AOpen FSP300-60BT PSU for Benchtesting Motherboards?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: AOpen FSP300-60BT PSU for Benchtesting Motherboards?
    Originally posted by KenOlson
    1. If the Server PSU has been in storage for 3+ years should a "burn in" be done for PSU. If yes what is correct procedure?
    Run a light load (a few old hard drives) for a day or so. The "burn in" is necessary for reforming the caps and to spot any issues that could cause failure later on. At this point some measuring equipment (a cheap multimeter and oscilloscope) will be useful.
    2. If connect a "Good Server PSU" and Floppy Drive to an unknown condition Motherboard, is it also necessary to have either a HDD or CD drive connected?
    No. It is a good idea to have the HDD and CD drive connected though, to see if the unknown condition board recognizes them. This can save headaches later on - ie when you decide the board is good, install it in a nice case with all the parts, and then you realize it won't see the HDD.
    A working TV? How boring!
      master hoarder
      • May 2008
      • 12170
      Originally posted by c_hegge
      I mean even with some load on it. Every time I mess with the load resistors on FSPs, they won't start, period.
      Interesting.
      The feedback design on those FPSs must be horrible, then.
      Are you sure you were removing the right resistors? Also what resistor values did you replace them with?
      • qwerty99
        Xbox 1.6 Motherboards and Polymer Capacitors
        by qwerty99
        Hello!
        I need to change the capacitors on my three original Xboxes.
        Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
        The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
        The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
        I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
        06-26-2022, 12:53 AM
      • Foetuss
        Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
        by Foetuss
        Hi all
        Hope this is in the correct place.
        I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
        Could use some double checking to see if I'm not doing something stupid .
        Pictures of the boards are attached.
        What I will be replacing with what : (planned)
        Soltek Golden ::
        4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
        6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
        01-18-2025, 11:44 AM
      • madscientist750
        Looking for capacitor lists for Motherboards, Video Cards, Home Appliances
        by madscientist750
        I would like to ask if there is some kind of capacitor lists for motherboards, power supplies, video cards, audio cards, microcontroller powered home appliances, and so, that i could try to find and download. I use to repair those things and i would find it helpful if i could know in advance what parts may i need for common repairs.
        07-09-2024, 09:24 AM
      • blues_spirit
        practical courses for troubleshooting pc motherboards
        by blues_spirit
        Hello from France,
        mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
        Do you think this is feasible for me? I...
        12-18-2022, 12:56 PM
      • Deby
        List of compatible laptop motherboards
        by Deby
        This is a list of compatible laptop motherboard information that I have been collecting for some time.
        And it's still ongoing.
        Every time I come across information that a board is compatible with another, I write it down.
        Anyone who wants to, can continue to expand the list.
        Packed in the rar, is an excel table that has additional information.
        Motherboards.rar...
        05-31-2024, 04:34 AM
