I want to mod this atx psu I got (it's a logisys ps480d) to make a variable supply that outputs about +/- 5-25v at 15-20 amps. The schematic seems to be pretty similar to this. My plan is:
desolder basically the whole secondary side (including the main transformer),
reconnect the primary of the main transformer by soldering wires to the board and the transformer,
rectify and filter the output with properly rated schottky diodes and a pi filter,
make a voltage divider out of a 10k potentiometer and connect it to pin 1 of the tl494 (after desoldering the built-in voltage divider, of course).
I also plan to remove the lm339 because it wouldn't be serving any purpose (that I can see) after I basically redid the circuit with only feedback regulation.
I have several questions:
Do you think my plan would work?
Should I add input filtering/PFC or whatever? (This cheap piece of crap left out a lot of components.)
Are the main power transistors are good enough or should I replace them? Part number is D13007K.
What capacitances and inductance should I use in the pi filter?
Should I rewind the transformer? I'd rather not if I don't have to.
Am I correct in thinking that the main part that limits the maximum output is the transformer?
