Suing Antec
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Suing Antec
    Originally posted by PCBONEZ
    At the time they were using Fuhjyyu - absolutely.
    It's a little too late now.
    The idea of avoiding liability by establishing a corporation just pisses me off.
    They begin to think "even if we knowingly fuck people over they can't touch us personally".
    Stock holders should share the $$$ of liability and CEO's should go to jail.
    I guarantee the quality of just about everything would improve.
    And I think we'd see fewer mine explosions, ship wrecks, and a lot less oil in the ocean....
    Agreed 100%.
    sigpic
    (Insert witty quote here)
    • Agent24
      I see dead caps
      • Oct 2007
      • 5096
      • New Zealand
      Re: Suing Antec
      Originally posted by 370forlife
      The thing is, antec hasn't used power supplies with Fuhjyyu caps in years.
      I'm pretty sure my friend's Antec Basiq has Fuhjyyu capacitors. Online reviews show some have CapXon.
      -David VanHorn
      • everell
        • Jan 2009
        • 1514
        Re: Suing Antec
        Also keep in mind a lot of other manufacturers used Fuhjyyu.
        Interesting that Bestec has an even worse reputation.......but I have never seen a Fuhjyyu capacitor in a Bestec........even the Bestec ATX-250 12E.
        So Antec with Fuhjyyu capacitors is better???
        Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
        • dmill89
          • Dec 2011
          • 2534
          Re: Suing Antec
          If it's a really old one it's possible. The early Basiq models were made by FSP which often uses CapXon capacitors in lower end models and also occasionally used Fuhjyyus in low-end models as well. However unlike the CWT built units these early FSP built Basiqs weren't designed to be quiet and thus had much higher RPM fans that don't cook the caps like the old CWT SP and TP series did so even low quality caps can last a while. The newer Basiq series PSUs are built by Delta and use mostly use Ltec which while not the best, are generally good enough for use in PSUs. Most of Antec's higher end offerings are Delta or SeaSonic and use Japanese caps.
          • dmill89
            • Dec 2011
            • 2534
            Re: Suing Antec
            I think the big issue with Bestec was their propensity to fry motherboards. While some of the Antec Smart Power's used a 2 transistor 5VSB rail like the Bestec ATX-250 12E on the Antec the "killer cap" is located between the heat sinks right in the airflow path while the caps on the secondary are buried in the wire loom and out of the airflow path causing the output caps on the secondary to fail first. This will generally either give lots of symptoms (buzzing, unstable system, etc.), or trip the protection circuitry leading to much less fried motherboards than the Bestec, there is still the occasional instance of a fried motherboard from and Antec SP but these are mostly people who ignored the symptoms of a failing PSU or units with a manufacturing defect. On the Bestecs the 5VSB "killer cap" is often the first to fail shooting excessively high voltage (often 12v+) down the 5VSB rail and frying the chipset. The CWT Antecs with Fuhjyyu caps may not be much if any more reliable as PSUs than Bestecs but they haven't cooked as many motherboards.
            • c_hegge
              • Sep 2009
              • 5219
              Re: Suing Antec
              Antecs did have 100% failure rates and they did often kill motherboards, and yes, they should have been sued back then for it. Personally, I still don't buy antec. Not because I fear the caps, but because I hate them as a company. If they were really that desparate for that extra 5oc/unit, they can add 50c to the price and I'll gladly pay it. It also annoys me how they tried to downplay it to make it seem like it was just a bad batch. IMO, they should have been recalled.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Re: Suing Antec
                OH BS.
                The Antecs not only fried motherboards they caused house fires.
                It's pretty old but there used to be thread with links to the stories.
                I personally found out about the Antec problems by frying a motherboard.
                The damned Antec [a TP2-550] was new out of the box and the Fuhjyyu WERE ALREADY BLOATED.
                I posted photos in here somewhere. Also very old now.
                Mann-Made Global Warming.
                - Dr Seuss
                • Shocker
                  Banned
                  • Dec 2011
                  • 635
                  #28
                  Re: Suing Antec
                  OH BS.
                  I remember it
                  https://www.badcaps.net/forum/showthread.php?t=3246
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5096
                    • New Zealand
                    #29
                    Re: Suing Antec
                    What do you expect? This is Fuhjyyu you're talking about...
                    -David VanHorn
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Re: Suing Antec
                      I bought the POS in '05 or '06 when I was still learning about caps.
                      There weren't any gripes about TP2's here (or anywhere) yet.
                      I hadn't run into Fuhjyyu yet either.
                      Then it sat on the shelf as a spare for a year or more before I used it.
                      I should have checked the forum again just before I tried it.
                      I was pissed because I -did- research it before I bought it and there weren't any gripes yet.
                      It was still too new.
                      By the time I used it there were gripes but I didn't think to check again.
                      AND it fried a really good board.
                      - Dr Seuss
                      • Shocker
                        Banned
                        • Dec 2011
                        • 635
                        #31
                        Re: Suing Antec
                        Yeah, Antec was a pimp back in the day.
                        Perhaps their designers drank too much .
                        Has anyone ever all over an Antec PSU???
                        Oh, wait a minute, they make Ower Upply Units.
                        • c_hegge
                          • Sep 2009
                          • 5219
                          Re: Suing Antec
                          You mean, like this?
                          • Shocker
                            Banned
                            • Dec 2011
                            • 635
                            #33
                            Re: Suing Antec
                            Yes
                            In any case, what was Antec drinking???
                            • Shocker
                              Banned
                              • Dec 2011
                              • 635
                              #34
                              Re: Suing Antec
                              What's an Ower Upply, anyway???
                              • c_hegge
                                • Sep 2009
                                • 5219
                                Re: Suing Antec
                                It's a power supply that only lasts for an ower (hour)
                                • Newbie2
                                  • Sep 2005
                                  • 885
                                  Re: Suing Antec
                                  An actual United Chemicon cap coming stock in a gutless wonder?!
                                  At least HongKongFlyApart Company decided to invest a few extra cents into that power supply...
                                  My gaming PC:
                                  AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                                  ASUS M4A77TD AMD 770 AM3 Motherboard
                                  PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                                  G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                                  TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                                  WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                                  ASUS Xonar DG 5.1 Channel PCI sound card
                                  Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                                  Antec Three Hundred Mid-Tower Case
                                  Microsoft Windows 10 Pro 64-bit
                                  Microsoft Windows 7 Ultimate SP1 64-bit
                                  • Shocker
                                    Banned
                                    • Dec 2011
                                    • 635
                                    #37
                                    Re: Suing Antec
                                    c_hegge: Gonna vote???
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      Re: Suing Antec
                                      Yup. I said no, because it's a bit late now
                                      • Shocker
                                        Banned
                                        • Dec 2011
                                        • 635
                                        #39
                                        Re: Suing Antec
                                        Guess I wrote the wrong words when starting. I should have wrote should Antec HAVE been sued.
                                        • c_hegge
                                          • Sep 2009
                                          • 5219
                                          Re: Suing Antec
                                          well, in that case, yes but I can't change my vote
                                          • sirpsychol
                                            Antec Earthwatts EA-380 smd element type/value
                                            by sirpsychol
                                            While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                                            09-03-2023, 07:58 PM
                                          • ajdrenter
                                            Picking caps for Antec SU-380
                                            by ajdrenter
                                            In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                                            https://www.badcaps.net/forum/showthread.php?t=14159
                                            It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                                            05-13-2023, 10:40 AM
                                          • CWEastwood
                                            Antec Smart Power SL300S capacitor replacement.
                                            by CWEastwood
                                            I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                                            The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                                            I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                                            Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                                            03-25-2023, 12:18 PM
                                          • s_henya
                                            Antec VP-600P and NE550M dead
                                            by s_henya
                                            Got in these 2 nice PSUs, both died after power surge.
                                            Both seems to be suffering from the same fault.
                                            Blown main fuse
                                            Shorted N mosfet 550v
                                            VP-600P: 5R280CE short between GDS
                                            NE550M: MDF18N50 short between GDS
                                            In terns of board layout these seems pretty identical.
                                            From past knowledge, once gate get shorted, most likely the for the driver to go bad as well.
                                            I never tried to salvage blown fuse PSU with shorted Mosfet due to that.
                                            Is it worth to try and replace the mosfets? is there a chance that the...
                                            12-03-2024, 10:00 PM
                                          • GnatGoSplat
                                            Antec BP500U APFC Coil
                                            by GnatGoSplat
                                            Antec BP500U PSU fried in my wife's gaming PC. I smelled something unpleasant last night, so I had a hunch something might be amiss. Woke up this morning to a popped breaker and immediately assumed the APFC cap must have blown. I last fixed it sometime in 2011, there's a thread about it here someplace. APFC and secondary caps that time. Replaced them with Panasonic caps. 10+yrs is probably a good run. It's been running 24/7 the last 3yrs, eth mining with a 1070ti and AFK fishing in Black Desert Online, lol.
                                            Anyway, cracked it open this morning, expecting it to just be the APFC cap...
                                            11-02-2021, 09:22 AM
