bridge rectifers in parallel
  • hkivan
    • Mar 2006
    • 122
    Hi guys,
    Sometimes, I want to solder additional caps to the primary caps in parallel so that to increase the overall capacitance. But, I know this would impose additional stress on the rectifier. I have come across some PSUs with 2 bridge rectifiers stick together. Are they work in parallel ? If I solder a bridge rectifier to my existing one in PSU, will it be helpful ?
    I have the folowing on my hand ,
    rubycon MXR 400v 120uF
    Teapo LXK 200v 680uF x2
    HEC LS 200v 680uF x2
    ENLA for audio 56v 8200uF x2
    nichicon VX 160v 100uF x2
    STO 200v 330uF
    TL 400v 47uF..... and some bridge rectifiers
    As a DIYer, I wish I can use my existing inventory to full extent.
    I ever recap a DVD player, some AGP cards, m/bs , PSUs, ...etc.
    I just enjoy DIY, getting the most out of some cheap items, upgrading
    everything as possible.
  • larrymoencurly
    • Oct 2004
    • 960
    Re: bridge rectifers in parallel
    I was told that when diodes are put in parallel, they have to match almost exactly in the amount of voltage each one drop, and because that voltage varies with temperature, they have to be clamped together, either directly or through a heatsink.
    • hkivan
      • Mar 2006
      • 122
      You mean that different diodes can work in parallel provided they have the same
      temp.
      I want to add a bridge rectifier to work in parallel to the existing one and attach
      a heatsink to them. Afterwards, I will double the primary caps to further smooth down I/P current. Because I have a no. of 200V caps on hand and have nothing to do with.
      I replaced a small cap to a larger one in a DVD player before. As I read from some
      forums , it is to make the picture quality better by filtering more noise.
      • arneson
        • Sep 2005
        • 1267
        Better to go to a larger device to begin with.
        Bridges come in all shapes and sizes.
        Jim
        • tiresias
          • Feb 2006
          • 489
          Yes - or if you don't mind some extra soldering, I guess you could use four separate diodes rated with a higher current rating in place of the existing rectifier package.
          • hkivan
            • Mar 2006
            • 122
            By the way, why bridge rectifiers are always soldered in the way that
            they have their long legs above pcb? why keep their legs so long?
            Why don't just like caps, having cut their short ?
            Sometimes, I think I just solder an additional bridge to their legs and make them work
            in parallel. It is the easiest way , saving any extra work.
            • arneson
              • Sep 2005
              • 1267
              Bridges get Hot. That's my best answer. If theres a center mounting hole you can bolt on a heat sink, or glue on. This is why a bigger device is better.
              Jim
              • hkivan
                • Mar 2006
                • 122
                I just want to solder a different bridge to the existing bridge.
                Will they works and have a longer life span?
                In this way, could they withstand higher inrush current?
                • PeteS in CA
                  • Aug 2005
                  • 3580
                  • USA, Unsure of Planet
                  Like Arneson said, BRs get hot, and may be raised above the board to avoid toasting the PCB. This is usually done with .5W and higher resistors, too. Also, the mfr may be using the same PCB for multiple models, with some components having different lead spacing.
                  PeteS in CA
                  • arneson
                    • Sep 2005
                    • 1267
                    Increasing the rating of a bridge beyond the original design may well extend It's life but will not help anything down wind of it.
                    Generally they are highly over rated to begin with.
                    Jim
                    • hkivan
                      • Mar 2006
                      • 122
                      I learnt of some guys replace the I/P caps of their
                      hi fi equipments to a larger ones. The I/P bridges were
                      fried when they just swtiched on their equipments.
                      For PSU, I wish to know how large a cap I can use
                      with a RS606 bridge? How do know the value of
                      the peak forward surge current of a cap ( caps in
                      parallel ) to the bridge ?
                      • PeteS in CA
                        • Aug 2005
                        • 3580
                        The surge current is going to be determined by circuit resistances - IEC 320 connector contact resistance, wire harness resistances, trace resistances, inductor winding resistances - and the inrush limiting circuit, usually one or two thermistors. The resistance of the thermistors can be affected by when they P/S was last running (IOW, if they are still hot). The P/S spec should tell you what the maximum "cold" inrush current is.
                        PeteS in CA
                        • PeteS in CA
                          • Aug 2005
                          • 3580
                          I could be wrong in that last sentence, unless you get ahold of the detailed spec for the model. The ATX12V spec, , merely requires no damage to components and not exceeding connectors' and wires' ratings.
                          PeteS in CA
                          • gonzo0815
                            • Feb 2006
                            • 1600
                            AFAIK it is no probem to use rectifier in parallel. If one of the diodes will getting hotter due conducting slightly better the resistence will rise and limmit the power flowing though it and the current will spread over the other diodes. But of course, the diodes should be overrated to do that.
                            • hkivan
                              • Mar 2006
                              • 122
                              Thank a lot.
                              I glad to see many technicial folks in this forum.
                              • PeteS in CA
                                • Aug 2005
                                • 3580
                                The V(F) of rectifiers has a negative temperature coefficient - V(F) decreases as the diode die gets hotter. Thus, as one of the parallel diodes gets hotter that the other, its V(F) decreases, increasing the share of the total current that diode conducts. OTOH, V(F) will rise as conducted current increases, so it may eventually reach some kind of balance, but it may accidentally be 50-50, or 100-0, or somewhere in between. Where depends on V(F) matching, device cooling, and the phase of the moon.
                                PeteS in CA
