85V on 200V Primary?
  • mockingbird
    • Dec 2008
    • 5484
    I have a PSU I recapped, but when I turn it on, nothing happens. I checked one of the primaries and it is only showing 85V.
    Can someone point me in the right direction? Maye one of the MOSFETs are blown?
    master hoarder
    • May 2008
    • 12175
    Re: 85V on 200V Primary?
    Does the PSU have 2x 200v primary caps? APFC?
    The only two possible explanations I have for this is if you live in a country where the line voltage is 115 VAC and
    - the voltage-selecting switch on the PSU is in the 230V position (assuming the PSU is PPFC or no PFC)
    *OR*
    - the PSU is APFC but the APFC circuit is not working.
    Pictures would be helpful if you have some.s
    • mockingbird
      • Dec 2008
      • 5484
      Yes, it has 2 200V big caps.
      So if it is active PFC, there would be no switch, right?
      It's made by this company:
      http://www.ace-power.com.tw/
      I will try to take some pics. Thanks.
        master hoarder
        • May 2008
        • 12175
        Correct.
        The 85v you're getting across each cap is normal if the APFC isn't working or turning on. Reason why is because line voltage is 110-120 VAC (RMS). The rectified (peak) voltage is sqrt(2) times that, or about 160-170V. Since the caps are in series across that voltage, each one gets half of that voltage, which is roughly what you got.
