas
                    News Hater
                    • May 2013
                    • 323
                    • Denmark
                    #69
                    that's a HV cap, so it is more tricky. Typically you can bang lytics by overvoltaging them with AC, lets say with linear transformer of 24V and enough amps. I guess this one would explode on AC too.
                    • Behemot
                      • 4845
                      • CZ
                      #70
                      I think you can use transformer welder just fine It passes on "enough amps"
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        Originally posted by kaboom
                        Like this:
                        • c_hegge
                          • Sep 2009
                          • 5219
                          I was gonna say toss it into a fire
                            master hoarder
                            • May 2008
                            • 12170
                            • Bulgaria
                            #73
                            I would dissect it, fill it up with water (piss would be funnier, but probably too gross for most people), then seal it again (with ductape, of course), and see how it performs.
                            I say there is a chance it might do better.
                            • ttn328
                              • Jan 2011
                              • 12
                              • Vietnam
                              #74
                              Sorry for off topic.
                              Some Chinese companies can fake rating on their cheap caps, could they also fake rating or specs on semiconductor products such as diode,... say they up a general purpose 1N4007 to FR107 or something ? It is serious, many fast recovery diodes are used in PSU.
                              • Behemot
                                • 4845
                                • CZ
                                #75
                                There is too many fakes of everything. I would not worry about 1A diodes but more like high-power transistors and diodes. If you make the junction half or quarter the size it should be, it hardly does 20, 30 amperes etc.
                                  I wouldn't be entirely surprised if this happens with smaller devices.
                                  It definitely happens with larger ones, see: http://sound.westhost.com/counterfeit.htm
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    • Romania
                                    #77
                                    FR107s are cheap enough for the chinese not to bother. On the other hand, i've seen plenty of PSU designs where a 1N4007 has been used in place of a fast recovery diode. Of course, it eventually failed.
                                    A working TV? How boring!
                                      I've seen fake 5mm LEDs (re-cased 3mm LEDs) so it wouldn't surprise me. Those were small signal LEDs, maybe 5 pence (~6 euro cents) each in volume.
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        I really need to see a picture of these...
                                        • kc8adu
                                          • Nov 2003
                                          • 8832
                                          • U.S.A!
                                          #80
                                          i have seen those.
                                          while the optical charecteristics would stink in most cases the die is the same between 3mm and 5mm.
                                          its no surprise from folks who make fake eggs.
                                          http://www.chinahush.com/2009/04/24/...-chicken-eggs/
                                          • eryjus
                                            by eryjus
                                            05-10-2023, 11:21 AM
                                            by momaka
                                            03-12-2025, 03:42 PM
                                          • Paxman_Swede
                                            by Paxman_Swede
                                            Hello!
                                            01-14-2025, 09:51 AM
                                          • Galraedia
                                            Fake Caps in Xbox 360
                                            by Galraedia
                                            I decided to take one of the Rubycon capacitors out of a phat Xbox 360 with a Zephyr motherboard and noticed that all the Rubycon capacitors near the CPU were fake. The capacitors in question are Rubycon MFZ 680uf 6.3V and they all have a bullseye bottom, something not found in genuine Rubycon capacitors. None of them were leaking, they all have the K top, and the system has never been opened before. It appears Microsoft was using fake capacitors in the Xbox 360, or the Chinese facility where the console was manufactured in was using them and passing them off a genuine. Just thought I'd share...
                                            02-04-2023, 09:55 PM
                                          • Foetuss
                                            Gigabyte GA-6OXT :: caps question
                                            by Foetuss
                                            Good evening
                                            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                            But I was also suprised about the bigger boys, which are 330µF 25V.
                                            Could it be they used 25V caps because they were cheaper / available at that time?...
                                            02-11-2025, 12:22 PM
