Theory question / exercise in determining capabilities of ATX PSU
  • rogfanther
    • Jul 2006
    • 458
    • Brazil
    First, I know this is a gutless crap. They sell well here, and are the kind of model found in popular shops.
    It is a Coletek CT-2045S. I collected a bunch of burnt PSUs from friends just for studying how to fix them, and was lucky to get 2 or 3 of the same model each. I ask you for please reviewing my conclusions.
    From the label :
    Peak Power : 450W
    3.3V - 18A
    5 V - 22A
    12V - 25A
    5Vsb - 2A
    -12V 0.3A
    Maximum combined power for 3.3V and 5V : 140W
    Primary diodes : 2 x 1N5406 ( rated max 3A ) and 2x 2A05 ( rated max 2A ) .
    Secondary rectifiers : 3.3V - S20C45C ( max. 20A )
    5V - S2045C ( max 20 A )
    12 V - F12C20C ( max 12A )
    The main controller is a Welltrend WT7520. Secondary caps are marked 1000uF x 16V KYS . The -12V line gets a 470uF x 16V KYS.
    The voltage here is 127VAC.
    So, I believe I could argue that the most power this would be able to have was 127 x 3A = 381W.
    With those secondary rectifiers, while the 3.3V current is inside the possible, the 5V exceeds it ( and in one of the psus, the 5V diode was shorted ) , and the 12V line is very exagerated.
    That , along with the ausence of pi filters, would make this a not-that-good 350W PSU with much ripple.
    Sorry for the bad photos, if necessary I can get a better camera in the office.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Theory question / exercise in determining capabilities of ATX PSU
    This is a CWT unit, unfortunately. Probably from their ISO division. It could probably do 100W barely in spec, maybe 150 before blowing.
    While the amperage rating of the input diodes would indicate they would fail at 381W, typically they can do much more than that. But it dosen't really matter as it would never reach that level of loading, probably more along the lines of 250W input to get 150W output before 'sploding.
    • b700029
      Banned
      • Sep 2010
      • 640
      What are the primary transistors?
      • rogfanther
        • Jul 2006
        • 458
        • Brazil
        The primary transistors are KSH130007A.
        370forlife, but is my analysis correct, in that with the maximum current for the secondary rectifiers, or the input diodes, limits the real maximum this psu would be able to do ?
        Thanks.
        • c_hegge
          • Sep 2009
          • 5219
          @370forlife, You sure that's a CWT? I can't imagine CWT would build something that bad (and there are no "CWT" markings on the transformers and no green tape). It looks like an Okia/Broadway Com Corp to me.
          @rogfanther, That is correct. The input diodes could in theory handle 381W assumming a 127V input which will equate to about 285W output assumming 75% efficiency, however, those switching transistors will go kaboom at before that.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            In cheap PSUs generally the maximum current of the secondary rectifiers limits the output power - but to reach that maximum current the primary switchers must be able to take it, and most of the time the heatsink they're on is way undersized for the task, and unless the overload was on only one rail they will usually fail before the diodes do. On your particular PSU you also have a really small output filtering toroid coil (the round thing with lots of wires on it). It'll do 200W... barely.
            Approaching maximum current also means high voltage drop thus a lot of wasted power (and more heat to get rid of). That's why cheap PSUs have lousy efficiency. Picture this - a 300W supply with 70% efficiency eats 429W from the wall. If the efficiency were 80% said PSU would be able to provide 350W from the same input power.
            As for primary rectifiers, their current handling capability depends a lot on their temperature. It's not uncommon for them to survive almost twice the rated current continuously if they're placed in the path of airflow.
            A working TV? How boring!
            • c_hegge
              • Sep 2009
              • 5219
              In this case, though, it wouldn't take much at all to overheat them with those tiny little heat sinks. I recently put an okia PSU on my load tester which looked similar to your unit. It managed only 79% efficiency on 230V (120W load), and failed at only 250W load. On a lower input voltage, the efficiency would be lower, so it would generate more heat and fail sooner. The ripple was WAAAYYYYY over the limit, even at 120W, at around 180mV on the 5V rail and over 200mV on the 12V.
              • rogfanther
                • Jul 2006
                • 458
                • Brazil
                Thanks, I forgot to search for current specifications for the switching transistors. Will read the datasheet again and add that to my notes.
                Shouldn´t CWT be somewhat like a reputable company, producing like maybe not-so-great PSUs, but at least better than this ? I believe most of the common PSUs sold here are rebadged L&C´s ( will post pictures when I find them in the PSU box ) .
                Because I don´t want to use good caps in this, I can´t measure the ripple, but will try to do it when some new one crosses my path. Is there a "proper" way to measure it , with some defined load, or can I just use some old harddisks and fans ?
                Thanks.
                • c_hegge
                  • Sep 2009
                  • 5219
                  You can use some old drives and fans, but don't connect anything to this PSU unless you don't mind killing it.
                  My load tester is one I put together myself with about 30 large power resistors.
                  To measure the ripple, you need an oscilloscope. I use an EasySync/USB Instruments DS1M12 Stingray.
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3112
                    BCC use CWT and yuelin as an oem. This is not a yuelin. But like I said, it is probably from CWT's ISO lineup which do not use CWT marked transformers and do not necessarily use green tape.
                    • rogfanther
                      • Jul 2006
                      • 458
                      • Brazil
                      green in like these ?
                      • 370forlife
                        Large Marge
                        • Aug 2008
                        • 3112
                        ^exactly.
                        • c_hegge
                          • Sep 2009
                          • 5219
                          ah, OK. I have an ISO -branded- PSU and it has CWT markings all over the transformers. In any case, though, they must have taken a low end 100W CWT and put a 450W label on it.
                          • lti
                            • May 2011
                            • 2551
                            I have a 75W power supply with more guts, and the manufacturer had to cram everything into a smaller enclosure.
                            Only one cap filters each output, there is no room for a pi filter, and the main filter coil is smaller than the 3.3V coil. If the filtering components had been installed and the heatsinks were bigger, the transformer would limit the output power.
                            I don't see how two small diodes and two big diodes can be used in the bridge rectifier.
                              master hoarder
                              • May 2008
                              • 12175
                              It's just like using 4 diodes of the same size.
                              Leadman/PowMax and low-end Sun Pro PSUs often do this.
                              In such a case, the big diodes are connected to the Live, and the smaller ones to Neutral.
                              - When the PSU is used in a country with 110-120 VAC, the smaller diodes are bi-passed by the voltage-selecting switch. Then the Neutral becomes connected to the common connection between the two primary filter caps and you have a voltage doubler circuit. Therefore, the current pulled from the wall by the PSU is limited by the rating of the bigger diodes.
                              - When the PSU is used in a country with 220-240 VAC, both the big and the small diodes are used to form a full-wave bridge rectifier. Therefore, the current pulled from the wall by the PSU is limited by the rating of the smaller diodes.
                              • b700029
                                Banned
                                • Sep 2010
                                • 640
                                And on 220-240, the amount of current drawn for a given output is on average 1/2 that for 110-120, so they save a few cents by using smaller diodes. Really clever cost savings, too bad they can't get anything else right
                                • sarry86
                                  Sony Dav-dz350 no power on secondary
                                  by sarry86
                                  Hi guys, I have this power supply which has a problem providing power on the secondary portion, seems like there's no power past the transformers, I checked the PFF4N80 which had shorted and replaced it with a new one, I then checked the optocoupler part and found that the TL341 IC too had shorted out so I replaced it with a new one as well, I measured everything on the secondary side of my power supply and I found a 1N5819 diode shorted, I replaced it with a new one, nothing else seem to have a problem, I am out of ideas, please anyone help me out what should I look after...
                                  11-10-2022, 07:48 AM
                                  Secondary out 32 volts AC getting 146 volts DC do not understand
                                  I will post a picture of this transformer setup tomorrow I hope someone can shed some light on how this
                                  could be ( has a bridge rectifier with no capacitors on the DC side on other thing that is strange about this setup is that negative side of the bridge rectifier also goes to machine ground )
                                  Now if check one wire that to the machine ground and wire one tap that goes to the bridge rectifier the voltage is really wired and when you check the other tap wire that goes to other side of the bridge rectifier this voltage is also is really weird but not 32 volts AC side of the...
                                  08-27-2020, 06:00 PM
                                • bauto601
                                  KDM 480W PSU upgrade succes! (opinions?)
                                  by bauto601
                                  Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                  A "nice" YoungYear unit? - Badcaps
                                  The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                  12-26-2023, 03:05 PM
                                • Crystaleyes
                                  TV standby to power_on circuitry theory and operation
                                  by Crystaleyes
                                  Although it is far from my main field of interest, people here keep asking me to fix their flat screen TV's.
                                  So far, the problems have generally been on the PSU, the T-Con or the backlights, all of which have been relatively straightforward.
                                  As far as the main board, or SSB, is concerned, the only real issues I've encountered have been bad caps and fucked BGA soldering.
                                  It has also become clear that 'stuck in standby' is a common problem, and something which I no experience with yet could waste lots of time on without an understanding of how the 3v3 is sent to trigger...
                                  07-11-2023, 08:34 AM
                                • repair-it
                                  Need help determining capacitor value 10C
                                  by repair-it
                                  Not sure what the value is for these caps labeled 10c. I know the WJ is 16v....
                                  05-29-2025, 05:01 PM
