Hi
Have a FSP 700 with a burned out inductor on the output side.
It handles 5v, 12v & -12v with 3, 8 & 8 turns respectively.
It has shorted 5v & 12v together.
I have a FSP 600 dead on the side with a good inductor however it has a different number of turns.
The 600 is a FSP700-80GLC(NEW)
The 700 is a FSP850-80GLN(REV1)
Turns are as follows
rail - 600 - 700
v - turns - turns
5 5 3
12 13 8
-12 13 8
Q. will this 600 inductor work in place of the 700?
If yes yipee!
If no, would unwinding be practical? Or perhaps a change in the output filter caps?
My knowledge is about Ohms law and not much more, although I do enjoy a little Giancoli.
Thanks in advance
Sal . . .
rail - 600 - 700
v - turns - turns
5 5 3
12 13 8
-12 13 8
If yes yipee!
Thanks in advance
Sal . . .
Even better is when I see a too-large rear exhaust fan and the one in the PS is temp controlled. The big fan puts the case into a vacuum and 'backdrafts' the fan in the PS. The heat removed by the case fan rises up and is pulled into the PS. The warmer-than-ambient air gets hotter as it picks up heat inside the PS and is then pulled into the chassis, to be exhausted and 'recirculated.'
) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
